Question about Fujitsu 18C1 Air Conditioner
Leaking water I have a Fujitsu A/C, for some reason, it is leaking water pretty bad after turn on for 5 minutes.
We had the same issue, and it turned out that our filters inside the unit (the indoor unit) were pretty dirty and needed a clean, and also the run-off pipe/hose was blocked with a sludge, etc. We had to clean the filters inside just with warm soapy water and then blow up the hose outside and it fixed it pretty much straight away.
handy tip - take your mouth off the hose quickly, as the sludge will come out of there pretty quickly as the handy one found out!
Posted on Sep 21, 2008
My 96 jeep grand cherokee laredo over flow tank won't hold any water. The radiator was staying pretty full until now. It's leaking water can't find where it be?
Pull the dip stick for the oil , its probably over full ! The reason is that you have a bad head gasket ! So water / coolant are mixed with the oil !
Nov 16, 2016 | 1996 Jeep Grand Cherokee
American standard caded 3 leaking water from tank into toilet and occasionally running every 5 minutes. is this a flapper problem (it seems well seated) or could it be leaking elswhere?
It could be a bad seat around the flapper or the flapper itself. Replace flapper with one designed for the Cadet. Check water level and see it doesn't flow above the overflow tube. if it is above the tube lower the float ball by turning the screw at top of ball.
May 03, 2012 | American Standard Cadet 3 Right Height...
2003 Saab 9-5 2.3 leaks coolant (from engine cooling system-it's coolant/anitfreeze/water mix, not evap water, when ac on
Is it leaking inside the car? If so then it is more than likely the heater core is leaking antifreeze. You will need to replace the heater core under the dash.
May 12, 2017 | Saab 9 5 Cars & Trucks
Car is overheating. Flushed three times--no improvemrnt. Can run pretty well with heater on and windows open. Doesn't heat up at idle speed. Someone suggested a loose fan belt but it is hard to...
There are 3 common reasons for a car over-heating:
  • lack of coolant due to a leaking radiator hose
  • clogged thermostat-fails to open to allow more coolant from entering the the system
  • bad water pump- although most bad water pumps tend to leak, it's possible to have a bad bearing inside the water pump which in turn would fail to adequately circulate coolant
Mar 13, 2011 | 2003 Chrysler PT Cruiser
Leeking water from bottom
I wrote a page on leaking water heaters with resources and information:
Page lists things to check.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Also run hand over tank to find warm spot that says where leak is coming from
A rusted tank cannot be repaired.
If your tank is rusted out, it might burst open and flood the area.
Hot water inside tank is under pressure.
Turn off heat source to water heater.
Turn off water valve located above tank.
Open tub faucet on hot side and relieve pressure from tank.
You can limp along with a leaking water heater by turning it on when hot water is needed.
For example a shower uses 5-9 gallons hot water.
Turn gas water heater on for 15-20 minutes.
Turn electric on for 20-30 minutes.
To conserve resources with next heater:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Nov 15, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The faucet leaks, behind the wall when the shower
The most common reason for basement leakage is from the seal at the drain or the seal behind the overflow. With the overflow, the water trickles down after bouncing off your body and back onto the tub. This possibility MUST be eliminated first before determining the next step, Turn on the cold water and fill the tub and let the water go into the overflow for about 5 minutes. This will simulate someone in and using the shower. Check for leaks in the basement.
This test, as simple as it is, will also implicate bad plumbing connections at the valve itself behind the wall as well as eliminate backsplash from the showerer bouncing back onto your control valve(s).
If you have a leakage, wait a day and, with the drain open, turn on the hot/cold valve(s). and waste some water for another 5 minute test. This test eliminates the overflow as a suspect, and with the drain open almost always eliminates the drain as well. Hey..in plumbing there are no perfect answers.
If you still have leakage and no one is showering you have pretty well isolated the valve or connections to the valve. If you don't have leakage, it points to water bouncing off the body and onto the control valve(s) at which point resealing would be in order.
You can get leakage also if the caulking around the tub where the tub meets the wall has gone south. Stamped out steel tubs (common in rental apartments) have open corners so if the wall-to tub caulking is poor then the shower bounce off the body will easily trickle to the basement. This is not an issue with cast iron or fiberglass/plastic tubs.
If these tests truely point to the valve(s), repost your ? and refer to the drain tests completed, and supply as much information as you can about the brand and age of your valve(s)
Jun 02, 2010 | Moen & One Handle Tub & Shower Faucet
There is a oil puddle unnder my 1992 nissan pickup every time i move but the oil level is fine????? and i know it's leaking because i got under it and ran my finger along the oil pan and it was wet with...
you could have leaking valve cover gaskets leaking or a bad oil sending unit (oil pressure gague) .. make sure the oil is not red .. that wiould be a transmission leak .. over thghtning of the oil filter can cause leaks .. a clogged PCV valve can force oil out thru seals .. one way to track down leaks .. is to spray the engine with an engine solvent like Gunk .. then wash that off with a hose after it sits for a few minutes (keep water out of distributer).. that will clean the surfaces pretty good .. then it becomes obvious where leaks are coming from ..
if the oil turns out to be red in color . then look for hoses from the transmission to the radiator (transmission cooler) .. those frequently leak ..
Feb 22, 2010 | 1992 Nissan Pickup
Overheating, thought upper hose was leaking replaced that but still leaking is the thermostat in that area?
Your thermostat is located where the upper radiator hose connects to the engine under a housing. If it is not leaking there then check the bottom of your water pump. Look at it from underneath and you will see a small weep hole in the water pump housing. If it is leaking there your seal or bearing packing has gone bad. Simple solution- replace the water pump. The other reasons for overheating could be a stuck thermostat which will cause the vehicle to overheat within about 5-10 minutes after starting. The other cause could be a radiator that needs to be roded and cored because of to many deposits internally causing restricted flow of the coolant.The thermostat could be cracked or rusted out also. Try to gain access to a system pressurizer to find your leak. I have given you just about every scenario to check to find your problem. Good luck.
Dec 08, 2009 | 1994 Ford Explorer Limited
Water leaking during drain and spin
Hi!
You Need to check the following--
The fill hoses : These are located behind the washer and are connected to the water mixing valve and faucets. Pin holes and cracks on the hoses may cause them to leak.
The water valve: The water mixing valve is located behind the washer. The fill hoses connect to the water mixing valve. Inside of the valve is that the water gets directed to the filling spout. Water leaks happens when the valve develop pin holes or cracks. Bad fill hoses or water valve could be the reason why the washer is leaking water.
The Filling spout: Is just a directing part, this part directs the water from the water valve to the tank. Pin holes and cracks is what make this part to leak.
The tank : The major cause for the tank to leak is through holes or cracks that the tank develops because of vibration or metal items hitting the tank during the spin cycle.
The tub seal : The tub seal is made of rubber, it is connected between the transmission post and the center of the tank. Leaks developed when the seal gets worn out and it looses the ability to make a good seal between the transmission and the tank. A crack tank or worn out tub seal could be the reason why the washer is leaking water.
The overflow tube : This tube is use to direct the water away from any electrical parts like the motor in case of an overflow cause by a bad water mixing valve or bad water level switch.
The pump : The pump job is to remove the water from the tank to the drain pipe. This pump has an electric motor and an impeller. When the pump motor is turning, any water that falls in to the impeller, is push out to the drain pipe.
Most leaks are cause by a worn out seal between the front pump housing and the rear one.
The drain hose : The drain hose is made of hard plastic and some times it develops pin holes and cracks leaks. Bad pump or drain hose could be the reason why the washer is leaking water.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Rylee
Apr 03, 2009 | GE Washing Machines
1994 GMC Safari Oil leaked out for no reason. Put more oil in...look under van and oil is leaking like a water fall. Turn Van off oil leak calms to a trickle. Other than the oil water fall the van runs...
Check the oil filter adaptor bracket. My 1993 Safari had the same problem, and the adaptor bracket and seal were bad. Replacement fixed the leak.
Dec 31, 2008 | 2002 GMC Safari
Fujitsu 18C1 Air Conditioner Logo
468 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
