Question about RCA P52926 52" Rear Projection Television
RCA Home Theatre Model # P56927, Serial # 026451246
Picture quality looks like double vision or shadowed. convergence lines need adjustment. i have tried the remote but i cant get it to work.
  • randynazer Aug 21, 2008
    all colored shadows. Please help!!!!!
    Genius:
  • 2,920 Answers
It sounds as though your convergence board went out
Posted on Sep 02, 2008
My sony kp57ws510 model tv has double vision and the double vision that shouldnt be there is in blue and red..whats wrong with my tv?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors on the tv convergence board are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Picture sinks from top and rises from bottom. Looks like doubles
You have a convergence problem. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to repair the problem and where to get the parts at the best price. If you need more help please let me know.
Thanks for using FixYa and for the generous rating.
hardrocko
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
Seeing double
You need to replace the convergance IC's
Sep 03, 2009 | Toshiba 56H80 56" Rear Projection...
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Home Theatre Projection TV
Your ICs are bad that control the Convergence. I would quess that the ICs that they have used before have been the cheaper versions. Sanyo are the best the cheap ones only last for a while then need replacing. The sanyo chips cost considerably more than the imitation ones but are worth it in the long run.
Mar 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red Shadow on Picture
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 61H71 61" Rear Projection...
RCA Home Theatre System 51 or 52"? Chassis # PTK169PAAS
If it is a "minor" convergence problem you can adjust it by going to the menu and scrolling to convergence and follow prompts A cross will appear when you have reached the correct place and you do the minor adjustments as it says. If picture is bowed you have major convergence problems.
Jan 05, 2008 | RCA 32V420T 32" TV
your convergence alignment is off,requires reaignment or possible replacement of module,this type of rca projection tv has a fault with the harness feeding the convergence module there is a fix for it,contact you local rca dealer,they must replace the connector because it bows and looses connection over time that creates other faults also/
Aug 22, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
113 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
