Question about Oster 76076-010 Hair Trimmer
The clippers started running intermittently and then stopped running. I opened the housing and nothing seemed burned out and the switch still makes a clicking sound when I turn it on and off, but the clippers don't run.
    Problem Solver:
  • 7 Answers
Sometimes if your blades dry out the clipper will turn on, but won't clip. try oiling you blades and then turn it on.
Posted on Feb 16, 2009
Won't turn on :(
It sounds like you know nothing about elecrical stuff so safety first, take it to a repair shop. If you have no experience with this sort work you can easily kill yourself or burn your house down; poor electrical work causes many house fires, so take it to the repair shop
Ring the supplier it may be a common problem or an easy fix. If no luck there take it to a repairman, preferably at a Bodum Bistro repair shop.
If the switch is unavailable, they may be able remove it and see if another switch can be substituted or added.
The worst case would be short switch out and the grinder will be on all the time now and you can turn it on and off at the wall socket or fit an in line switch to the power cord.
Ask for an estimate as it may be cheaper or at least more practical to replace it.
If you try to do it yourself you may electrocute yourself or burn your house down, so do some overtime and use the money to pay for an expert repairer or a new one.
Feb 27, 2014 | Bodum Bistro Electric Burr Coffee Grinder...
LG model LMV1638SW microwave intermittently runs.
The microwave runs intermittently. You should open it up and look at the connections to see if any have darkened or burn like signs. If you find that, you can either replace the (usually plastic) connection piece, or just remove it and reconnect the wires (that were housed in it), to their connection points. If you want, you can use electric tape to cover those metal wire connectors, but it's not necessary it nothing else is touching.
Nov 07, 2013 | Microwave Ovens
My clipper smoked and now it wont run at all
Sounds like your motor went out. You might as well buy new clippers for the price to fix them. One thing that causes that is when you spray your coolant to not hold your clippers blade up. Keep them blade down. The coolant can run into your clippers and burn them up. You only want to use grease inside your clippers.
Jan 21, 2013 | Andis Agc Super 2-speed Clipper...
What would make circuit board burn out in Andis AGP trimmers?
You need to replace the motor and the PCB. The motor is drawing too much current, that's what has wrecked the PCB. If the armature is a separate available part rather than a complete motor then it will be the armature you need.
Jun 25, 2012 | Andis Dog Clippers - AGP Super 2-Speed...
My Dyson DC07 vacuum started to run slower after being on for a little while and then would run normally again. I have switched on today and it has just stopped. When I push the start button, on...
The motor running slower was the motor starting to burn out. The "almost start" is the brushes making intermittent contact with the armature in the motor.
Your machine needs a new motor Pam.
Jan 18, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
I took off the end cap of my single speed A5 to clean out the dog hair and now they will not run. Before I took the end cap of and cleaned out the hair, the clippers would run intermitenly. Sometimes...
Chances are if you could wiggle the cord and get your clippers to start again there is a short in your power cord. However there is a list of other things to check:
  1. Within the cap are two brass tabs which sit across from conjugate tabs within the main housing. These are designed to contact each other when the cap is secured. If there is any question whether they are in contact, you can exaggerate the bend slightly to ensure that they are.
  2. Check your carbon brushes to make sure they are not worn down. The brushes are directional so make sure the concave surface direction matches that of the housing and thus the armature contained within.
  3. Lastly, check your toggle switch. Gently, tug on each end of the switch's wires to make sure they are secured to both the housing and the switch. These wires can become broken and appear to be attached to the switch when they are not. The number one cause is a loose or missing switch nut, especially since Oster has switched from metal to plastic on the nut.
Hope this helps.
Jan 06, 2011 | Oster Golden A5 1-Speed Universal Motor...
My Golden A5 clippers won't shave a knowlegable dog groomer friend of mine said the blade seems sprung from the housing it doesn't fit snug against the body of the clipper is there an adjustment I can...
it seem the hinge on your clipper is worn out, here how you can check it, place blade on with the clipper off tap the blade forward if the blade pop,s open the hinge is worn out, you need to replace it, Now on the cutting part of the blade when was the last time you had your blade sharpen. if it been a while or you can not remember it's time to have it sharpen by a professional.
Apr 13, 2010 | Oster Golden A5 1-Speed Universal Motor...
Proffesional Oster clippers model 274-69 seems to be frozen...
First, these are very sensitive to no lubrication. They should be lubricated every use to every few uses. Put a drop or two of light machine oil (sewing machine oil is about right) directly on the cutting blades. That may fix your problem. Also, watch the blades once you getit running and make sure the teeth totally pass each other or it will pull hair -- no fun! The travel of the moving blade is generally adjustable via a large plastic screw on the side of the clipper.
Dec 05, 2009 | Oster 76076-010 Hair Trimmer
Loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
Jul 03, 2009 | Wahl Designer 6 (8355100)
Wahl 9765-301
if you put oil on the blades does it help if you remove the blade you should see the pivot what make the blades moves hair preventthe blades from moving freely after if it still weak motor is weak not mush to do with that pricewise better by andnother one cheers
Jan 30, 2008 | Wahl 9765-301
Oster 76076-010 Hair Trimmer Logo
172 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
