Question about Whirlpool Duet GHW9150P Front Load Washer
Sour smell coming from inside whirlpool duet front loader
Can you advise on how to get ride of sour smell inside whirlpool duet front loader? I check that there was not any items caught inside the rubber door seal.
  • 2 more comments
  • Anonymous Aug 18, 2008
    I have had the same odor problem since we got it. I thought leaving the door open would help and cleaning the rubber seal would do the trick. No luck. I have just discovered that the brown funk is coming from the inside or outside of the metal barrel. I don't want this machine anymore but spent alot of money on it to just get a new one. I am surprised there has not been a recall but I guess unless is it a life threateningn issue the company doesn't have to do anything. My question to you is do you have the same problem?
  • Cherie895 Jan 20, 2009
    I had this terrible sour smell which at first I blamed on the dirty laundry. As the smell became worse I sniffed around and realized it was coming from the whirlpool HT Duet washer. Now I have to service this myself? I too, have suffered from sinitus and allergies and asthma! If I could afford it I would get a new washer and dryer today. Never buy one! We had an issue earlier with the pump and fix it ourselves because our service insisted we buy a new electronic panel!
    What energy and water efficient washer would you recommend? One that uses leswater than older versions and has a high speed spin to remove most of the water so clothes don't take so much time to dry?
  • Anonymous Mar 12, 2014
    e03 error on whirlpool duet front loader
  • Anonymous Mar 29, 2014
    Duet front loader
  • Official Brand Answer
  • 30 Answers
At the risk of being rude... it's not your washer that is causing the problem it's your washing habits. Jeff is "right on the money" when he stated water temperature is important. It's fine to use mainly cold water but it makes preventive maintenance very important. A hot soak or wash as your last cycle on was day will help dissolve and flush out residue. Just as important is the amount of detergent used and use of fabric softener. To remove odor from your washer and laundry the "splash area" just above the normal waterline must be cleaned. This is invariably the area of heaviest buildup of odor-causing residue. To clean the splash area add 1 or 2 caps of smelly washer cleaner to a full load of laundry and wash in a hot setting. The added bulk of the laundry will raise the water level to include the splash area. Intermittently pause to soak for more extreme cases.
Posted on Dec 09, 2012
    President:
  • Whirlpool Master
  • 662 Answers
A lot of machines can suffer from this problem. It is usually down to a bacteria build up between the drum and the tub. The majority of appliances that suffer form this have been used mainly on 40 degree washes and with a biological detergent.
The best way to get rid of this smell is to place two tablespoons of washing soda or soda crystals in the detergent drawer and then run the appliance empty on the 90 degree wash. You may have to repeat this treatment before the smell goes but it will go eventually. Hope you've checked out & cleaned your filter.
You can give me an excellent rating for the help, can't you? Thanks
Posted on Jun 24, 2012
  • 5,911 Answers
Residual water sits inside the wash tub under the stainless steel basket and in the drain lines & drain pump. This is normal. If you are in the habit of using very few hot water cycles and do not leave the washer door open when not in use, bacteria, mold and mildew can build up and cause the sour smell you are experiencing. The following link provides some good info on how to prevent these odors:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
You may also want to remove the drain pump reservoir and check to see if you have anything caught. Sometimes debris can build up in the drain pump and cause odors. The following link explains how to check the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I personally own a front loader such as yours and have never had a problem with odors by following this simple advice. Occasionally run a sanitary cycle with nothing but bleach in the water. For washers with no santitary cycle, run it on the hottest setting you have. Sorry...front loaders require a bit more TLC than conventional top loaders. I hope this helps you. If you have questions, please let me know.
Posted on Aug 18, 2008
I have a Whirlpool Duet front loading washer with a smelly trap.
It is normal to have water in the drain lines and drain trap even when the unit is not in use. There's usually about a gallon of residual water in the lower portion of the wash tub, drain line and pump. If you are experiencing sour odors from the washer, the following link can give you some pointers on things to try to help keep the smell from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Read through the link provided and let me know if you still have problems. I personally own a front loader and have followed this regiment for 9 years now with no odor or mildew problems. I hope this helps you as well.
Jan 28, 2010 | Whirlpool Washing Machines
I have had my duet for about 5 years. I thought
The problem is commonly caused by debris building up in the drain pump. Over time it sours and begins to smell. The following link explains how to access the drain pump and clean it:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
There are several other factors that can also contribute to front loader odors. The following link explains a things to look for and try:
Read through the information provided and let me know if you have any questions. I hope you find this information helpful.
Jan 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine smells sour and I don't know how to cure it.
I used 2 quartz of Clorox bleach running a full load without clothes. After that the odor has gone for good. Try that.
Oct 05, 2009 | GE WHRE5260E Top Load Washer
Sour odor. Even though I take my clothes out right away.
The problem is that water sets in a filter area below the tub and sours, or smells like raw sewage. This is common on most front loaders, Whirlpool makes special tablets used in washer to take out the odor.
Jul 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
After washing with my whirpool duet my wash smells sour. Any idea?
Try using Affresh washer tablets. This kills the smell in front load washer. You can order this online or at a local parts store. Works great. I use it on all the front load washers that i sell in my store.
Jun 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My towels always smell sour...it doesn't matter what detergent or fabric softener I use. I have the Whirlpool Duet front loading machine and dryer.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer smells!
Did you check for small wet items just inside the door? Push in on the soft gray rubber area right down in front and made certain you don't have something soured down in that area.
Dec 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
426 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
