Microsoft isatap adapter #15
I cant find the solution why my adapter doesn't function, the error message i always have is this
"This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available."
when i try to click, check for solutions, still can't find any.
please help me..my unit is acer aspire 5920.
thanks
Forget the system restore. The person who suggested this probably does not know what the problem is and is just maknig suggestions out of the blue.
Checkout http://support.microsoft.com/kb/932520.
If you get similar problems again got to the misrosoft web site and have a look - simple and effective.
Posted on Oct 19, 2008
Try doing a system restore
Posted on Aug 28, 2008
Need new download of ISATAP drivers
Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalog
In such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
Mar 18, 2013 | Microsoft ISATAP Adapter
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
I need microsoft ISATAP adapter #3 driver
you can try this:
Step1:
However, try the below steps to fix the issue you are experiencing:
1. Click on Start, type Device Manager in the search box.
2. In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
3. Still in Device Manager, click Action and select Add legacy hardware.
4. Click next, and select Install the hardware that I manually select from a list (Advanced), click next.
5. Select Network Adapters and click next.
6. Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
7. Click next and finish the remaining wizard.
Step2:
The ISATAP is related to Internet Protocol 6.
Please check if IPv6[Internet Protocol version] is enabled on your computer to obtain an IPv6 address.
however this driver only pertains to ipv6, so your internet adapter should still function properly. if it is, you can do this:
Disable but leave ISATAP in the hardware list and go to your manufacturers Website
and check for Post SP1 Driver updates for your computers Chipset.
Feb 01, 2012 | Toshiba Computers & Internet
Microsoft ISATAP Adapter This device is not working properly because Windows cannot load the drivers required for this device.
ISATAP is Microsoft trying to allow IPv6 to function over an IPv4 infrastructure, however, it was released extremely prematurely, and as a result, doesn't like to work, or install. According to Microsoft, your computer should continue to function without ISATAP functioning,and the error message may be ignored. However, if you believe that this may be causing you some problems, then you may navigate to the device manager ( Start > Control Panel > Hardware and Sound > Device Manager ) from this window, see if you can find ISATAP adapter and 4TO6 adapter, right-click these, and select "Disable" NOTE: this may cause Internet Explorer and Windows Mail to run slower and have a few errors.
I hope this helps!
May 08, 2011 | Microsoft Computers & Internet
Hi my Microsoft ISATAP is not working I followed the steps to reinstall it, is still not working
Hi j_lorcy,
As per Microsoft, you can safely ignore this error message. The Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager does not indicate a problem with the adapter. The adapter will continue to work correctly. Microsoft has confirmed that this is a problem in the Microsoft Windows Vista-based Computer or on a Windows Server 2008-based Computer.
Hope this helps.
Please post back if you have any questions or require any further assistance.
Thanks for using FixYa.
Nov 02, 2010 | HP Pavilion dv6000z Notebook
Hello, i have a hp notebook which code 31 error on
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Feb 23, 2010 | HP Pavilion dv6000z Notebook
ISATAP Adapter #26 not installed
http://www.soft32.com/download_175416.html
This is kinda Microsoft. See if you can dig around here for your version if this doesn't work. Good luck, and rate, if helpful of course.
Jun 01, 2009 | Microsoft Windows Vista Home Premium with...
EXCLAMATION MARK IN THE DEVICE MANAGER
Regarding the Microsoft ISATAP Adapter error, you can ignore it safely. Please refer to the following link:
http://support.microsoft.com/kb/932520/en-us
Dec 07, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
1,479 people viewed this question
David Payne
David Payne
