Question about Sony KP-51HW40 51" Rear Projection Television
Blue Screen How do you fix a tuner on this tv? We called the nearest tv repairman and he said he doesn't travel this far but we could bring it in he would fix it. Since this is a 51 inch tv, it would be a pain to move. Especially if they are going to tell me it is going to cost $800 to fix. I may as well go out and buy a new one. Is this a costly fix?
    Genius:
  • 2,920 Answers
The tuner is about 100.00 you have to unsolder the old one and solder the new one in in its place takes about an hour to do
Posted on Aug 20, 2008
  • Ronnie Houston Aug 21, 2008
    the tuner is what the cable screws onto..the tv repair shop can order the new tuner for you if you ask him to
  • Ronnie Houston Aug 30, 2008
    if you take it to a shop they are going to charge alot more to fix it the tuner itself isnt that expenxive and if you know how to solder you can install it yourself.all you have to to is unsolder the old tuner and solder in the new one takes about an hour
Tv is hooked to cable but still gets no picture or sound...only a blank blue screen
Verify that the source is set to "Tuner", "Cable", "Antenna" or "TV". (I don't know which of these names Maxent uses, and the site formerly used for their downloads is now a generic search page.) Make sure the TV format is correct for your region (in the US it should be ATSC, sometimes called HDTV).
If you have a portable TV, bring it over and connect the cable to it to verify that the cable connection is good.
Check the other inputs to verify that the internal video switch is functioning properly. If you don't find a problem with any of these tests, you likely have a tuner problem. Note: do not use a tool to tighten the cable on the tuner connection. I've seen a lot of tuners broken that way, including some with the circuit board ripped apart inside. Use your fingers, and just make the nut snug enough to hold the cable in place and secure the ground connection made through the nut.
Feb 16, 2012 | Maxent MX-42HPT51 42 in. Plasma TV
Our picture will only show reds and greens, no other colors.
Go to your On Screen Menu to picture settings and reset and choose "reset picture" mode. This will bring you back to factory defaults. If this doesn't work shut off wait 10 sec. and turn on the TV. If still no luck call your best friend who is a TV repairman, you probably have a damaged blue drive.
Oct 02, 2011 | LG 32LG30 32 in. LCD HDTV
Vizio VW42L went black screen, no sound could turn on but not off, with remote or on the side. Called a repairman, decided to purchase a new TV. Year gone by, plugged it in and it has worked for several...
Yes,the tv main Tuner signal board it is the problems and the causes it have intermittents shorts in sides.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal boad for the replacement.
Jul 10, 2011 | Vizio 42 in. LCD TV
My television screen has an orange tint that I cannot fix by using the menu adjustments
Hi, If you have florescent lighting it will have an effect on the TV. Move the TV away or in another room. if that doesn't fix it call a repairman.
Jun 24, 2011 | Akai Televison & Video
Small blue dots all over the picture screen
In your tv the image is generated by 3 small LCD screens. In your case the blue LCD is dying - some pixels from it are no longer responding to the commands of the image processor.
To fix it you must replace the blue LCD screen. This is a very delicate job that requires extensive experience - you will have to call a repairman - and it will be expensive, around $600.
Apr 06, 2011 | Hitachi Televison & Video
Sony bravia kdl-46z4100 is 18 months old. TV speakers quit working. can they be replaced easily, or does a repairman have to be called.
Try the tv unplug,replug it back an hour later.The tv now,resetting back to factory setting.Go to tv Menu.Goto AUDIO setting,go down to reset,the Tuner board is now resetting.The tv should have sound now.Not than,the Tuner board have problems.Not the speakers,yes call the repairman.It'll cost half the price of a new tv.
Sep 07, 2010 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Flat screen tv, power works but it shows a continuous blue screen
Yes,Ur Main Tuner signal board is dead.Replaced this Tuner signal board will solved this problems.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner Siginal board for the replacement.
Mar 17, 2010 | Olevia LT42HVi 42 in. LCD Television
Fixed green light have audio but no video
it sounds like the tuner went out,you would have to know how to solder and remove the old tuner to be able to do it yourself
Aug 28, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Blue screen nonworking tuner
Yes get number of side of tuner and call around. I use www.bluestar-online.com for some cheap parts. But there are others, MCM, Tritronics, Dalbani etc.
Aug 20, 2007 | JVC AV-27530 27" TV
Sony KP-51HW40 51" Rear Projection Television Logo
46 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
