Question about HP Compaq Evo Notebook N410c
Laptop fails to start up
When turned on compaq logo along with what can only be described as a screeching noise then amessage in the top l/h corner "non-system disk or disk error, replace and strike any key when ready".
    Master:
  • 788 Answers
Sounds like your hard drive has gone bad. Can be easily replaced with another 2.5" laptop hard drive but all your stuff is lost I'm afraid. Get it fixed under warranty if you still have time.
Posted on Aug 18, 2008
I have a Toshiba A505-S6960 laptop. Never have had a problem until today.......when I turn the laptop on it goes through the boot process but only makes it to the Toshiba logo screen with the F2 and F12...
It seems that your computer is not seeing your hard drive. This could either be because of bios settings or more likely because the hard drive has failed. If the unit is under warranty, call Toshiba support and describe the issue to them. If not, places like Best Buy can determine for sure the cause of the issue.
Toshiba Support
May 16, 2011 | Computers & Internet
I have a HPDV9000 Laptop and it is making a terrible loud noice, very annoying. Starts when turned on. What can it be. Thank you.
More than likely it's one of the cooling fans. They spin at relatively high RPM and if they're damaged they can emit a loud whirring or screeching noise. If it's a clicking noise then it could be your hard drive failing.
May 04, 2011 | Computers & Internet
I have a compac presario cq60. when i turn on the computer the there is a blinking line in the top left corner. the computer does not come on.
Hmmm,
Ok, well if your machine shows the manufacturer logo (Compaq) and then goes to the blinking light there is usual and issue with either the hard drive (hardware) or the installed operating system (software). If the cursor is blinking before the logo this is usually an bad component (most likely ram or motherboard) causing the machine not to turn on correctly.
All of these issues need professional help, if not under warranty I would bring this to my local shop to be looked at.
Mar 15, 2011 | Compaq Presario CQ60-220US PC Laptop
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dryer makes screeching noise..dries the clothes ..seems the tub is loose
at the top of the drum there is a felt pad with 3 white nylon glides attached to it. if this is worn, and it does wear, it will make a screeching noise like you described because it changes the postion of the drum and it will also appear like it is loose. you can purchase this part as a kit along with the glue to hold it on and it is not an expensive part. hope this helps.
Oct 14, 2009 | Frigidaire FEX831CS Top Load Stacked...
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
How do i turn on the bluetooth on my hp compaq 6720s
Not all compaq 6720s come with bluetooth module, but you can go to Control Panel --> System --> Hardware --> Device Manager, check whether your laptop is bluetooth ready, refer picture below,
If you can see the Bluetooth Devices in Device Manager, means your laptop is bluetooth ready. Then on your bluetooth by click the wireless button and you willl see blue light is on.
Check this icon at the right bottom corner of your desktop,
If BWT is disabled (red logo), enable it by right-clicking the Bluetooth icon and selecting Start the Bluetooth Device. The logo will change from red to white. Then you can use the Bluetooth Setup wizard to configure the service and security features as follows:
1. Right-click the Bluetooth icon, and then select Explore My Bluetooth Places.
2. Right-click the My Bluetooth Places icon in the Folders pane of Windows
Explorer and select Bluetooth Setup Wizard to begin the configuration process.
Jul 22, 2008 | Compaq Computers & Internet
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
HP Compaq Evo Notebook N410c Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
