Question about HP Computers & Internet
My hpofficejet6310 will not scan to computer without a computer camand when the scan button is depressed on the unit it says, (no scan optionsrefer to device documentation for troubling shooting) i can not find any referance to this in the booklet ???
Will not print
Posted on Oct 07, 2008
  • 114 Answers
You may need to uninstall then re-install HP software.
Posted on Aug 18, 2008
How can i set the clock for cadillac 1989
Car running, radio off. Press the volume button to display time and release. Depress the scan button for hour, seek button for min. This is from memory. the radio does not need to know AM or PM. depress each button till the proper hour and min. appear. If it goes past the correct time simply continue to depress the button till it is correct. Going past 59 min will not advance the hour.
Dec 07, 2016 | Cadillac Cars & Trucks
Isuzu 3ld-Tec 4x4 won't move out of park without depressing the shft-lock button
it is not supposed to move from park unless you press the button.
Oct 02, 2012 | Cars & Trucks
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My computer does not start when I depress the button. The light flickers once only.
At CompUSA, they sell an inexpensive power unit checker for around 10 bucks...it will check all the cable outlets for most power units and let you know if you have lost a main power rail.
May 21, 2010 | Antec 430-Watt Power Supply
How do i scan using a HP desktop F380
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    Mionet problem
    Your account has something called "account bug"
    You will need to reinstall MioNet on all computers, reset the My Book World, then attach it to your new MioNet account. You'll need to download the Blue-Ring My Book World version of MioNet here:
    http://www.MioNet.com/mbvista
    Then, to attach your My Book World to the new MioNet account (just select a new username when you re-install MioNet), follow these directions:
    1. Turn off My Book World
    2. Identify the reset button on the back of My Book World
    3. Depress the reset button while restarting My Book World
    4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
    You should now be able to sign in to the Shared Storage Manager as admin/123456.
    5. Please open your web browsers and enter (without the quotes) "http://<IP address of My Book World>" or "http://mybookworld" in the address bar. The Shared Storage Manager web page will appear.
    6. Once you have accessed the Western Digital Shared Storage Manager please select "General Setup" then choose "WD Anywhere Access settings." Use the default username of "admin" and default password of "123456" (without the quotes). On the following page you will have three buttons to select, please click on the "Reset" button. This will return the MioNet software on My Book World to default settings.
    7. From within the MioNet Client, go to File > Remove Computer. Locate the My Book World (WDStorage, MyBookWorld, or whatever you named it) and remove it.
    8. If you do not see a new window from MioNet informing you that you have a storage device available, "Scan for Cameras and New Devices…" to detect the unit.
    Jul 16, 2009 | Western Digital 500GB My Book World...
    I can't access my drive through mionet. My son accidently unplugged the world book and I can't access it ever since. Should I reinstall the mionet. I can't remember if there were any installation CD that...
    Once the My Book World has been plugged back in, it will request a new IP from the Router. If the drive was unplugged accidentally, the ethernet cable may have also been knocked loose: make sure all cables are attached to the Router and the My Book World.
    If your drive is still not appearing properly in MioNet, you can do a Hardware and Software reset on the drive. It will not affect your data, and it will allow you to re-attach the drive to your MioNet account. You do not need to reinstall MioNet to do this.\
    Jun 11, 2009 | Western Digital My Book World Edition 1TB...
    Have an HP Deskjet F2180 and it will not scan. Item placed on glass as instructed and scan button depressed, but nothing happens. Printer otherwise working perfectly.
    try connect your printer to your computer,
    then manually go to 'my computer',
    then double click on the printer,
    then choose scan.
    Nov 30, 2008 | Office Equipment & Supplies
    Unresponsive buttons on Head Unit - Help!
    i have the same problem and i can figure it out either
    Oct 01, 2007 | Sony CDX-GT210 CD Player
    Cannot turn on
    You can reset your Lyra player at any time by depressing and continually holding the power button for a minimum of 10 seconds. Upon releasing of the power button, the unit should reset. If it does not, we recommend that you try again by depressing and holding the power button for up to 20 seconds. Constant pressure is required to depress the button for this duration. Second, download the latest firmware for your player. As for the unit freezing I figured out that it has to do with WMA files. try to re-coded your WMA's to MP3. I think it just has to do with the firmware not liking WMA very much. Use MP3 format only and I think you will be fine.
    Jan 13, 2006 | RCA RD2826 MP3 Player
    Computers & Internet Logo
    164 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
