Question about Panasonic Lumix DMC-FZ5 Digital Camera
Blurriness When I take photos they all come out blurry. How can I fix this?
  • 876 Answers
This is a great camera! Are you using the focus guide to focus on your main subject. Move the camera until your main subject is in the bos ten depress the shutter button 1/2 way down to focus the subject. Leave you finger there at the focus point-You can then move the camera to take in more objects or people and gently push the shutter all the way down. Generally, the causes of out of focus photos are:
the camera in the wrong mode-just start with the general mode-usually a little camera symbol
do not change any settings-if you have go to the menu button and settings and go back to default settings
the focus feature of the camera 9explained above is not being used
You are too close to the subject (use the zoom instead)
You are experiencing camera movement by pressing on the shutter too hard or moving your hands. A tripod always works best.
You can go to www.panasonic.com and obtain a manual for your camera if you do not have it.
If your camera still gives you blurry photos, please get back to me with any info that might help- have you dropped it or gotten it wet or anything like that?
Thank you for using Fix YA and please don't forget to rate me!
Posted on Aug 18, 2008
  • 40 Answers
Clean the lens if it's dirty, try to turn on auto focus (or set up manually if you know the distance to an object you're shooting), get good light while taking pictures, stabilize the camera (try not to shake it), press the shooter button only half way down and wait a second until you see or hear the signal that the camera has focused the image, and then press the button all the way down to take the picture. Best pictures are usually taken during daylight, when the sun is behind the camera, and your camera is on a stand. Try not to take the pictures with camera pointed towards the sun.
I have a Olympus C-750 UltraZoom. I was taking pictures and everything was normal, but then I noticed the viewfinder was blurry. I was walking through a tunnel under a river and I thought the temperature...
Hi Steve, I inform you that the problem only is moisture. Please follow this.
1. Put the camera in sunlight for few hours. After that use it & if you face same problem then
2. You need to visit camera repair shop and they open the camera completely and clean all the inside part of the camera. because you need to clean the moisture inside of lens, viewfinder & sensor too.
So only hope in sunlight. If its solve then fine.
Jan 21, 2011 | Olympus Camedia C-750 Ultra Zoom Digital...
My webcam is blurry on MSN Live
Most of the blurriness of webcameras is due to poor lighting - try to increase the light next to where you are sitting. Also check for a rotatable ring around the lens - that's the focus ring, but not all cameras have that, some are fixed-focus.
Oct 20, 2009 | GE EasyCam Webcam
My camera was dropped, and the screen adn pictures are all blurry
Try going to a camera center. They have the expertise on that matter. They can also tell you to how much is needed to get it fixed.
May 02, 2009 | Kodak EasyShare Z812 IS Digital Camera
Shadowing and blurriness
needs a convergence board repair, not too hard to fix if you are handy with a soldering iron.
get the 2 convergence chips for this model @ partsstore.com
Mar 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
Blurriness
hellp you are very good
May 22, 2008 | Canon PowerShot A430 Digital Camera
RCA 36
I got an RCA 27" TV from someone who had moved it to another room but found it was "blurry" after moving it. I brought it home and tried all the suggestions I had found online but it was still blurry. I looked at the back of the TV and found 2 tiny knobs on the right (from the back view) which I began to fiddle with while looking at the screen. It fixed the blurriness immediately! I now have a beautiful screen.
Apr 30, 2008 | Toshiba 36A40 36" TV
Taking faster photos
The time delay is caused due to the time taken to focus. and the blurriness is caused by slow shutter speed which gets adjusted by the amount of light recieved by the camera light sensor.
Dec 04, 2007 | Samsung SGH-D900 Cellular Phone
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Panasonic Lumix DMC-FZ5 Digital Camera Logo
176 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
