Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Cannot get the router to broadcast wireless
The wired connection is working fine, but it refuses to send out a wireless signal. When I access the router it doesn't seem to have any settings related to the wireless signal (but that's only as far as I can tell).
Additionally, the router is accessed via 192.168.0.1 when Verizon supposedly uses 192.168.1.1 - don't know if that's related to the problem or not.
  • 1 more comment
  • caldera32 Oct 02, 2008
    Turns out it that the wrong firmware had been flashed to the gateway. So sad...
  • Anonymous Oct 16, 2008
    i want to broadcast wireless
  • dcruse08 Jan 02, 2009
    I have a perfect wired signal but when i go to find the wireless network with my laptop, wii and other items it's not there. i have set up the network with my desktop and the light is even on but i can not find a signal what so ever.
  • 4,338 Answers
Check for a firmware update @
http://www2.verizon.net/micro/actiontec/actiontec.asp
Please remember to rate all users who assist you for free :)
Posted on Sep 30, 2008
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
Lose nettalk connection from router after on phone for twenty minutes
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 28, 2013 | netTALK DUO Wi-Fi VOIP Internet Phone...
Losing network connection
Oct 19, 2012 | Toshiba Computers & Internet
My d-link dir 615 wireless router will work fine and then just lose the signal and i have to un-plug the router and then re-plug it in again before it will work again why is this
Oct 16, 2012 | D-Link DIR-615 Wireless Router
Keep losing my wireless connections...
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
May 01, 2012 | Arris WR850GP Router
No Wireless Connectivity
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from other wireless routers and access points in your area.
Oct 09, 2009 | D-Link DIR-655 Wireless Router
My router is shutting off my internet
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible move the wireless router higher up.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 28, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My laptop shows full signal but refuses to connect to the router. The wireless phone rang two days ago and knocked me offline on wireless. Can someone please help? Nobody else's wireless device works...
It sounds like the wireless setup in the router may have gotten corrupted. From the wired PC, using a browser type 192.168.2.1 to access the router. It will ask you for a password. The default is to leave it blank. If you've set one, you'll need to give it the one you set. That'll get you into the router. Check the wireless setup. Everything else should be ok, or you wouldn't be able to access the internet from your wired PC.
If you can't find anything wrong, you can try rebooting the router and the modem. Shut both down as well as your wired PC. Wait 30 seconds. Boot the modem, the router and the PC at 30 second intervals.
Jun 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Router randomly stops sending out wireless signal
You may be getting interference from other routers in your area.
Check to see what channels the other routers are broadcasting in your area, change it to a channel that is not being used.
The location of the router could affect the signal strength, move the router away from concrete reinforced walls etc, and or move the router to a higher position in a clear space.
May 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
I want to use 2 wire ATT UVerse -- BUT NOT WIRELESS
the 2wire att uverse router, does not broadcast wireless signal if there is no wireless computer connected to its network. regarding the unchecking of the ssid, it will only hide the network name of your router, but technically, if a computer will try to connect to your router, it will still "send" wireless signal to a computer within its range.
you do not have to worry about the wireless signal being sent, if nobody connects to the router via wireless cionnection.
Jan 11, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
187 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
