Question about Sport & Outdoor - Others
Exercise Bike - Magnetic Resistance Failing
I have a 201 Schwinn Recumbent Exercise Bike, that I have been quite happy with for about 2 years now.
However, recently the resistance is failing - I believe it is a magnetic resistance system - and there is a slight difference between the weakest and hardest settings, but not like there should be.
Any help / suggestions, or even where I can find a repair manual?
  • Anonymous Jan 31, 2009
    I have the same problem. I could not change the resistance, although it changed on it's own. I pressed the + and - resistance buttons together, and now it doesn't change at all. I assume I shorted something out.
SOURCE:
SOURCE: I need an owners manual
Vital Fitness
Customer Service
5988 Peachtree Corners East
Norcross, GA 30071
888/337-2883 M-F 8-4:30 EST
Manual has assembly/maintenance instructions and a 1-page description of functionality. And a warranty card...that is printed on the back of the instruction page. *headslap*
kb
Posted on Mar 09, 2009
SOURCE: error message on recumbent bike
The problem might be the gearbox. I know because I have the same problem.  Keys fitness is out of business, but "The Treadmill Doctor" has purchased the inventory of parts for the bikes. They will help you troubleshoot, and have parts available if you need them. The number is 1-888-340-0482. Or, you can go to treadmilldoctor.com.
Posted on Apr 03, 2009
SOURCE: Wanted:Owners manual for DP Air gometer exercise bike
Scanned image of the 14 page manual that came with a DP AIR GOMETER Model 14-3800B that was purchased in 1991 is available at http://sites.google.com/site/oakrunsite/
Posted on Apr 12, 2009
SOURCE: the resistance belt on my Schwinn 205p recumbent
http://www.fitnessrepairparts.com/equipment/SelectEquipment/100 lists all the parts for this model
Posted on Jan 03, 2010
JayduttDave
  • 99 Answers
SOURCE: magnetic resistance not working on proform gl105
Just oil the area of magnetic resistance and if the problem continues then contact nearer repairer.
Posted on May 15, 2010
I need an owners manual for a Schwinn Recumbent Model 230 exercise bike. On line manual isn't for the 230 that i have. Will you send me one please?
We don't send anything. We are FIXYA, we are not Schwinn.
There are 5 different 230 models depending on the year. The manuals are in this link.
Product Manuals - Schwinn Fitness
www.schwinnfitness.com/manuals.html
  1. Cached
  2. Similar
Schwinn® 230 Recumbent Bike (2013 model), Assembly & Owner's Manual. Schwinn® 230 Recumbent Bike (2016 model), Assembly & Owner's Manual. Schwinn® 230i Recumbent Bike (2013 model), Assembly & Owner's Manual. Schwinn® 230i Recumbent Bike (2016 model), Assembly & Owner's Manual. Schwinn® ...
Schwinn Fitness Manuals
Dec 26, 2017 | Schwinn Exercise & Fitness
I've had a Schwinn 270 recumbent bike for 4 years. The resistance is completely gone. Suggestions?
I suggest you check the troubleshooting guide in the manual, as there are several causes for the resistance not changing. http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.270-MY17.AM-OM-W.EN.pdf I would suspect that no resistance at all might have to do with a failure of the servo motor, which appears to control resistance through interaction with magnets on the wheel.
Secondly, you can try contacting Schwinn Fitness: Customer Service
If you still can't figure out the problem you may need in-person help. Find a place that sells Schwinn exercise bikes or see if someone at a local gym that has recumbents can help you. The bike is apparently made by Nautilus.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Dec 06, 2017 | Schwinn Cycling
Does the schwinn recumbent 270 bike have a battery? It has an AC adaptor. The resistance will not increase when i press the higher resistance button.
It does not have a battery. Your resistance motor is most likely faulty. The only thing is, with schwinn, you will most likely have to replace the resistance motor, the console, and the wiring. All of this is very hard to find and will probably be more of a hassle than it's worth.
Jun 10, 2017 | Schwinn Exercise & Fitness
Resistance settings not working on fitnex r70 magnetic resistance exercise bike
If this is a new bike that may be the way it is. If it worked differently in the past, you may be looking at a busted tension motor or faulty brake.
Jan 03, 2014 | Champion Fitnex R70 Recumbent Exercise...
My new magnetic resistance bike is not working
The supplier or manufacturer can probably help you with this. Is there a support web site or toll-free number in the package.
Sep 29, 2012 | V-Fit Mptcr2 Programmable Recumbent...
What's the best exercise bike there is?
It is very difficult because there are two main versions of exercise bikes, so I've picket two of each type. If you prefer an upright bike the Schwinn 140 Upright Bike is the best pick, if you're more into recumbent bikes the best option is Nautilus R514 Recumbent Bike, both of them won the 2011 best exercise bikes.
Aug 09, 2012 | Exercise & Fitness
When can I get a replacement RESISTANCE BELT for my Schwinn 205p recumbent exercise bike?
This is Schwinn phone number. Contact them and ask whatever you are interested into. (800) 868-5764
Feb 28, 2011 | Cycling
Schwinn 201 recumbent bike makes clicking noise
Check the tightness of the crank bearings, also the crank fastening nuts (on axle) If its the gears you may have to turn the screws on the rear derailleur to adjust the tracking. The same as the front. Your question is kind of vague so its hard to pinpoint the clicking noise. Could even be a stone in the tire??lol
Feb 20, 2010 | Cycling
Schwinn recumbent bike 203 Ac adapter or batteries?
It uses an AC adapter. You can visit:
This is where I am getting the AC parts for my 201.
Mar 21, 2009 | Cycling
Sport & Outdoor - Others Logo
790 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
