Question about Casio Parts Cash Register PC Desktop
Royal alpha 601 sc cash register
I have a Royal alpha 601sc cash register with a thermal printer. The problem is that the register was only printing on the left half of the receipt paper, but now there are just three little marks in the middle of the receipt paper when printing out a sales receipt. Nothing else prints out, even though I have tried changing the thermal paper. Hope you can help, so far the tech support at Royal has not been helpful, just keeps telling me to change the paper which doesn't help at all. Thank you!
  • 1 more comment
  • jlellisboaks Aug 19, 2008
    I really appreciate the advice, but unfortunately it didn't seem to work. I suppose my next step should be to take the cash register to someone who is qualified to work on it (which I definitely am NOT!) unless there is a better alternative. The closest place to take it that I've found so far is over an hour and a half away! Thanks so much again, appreciate any other advice anyone may have!
  • Anonymous Mar 15, 2014
    how do I load the receipt paper into an alpha 5 80 cash register
  • Anonymous Mar 30, 2014
    How to remove grand total on daily transaction receipt with Royal Alpha 585cx
  • 737 Answers
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
Posted on Aug 18, 2008
Use your keey or look at the bottom of the rgister near the drawer there is a sliver latch move it toward the left
Posted on Sep 06, 2010
How do i open stuck drawer on alpha 6010sc
Posted on Aug 28, 2008
I have Royal alpha 600/601SC Cash register with PS-700e bar code reader.I purchased one PS-700P bar code reader for that after the original got damaged. But I have problems with this unit. it does not
the clue is in what youve typed
you used to use a 700E type
you replaced with a 700P type
perhaps look for the 700E type that matches the older type you have
i would assume the last letter is the series ident so the one you replace it will it newer
perhaps doesnt communicate in the same exact way
Nov 30, 2014 | Royal Alpha Retail Supplies
Royal alpha 601 sc cash register will not come on what is the problem
Check the fuses. If they are all fine, call a tech.
Aug 19, 2014 | Retail Supplies
How to change the date on a royal alpha 601 sc cash register ?
Turn key to Prg mode for date punch in todays date, example June 13 2014 would be 061314 and depress the # key.
The time in Program mode would be for 9:45 Am 0945 and depress the QTY/Date Key. for PM you would use military time such as 3:00 PM would be 1500. Hope this helps.
Jun 11, 2014 | Casio Parts Cash Register PC Desktop
Royal alpha 1000ml
That has a thermal printer.. did you buy thermal paper? Did you insert it in the correct direction?
Apr 01, 2014 | Royal 29043x Alpha 1000 Ml Cash Register
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2¼ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
Nov 24, 2013 | Royal Office Equipment & Supplies
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
Thermal Printer for Royal 600/601 sc Cash not printing
do you have tape in backwards? one side will print other side will not.
Jun 28, 2009 | Royal Office Equipment & Supplies
Royal Alpha 601sc cash register won't program.
Hi. I don't have a manual for that model. If you can flick me an electronic version, I'll try to help.
May 27, 2009 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
810 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
