Question about Brother SE-270D Computerized Sewing Machine
Bobbins for se 270-d
My machine keeps bogging down...tons of piled up thread on bobbin side. Should I be using a particular bobbin with this machine? Also, I have never oiled my machine and do not see anything in manual..Should I be oiling it?
I have the same problem! I also have the same problem with the ULT2001. The SE270D is a class A bobbin if I'm not mistaken. I've tried ALL kinds of bobbins and did not repair the problem. I stopped embroidering w/it for a while and only used it for sewing. It started embroidering ok for now. As far as oiling - I researched this last week when the motor locked up. You should be keeping the bobbin area (pop the plates under the sewing foot off) and make sure you don't have lint building up there. But the best I found, DON'T OIL. I couldn't find anything anywhere that would tell me where to put oil. What I did find was that you should take your machine in to be serviced about every 300-500 hours of use.
Posted on Sep 06, 2008
Brother 700e
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
Thread keeps on bunching up on the bottom side of the fabric
try changing the needle
check the top thread tension to make sure it's not to loose
rethread the machine top & bobbin, make sure the bobbin is wound
correctly & inserted correctly into the machine
Jul 11, 2012 | Brother CS6000i Computerized Sewing...
I cannotl get my 270 D to even sew, it will not pick up the bobbin thread and do a thing. I have yet to sew the machine. donna
Picking up the bobbin thread has to be done by manually. Turn off the machine, open the bobbin door, lift the presser foot, hold the end of the upper thread and slowly turn the side wheel till the needle enters the bobbin race and on the way up it will catch the bobbin thread. Pull the upper thread till you lift the bobbin thread too. Put both threads to the back of the machine, close the bobbin door and you should be able to sew.
Apr 03, 2011 | Brother SE-270D Computerized Sewing...
WHat is wrong when the thread is pileing up on the botom side of fabric and it stalls during sewing? It is the main thread and not the bobbin thread, I changed colors so I could tell what tread was...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother SE-270D Computerized Sewing...
I'm new to embroidering. I have BrotherSE-270 Disney. I have read through the manuel several times and am confused about the bobbin thread. Do I use tread specficaly for embrodering or will regular thread...
Your machine probably came with brother embroidery bobbin thread (one spool, white)...I used it until it was gone and did buy more embroidery bobbin thread at a regular superstore (it wasn't brother brand though)...however, I have since used regular thread and not had problems. HOWEVER, be sure it is good, quality thread - none of that $.50/spool stuff. That knots up and simply doesn't look good if it does work. Good luck!
Jul 08, 2009 | Brother SE-270D Computerized Sewing...
I have a brother SE 270-d. my only problem is that while embroidering, the bobbin thread is showing through the design on the top. I have tried adjusting the top thread tension but no matter how I adjust...
Try making the material tighter in the hoop and check your bobbin to be sure it's a L (look at your instruction manual...it will show you which bobbin works and which does not. I say this because you have a tension problem...dont we all, Ha Ha!
Jun 22, 2009 | Brother SE-270D Computerized Sewing...
Old Kenmore 158. bobbin issues, thread clumping and such
problem is always on the opposite side of the fabric, in your case the machine is not threaded properly.
Apr 24, 2009 | Kenmore 16622 Mechanical Sewing Machine
Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Nov 23, 2008 | Brother SE-270D Computerized Sewing...
Singer model 9134
i had the same problem
it was stored in a garage (lots of heat) and i had a plastic bobbin
tons of thread on the bobbin side
so i bought new ones (brother brand) same problem
my friend pointed out the brand of bobbin makes a difference
so what the hek a couple more dollors before i toss the machine
and it worked when i bought singer brand bobbins
the heat must have shrank my first ones (like a shrinky dink )
your mileage may very
Dec 29, 2007 | Singer CE-200 Quantum Futura Computerized...
Adjusting Bobbin Tension
I looked forever to find this darn green bobbin screw. Around the opening for your bobbin is a plastic cover. If you slide it forward it will pop right off. Once you remove this, the bobbin case will lift right out. On the front you will see your green screw for adjusting your bobbin tension.
Dec 28, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
104 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
