Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Cleaner will not come out of dispenser when handle is pressed.
Cleaner is not dispensing out of the cleaner resovior when trigger on handle is pressed.
  • 3 more comments
  • shannon_jeff Aug 20, 2008
    my shampooer won't spray out water just soap.
  • khm1174 Sep 10, 2008
    I've only used my cleaner a couple of times. Now it will not spray soap. I cannot find a model number on the machine. The only identifying information is "Dirtlifter Powerbrush".
  • rbeam Sep 11, 2008
    cleaner stopped dispensing soap half-way through cleaning my carpet. Now I can't get soap or water to come out. Happened when I refilled the machine. Any ideas?
  • Greytreiki Feb 19, 2009
    Cleaning solution will not dispense. The vacuum was stored with the dispenser not set to "closed" and wondering if that is the problem and a way to check if it's clogged. All else works.
  • Anonymous Mar 08, 2009
    Hi I have the same thing happen to mine. the bissell is a pro-heat+2 9200-y 08168c
    My email is sherrlynn47@hotmail.com
    Problem Solver:
  • 6 Answers
Greetings from GoVacuum.com,
It seems that you may have a bad pump. If you'd please give me the model number of the Bissell, I can give you the parts schematic so you can see how it's taken apart. We'd be happy to help you in explaining how to replace the pump should you have any questions.
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
Hoover troubleshooting
Hi! Try these quick and easy steps to get the water from your hose to spray.
Assemble the hose to the unit.
While holding the hose at an angle towards the ground, pump the trigger about 30 times. Turn the cleaner on then squeeze the trigger for 30 seconds.
If the water is still not dispensing there may be soap residue bulid-up clogging the nozzle/valve. Try soaking the trigger end in warm water for a couple hours, then repeating the steps above.
If the cleaner is still not dispensing from the hose but dispenses from the unit, a replacement hose may be needed. Follow the link below to order a replacement hose for your cleaner. Search Results
Aug 23, 2014 | Hoover F5826-900 SteamVac Upright Wet...
Why won't my Hoover SteamVac 7000 LS spray?
Hi there! Be sure you are only using the recommended detergent for your cleaner. Sometimes it is necessary to prime the trigger to get the solution to flow. Give these quick steps a try.
1. Recline the handle
2. Pump the trigger 30 times
3. Power the unit on.
4. Squeeze trigger for 60 seconds
If the cleaner still wont dispense you may have an issue with your pump assembly. We recommend taking your unit in to an authorized service center for repair. I have included a link where you may go to locate a service center near you. Service Center Locator
Thanks!
Aug 03, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
No water getting to brushs
Hi! Sometimes it is necessary to prime the trigger under the handle to get the solution flowing. To prime the trigger, recline the handle and pump trigger about 60 times. Then, power the cleaner on and squeeze the trigger for about 60 seconds. The solution should start to dispense. If it is still not dispensing there may be an issue with the pump assembly on the cleaner. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate one nearest you. Service Center Locator
Hope this helps!
Jun 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How can I fix my Hoover spin scrub 50 solution trigger? It is not working.
Hey there! Sounds like you have no tension in your trigger. This could mean a problem with the trigger spring or control rod in the handle. Try reassembling the handle. Remove the two handle screws and slide the handle up and off. Inspect the control rods for damages. They should be the same length. Make sure they are pulled down as well. Reassemble the handle. If the trigger still has no tension but the cleaner dispenses from the hose, a replacement handle may be needed. To replace the handle, follow the link below.
Search Results
Hope this was helpful!
Jun 11, 2014 | Hoover SteamVac Spinscrub 50 Carpet...
I am pulling the trigger and the carpet solution won't spray out
too much cleaner in the mixture, do you see the little fan type thing in the window spin usually when you dispense cleaner well it won't spin and dispense cleaner if you get it too soapy or concentrated.
Jul 07, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
Water does not come out when button is pushed
Check these items:
(1) When the trigger is pulled, does the rubber pad behind the tank seal on the handle get pressed down? A rod in the upper handle presses this rubber valve to dispense water/soap.
(2) Are any hoses kinked closed at the bottom pivot point of the lower handle, where attached to base?
Nov 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning
Either you have a pinched or clogged water line, or the rod in the handle is pushing down like it should. The drw back is Bissell has deemed this unit and its parts obsolete. So any parts are hard to find.
Nov 04, 2007 | Bissell 1950-3 Quicksteamer Plus Vacuum
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
174 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
