Question about Magellan RoadMate 700 GPS Receiver
Magellan 700 sound problem
Upgraded from 3.20 to 3.32- If I go to diagnostics and audio test, the sounds works like it used to. After turning unit off, sound does not work on powerup until the audio test
  • bosswoodster Aug 28, 2008
    I ended up taking parts from this gps to make up another before trying the fix. It seems as if it should have fixed it. thanks for the input
    Problem Solver:
  • 6 Answers
1. Search for the file ENG_F.SND sound on google or yahoo or any search engine.
2. Connect RM 700 to PC, and create folder name SOUND_EU on RM 700.
3. Copy the ENG_F.SND to SOUND_EU folder.
4. Disconnect RM 700 from PC.
5. Turn on RM 700, and go to Option, configuration, language, and choose English.
6. RM 700 will load sound file and turn off.
7. Turn on RM 700, if it keeps showing the initial screen, then connect the RM 700 to PC, and DELETE the ENG_F.SND from SOUND_EU. It should be OK after you disconnect RM 700 from PC and turn it on again.
GOOD LUCK!
NOTES: My screen indeed locked at first as covered in the last step, so expect that to happen. Don't worry if you never get to do step 5 and 6. Connecting the USB, deleting the SND file and restarting it works and the sound is back even without the file there.
This only fixes the Female voice along with the beeps and clicks. The unit goes silent again if you select the male voice but switching back to the female fixed that. I assume "_F" in the file name must mean female.
Posted on Aug 25, 2008
Magellan Maestro 4210 no audio or garbled sound
I suggest you take it back to the seloloer before the warranty expires
Jul 20, 2009 | Magellan Maestro 4210 Car GPS Receiver
I have the magellan 760, not have sound
Seriously, I believe your next step is to have the device inspected/repaired. At least you could call the manufacturer for FREE advice and FREE pricing. ZT3000 "Beta tester of "0"s and "1's"
Aug 12, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 firmware 3.32 upgrade
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it.i own now a mastreo 4000 so far so good no problems.
Feb 25, 2008 | Magellan RoadMate 700 GPS Receiver
Lost sound and audio
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.your choice
Jan 22, 2008 | Magellan RoadMate 700 GPS Receiver
Volume not working? Dial goes all the way around?
smegtrek
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
GOOD LUCK!
NOTES: My screen indeed locked at first as covered in the last step, so expect that to happen. Don't worry if you never get to do step 5 and 6. Connecting the USB deleting the SND file and restarting it works and the sound is back even without the file there.
This only fixes the Female voice along with the beeps and clicks. The unit goes silent again if you select the male voice but switching back to the female makes it work again. I assume "_F" in the file name must mean female.
The display still shows "AFIJDEN...." or something like that instead of the word "Exit" or "Entrance" when exiting or entering the freeway. Voice is fine though. Anyone got a fix for that?
Oct 05, 2007 | Magellan RoadMate 700 GPS Receiver
Negative audio test
Hi Please use the Audio test.If still its not working then send the unit for service.Magellan will charge you $ 49.95 if its not in warranty.
Aug 09, 2007 | Magellan RoadMate 700 GPS Receiver
this is not exactly what youare looking for but it will worth to know i guess. My 700 has auido problem. when i turn it on, i donto get any sound output. If you do the followign, configuration/diagnostic/audiotest, i recover the sound, till i touch sound volume bottom. It works fine considering nto everyday i need sound. I suggest you to
Aug 01, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 GPS
GOOD LUCK!
The display still shows "AFIJDEN...." or something like that instead of the word Exit or Entrance when exiting or entering the freeway. Voice is fine though. Anyone got a fix for that?
Mar 05, 2007 | Magellan RoadMate 700 GPS Receiver
My gps magellan 700 does not have sound
check to see if the sound will start working when you either run the tutorial or when you do the audio test. If it does work when you run these tasks, then you've got bigger problems than I deal with. As I would just swap out a ckt card, you do not have that capability. Alright, without having any addt'l parts, I'd open up the GPS and check the two wires and connectors inside to make sure they aren't split and that they are (obviously) still connected to the radio board.. (brd over keypad) You could have a blown speaker. If you have any contact cleaner then spray the audio adjuster b/c alot of times that gathers alot of build up. So, yea.. check your connections inside, there's really not too much that you can do, without additional parts to test them out. hope this helps atleast a little bit. -Daniel
Sep 04, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
159 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
