Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
HIT FOOT SWITCH AND MOTOR RUNS AND CUTS OFF WITHOUT COMPLETE CYCLE
    Sergeant:
    Champion:
  • 251 Answers
Trouble in ur wire going to the swtich contact ge about this problem looking forward to helping u Shaun
Posted on Nov 15, 2008
What would cause my Kenmore sewing machine's light to turn on but the motor seem to have no power?
The wiring for the older Kenmore is simple. The light switch completes the connection to the light. If the foot pedal has failed or connection loose where the wire attaches from the foot-pedal the motor will not run.
Also if the brushes in the motor are worn or failing to contact the motor internally the motor will not run.
With light on and pedal partially depressed attempt to activate motor to determine if brush connection are faulty. If the motor reacts at all the brushes will likely need to be replaced.
No success borrow a foot pedal from a friend or sewing center to determine if the pedal control is faulty.
Hope this helps?
Oct 15, 2016 | Kenmore Sewing Machines
Why does everything get hot except electrosurge wire tip for cutting?
A couple of possibilities:
1. Remove the belt. While using the foot pedal it is necessary to see if the motor moves freely without excess heat. If there is a problem the motor must be replaced or fixed.
2. Try to turn the machine without the motor attached by using the hand wheel. Does it move freely? If this is a problem the part that is causing the resistance must be found. Especially check the hook (under the bobbin case), needle arm and monitor moving parts.
3. Is the belt in good shape? If it is not so good then replace it.
4. While the belt is attached the motor must be cocked to allow the least resistance and most speed while the motor is running. This must be done carefully while the motor is running slowly. (foot control) The adjustment can be done most accurately this way.
5. Clean and oil all moving parts.
6. Make sure the bulb is the right size and not touching any of the metal surfaces.
May 19, 2015 | Sewing Machines
MOTOR CUT OUT , OR WONT IDLE AT STOP STREETS OR ROBOTS oIL LIGHTS START FLICKERING AND ENGINE STALLS
if this is happening when the foot is on the brake, then it is possible that the brake booster is leaking air and running the engine too lean.
check by idling without the foot on the brake
Feb 25, 2015 | 2005 Smart Fortwo Coupe
How to stop the bed from lowering when not contolling it?
If I remember correctly, that table uses an electric motor for the elevation. There are 2 possible problems. Either the down switch is sticking and the motor continues to run in the down position until it reaches its lowest point and hits the cut off switch or your electric motor needs a new brake installed. The brake installs between the motor and the actuator housing. These come apart fairly easily. For more information, or parts, call Pivotal Health Solutions @ 800-743-7738. I believe they are now the manufacturers of this table. Talk qith Quincey in parts.
Apr 30, 2014 | Chattanooga Adapta Summit Treatment Table
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
Dryer keeps cutting off and has to be restarted.
There is normally a switch inside the motor that detects in turning at speed. That keeps the dryer running until it is either stopped, the door is opened, or the cycle is through. I am guessing that the contacts are getting bad on this switch.
Jan 03, 2012 | Dryers
Old Jacuzzi Vectra (86), not cycling!
Keep giving it a few kicks! When that happens to motors it usually means that it is on its way out, I'd milk it for as long as possible but start thinking about a new pump and motor.
Aug 03, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a Lewmar Sprint 600 Windlass. It was working, however, my battires were low and there wasn't enough power to run the windlass. I think trying multiple times, I trick the breaker. I charged the...
I had the same problem this past weekend. Took the complete unit apart and found salt and all kind of moisture in the motor itself. It sure was not sealed very well from the factory. I am unable to find the motor sold separately, therefore I am taking my unit to an electric motor shop. I am guessing it will cost me about $100-$125 to get the motor reworked. It was extremely easy to take apart.
With the moisture in the motor, there was simply too much resistance for the windlass to turn, If you get your tension wrench and work the windlass back and forth, then hit the button. It should work temporarily.
Good Luck,
Tony
Apr 14, 2009 | Boating
The foot control is not working
well particular on electrical problem foot control is a switch of motor that deliver speed varies on how you press the foot pedal it consist of circular thick plate carbon the old model and the new one electronically control of power ic,It depend on how this pedal was contro.Anyway besure the power is off or unplug the machine; this control was been connected in series connection to the motor which you can test if your foot pedal control is defective. Disconnect the line wire holding foot pedal from the terminal inside motor assembly.If your not qualified electrician don.t do this.Connect the two terminal wire that inside the machine where the motor mounted.This connection is supplying your motor in full speed,Declucth your machine from the handwheel so that the motor run only.Plug the machine and switcn but you must jug only if the motor run in couple second of course without the foot control this was disconnected already.So your foot control is defective vice versa if motor does not run without foot control motor is busted.
how to fix if foot contol is defective, in carbon type you must replcace the circular thick carbon.On Electronic control check the IC if this open or some capacitor and resistor are open,Replaced any pars that had been short circuited.If the motor is defective replaced the carbon brush mounted at two side of motor case,There is an opening port.The carbon brush has spring holding push this carbon brush to the brush armature of rotor.
Mar 06, 2009 | Kenmore Sewing Machines
1997 CADILLAC DEVILLE D' ELEGANCE
check the tps switch and ilde air control mtr ref voltage one these control devices has failed thanks kdc744
Jan 08, 2009 | 1997 Cadillac DeVille
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
200 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
geapptech
Audie Bogus
Audie Bogus
Level 1 Expert
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
