Question about Ricoh IS 330DC Flatbed Scanner
Scanner Service The City of Bentonville (Arkansas) purchased several of these scanners to support our imaging needs for the City. One of these scanners has an issue that I'm not finding any information on via the troubleshooting web page. Scanning works properly however when finished and then returning later in the day to start another project, the red light is noticed to be on, and stays on and prevents any further use of the machine. Users must shut everything down completely and reboot, with the scanner being turned on prior to the computer itself being turned back on, before it can be used again. Once booted back up eveything works as it's suppose to, but then returns to that same status as it's left sitting again. This causes ever person needing to scan to repeat the same above process in order to use it. I beleive this to be one of the very first scanners we purchased and has already been sent back for repairs once. Our systems tech tried to figure out what's going on but has been unsuccessfull. Is there anything in particular that we should be looking for, or anything we can do to resolve this issue or will it be necessary to have a specialist service technician repair it?
  • 1 more comment
  • Carletta Aug 20, 2008
    Thought this solution solved the issue however the next day the red light was on again and the scanner un-usable/wouldn't scan a document. I think it must be a hardware issue not a software issue.
    Scanner is about 4 years old so is out of warranty. This is the only scanner we've had this problem with but is one of the first we purchased. While still under warranty, prior to my employement here, it was sent back for some type of other repair. My perception is that most likely it's defective equipment. I'll check into the replacement of it and compare to the cost of past and future repairs.
    This scanner is about 4 years old and is one of the first we purchased. Therefore, is out of warranty. This is the only machine we've had this issue with, however prior to my employement here I was told that, while still under warranty, it was sent out for repair for some other issue. I believe its a defective piece of equipment. I'll definately check into the replacement of it and compare to past and future repair costs.
  • 876 Answers
Have you tried uninstalling the scanner and reinstalling it? Do you have the original software for it. If you do not then you should be abe to obtain a driver download at this site:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/is330dc/is330dcen.htm
If you need to download the driver, be sure to do a clean download which means you need to turn off the scanner and unplug it,to turn off all running programs to do this including virus control. Download the file and save it to your desktop then click on it to install. Restart your computer.
If you have any other questions please let me know and please rate the solution. Thank You.
Posted on Aug 18, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 20, 2008
    How old is the scanner? is it still under warranty?
    You can go to this site and download amanual for your scanner:
    http://www.ricoh-usa.com/support/
    or you can find a service center here:
    http://www.ricoh-usa.com/about/salesands...
    i asked about the age of the scanner becasue teh cost of a scanner has come down alot in the past few years and sometimes, You are better off to replace than repair so be sure to obtain an estimate.
    Thank You for using Fix YA, and please rate my solution.
SOURCE:
Where are Walmart's Great Value products made?
I am not sure where they are made and assembled. However, I do know that they are officially distributed from their corporate offices in Bentonville, Arkansas.
Feb 16, 2014 | Cooking
Scaning only one side ( Right Side )of document.
I have many years repairing Canon scanners so I hope my suggestions help you out.
The problem your having is a common one with your model of canon scanner. It can be one of several things.
First it can be as simple as running some diagnostic paper through your scanner to resize the image. A certified canon technican can do this for you.
Second it can be a loose connector to the photo lens on your scanner causing the cut off image your experiencing now.
Lastly it could be the photo lens itself an the lens has failed and needs to be replaced. If that is the case I would suggest you purchase a new scanner because it will be cheaper then the cost of the repair.
I hope this helps you out and if not let me know.
Feb 28, 2011 | Canon DR-2580C Path-Through Scanner
Cant find police numbers in northeast arkansas to program in scan
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Apr 27, 2010 | Uniden BC796D Base Scanner
Hello I have recently purchased a second-hand CanoScan LiDE 25 scanner and it was accompanied by OmniPage SE Software. The reason for this purchase was to scan research papers for a friend. My experience...
Don't use the OmniPage software for scanning. OmniPage is an OCR (optical character recognition) program and is trying to convert the scan into a document compatible with a text editor (such as Microsoft Word). Use a graphics editing program, and use the option to 'Import' or 'Acquire' an image. Make sure that the LiDE 25 is specified as the scanner, and you should be linked to the scanner interface. Now when the scan is complete, it will be transferred to the graphics editor as an image, not a document.
Feb 04, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
What is the scanner frequencie for Woodstock City Police. Woodstock Ontario Canada
Here is the info from Radioreference.com.
http://www.radioreference.com/apps/db/?ctid=4312
139.77000 Woodstock City Police (Ch7)
142.42500 Woodstock City Police (?)
142.47000 Woodstock City Police (?)
142.68000 Woodstock City Police (Ch 1)
142.68000 Woodstock City Police (Ch 2)
142.86000 Woodstock City Police (ch 5)
142.92000 Woodstock City Police (Ch 6)
413.23750 Woodstock City Police (UHF)
158.38500 Woodstock City Fire
Hope this helps - J
For all of you scanner needs try ScannerMaster
Nov 18, 2009 | Radio Shack Pro-95 Handheld Scanner
Where can i get police frequencies for arkansas?
Hello there:
depending on what part of the state you live in this should help out a lot
  1. Central Arkansas Police Frequencies Central Arkansas Police. Benton Police. 154.580. Bryant Police. 155.565. 155.580. 154.680 new ... Shannon Hills. 37.220. Sheridan Police Dept. 155.640 ...www.skylord.com/kevin/central_police.html - Cached
  2. Northwest Arkansas Police Frequencies Northwest Arkansas Police. Bentonville Citywide Trunked System. 856.2625. 857.2625. 858.2625 ... Fayetteville Police Department 10-codes ...www.skylord.com/kevin/nw_police.html - Cached
  3. Arkansas State Police Scanner Frequencies and Radio Frequency ... Scanner Frequencies and Radio Frequency Reference for Arkansas State Police ... Arkansas State Police operations are conducted on this system. Frequency Display ...www.radioreference.com/apps/db/?aid=603 - Cached
  4. Arkansas Scanner Frequencies and Radio Frequency Reference Scanner Frequencies and Radio Frequency Reference for Arkansas ... Arkansas State Agencies. Frequencies for Arkansas public safety agencies. Choose Agency
  5. OK?
  6. best regards michael
Sep 28, 2009 | Radio Shack Pro-95 Handheld Scanner
Free scanner frequencies for arkansas
here you go
http://www.radioreference.com/apps/db/?ctid=165
Jul 03, 2009 | Radio Shack Radio Communications
Canon image class MF5750 printer/fax/scanner
If you're in the USA, go to this link. Enter your zip code or city / state and click the "Find Service Location" button.
May 22, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Working of negative scanner
The Manual explains all
There is usually a full user guide and manual on the software disk in PDF format.
The only way is to sit down and have a good read
Feb 01, 2008 | Office Equipment & Supplies
Ricoh IS 330DC Flatbed Scanner Logo
757 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
