Question about Sharp AL 1631 Copier
Black lines across copies
There are black lines on the copies, i tried changing the toner but it didn't help
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does this happen only when you are copying or is it happening when you are printing as well?
  • Sharp Expert
  • 1,326 Answers
Question dose it only show up when using the adf/ doc. feeder? Also, dose it show up on both the copy board glass and adf? If it is just the adf, you need to clean the adf slip glass. The small piece of glass next to the copy board glass. If that is not the fix, it could be the Drum Unit or the Fixing unit..
Posted on Aug 20, 2008
Try the drum, replace and make a copy
Posted on Aug 19, 2008
Why is there black line printed across the page in 3 different areas when something is printed. I changed the toner catridge.
This is nearly always the fault of the toner cartridge. The previous cartridge may have left toner on the transfer roller and this may have contaminated the new toner cartridge. Take the toner cartridge out and inside the printer under where the toner cartridge goes you will see a felt roller that goes across the printer and has a gear at one end. Wipe this roller with a dry clean lint free cloth, rotating it to make sure it is completly clean.
Check the blue coloured drum on the toner cartridge to see if there is a black line going across it. If so clean it with the same dry clean cloth.
If this does not work then I suggest you buy a genuine toner cartridge and try that.
Jun 10, 2011 | Samsung ML-2510 Laser Printer
Paper comes out black when printing and copying.
A. The drum is not being charged. The charger corona wire is probably broken or not making good electrical contact. The charger corona wire may be part of the toner cartridge. Try uninstalling and reinstalling the toner cartridge. If that doesn’t work, try another toner cartridge.
Please rate my help++++Thanks for using FIXYA
Jun 05, 2010 | HP LaserJet 3050 All-In-One Printer
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Jul 22, 2008 | Canon PC-940 Black and White Copier
BLACK LINE ACROSS THE COPY CANON IMAGE 2200
Most likely your drum unit is worn out. If it reaches the yield of 50k or more, it starts to develop grooves in the drum and toner gets stuck in the groove and is applied to your pages. If you have a service company, they can change it for you. We sell the drum for $220.
Jun 30, 2008 | Canon imageRUNNER 2200
Black lines going across the pages
1 check the toner cartridge see it has toner rings on it
2 open - remove toner check the bottom for a thin glass strip clean
Jun 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
Sharp AL 1631 Copier Logo
257 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
