Question about Microtek ScanMaker i700 Flatbed Scanner
Will not perform "scan to" operation
Message that appears is: "No scan jobs checked." This message has never appeared before and the problem doesn't disappear after quitting the program and restarting the computer.
Under "View" in the "Show scan queue window" I unchecked and then rechecked the check box and that solved the problem.
Posted on Aug 19, 2008
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
Mp navigator 4.3 don't start
On Windows Vista, the following error message may appear while scanning:-
"Cannot communicate with scanner.
Code: 2,155,0 (or Code: 53,3,0)"
In such a case, close the error message and confirm that the cable is connected and the printer is turned on. And then perform a scan over again after a while.
Oct 29, 2011 | Canon Pixma MX360 Printer
,i have my load but it is always says check operator services everytime i try to send a message
If the message "Check Operator Services" appears on the screen of your mobile when you attempt to make a call/sms, you should:
Check if there's a number 2 on the left hand corner of your screen.
If so, press and hold the # (hash) key until you see the message "Change the Phone Line?".
Press OK. The message "Line 1 selected" should then appear and the number 2 will disappear.
Attempt to make a call.
Note: Line 2 is an option on Nokia mobiles that's selected by holding down the hash key and pressing OK. Vodafone doesn't support this feature. You can prevent accidental changing of lines by activating your keypad lock. On some handsets, you can do this by pressing "Menu" then "*" to lock the keypad. "Menu" then "*" will unlock.
May 05, 2011 | Apple iPhone 3G Black Smartphone
My system is showing that you may a victim of counterfeiting
this can be that ur computer might have got virus ....so if u can go online from ur computer then go to filehippo.com and download malware bytes from that site and run a full scan and remove the virus detected u can also clean up ur computer by running disk clean up , disk dfrag and increase the performance of the computer
Jun 24, 2010 | HP Computers & Internet
No response when printing or scanning
You have a bad scanner assy which will cost more to replace than a new printer.
Jul 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have a microtek scanmaker 4900 mpdel. I was scanning a page from a book and cancelled the scan. Now, every time I try and scan something the message "no scan jobs checked!" appears and I...
Try this:
  1. In your ScanWizard Advanced Control Panel, click View
  2. Click Scan Job Window / Scan Job Queue
  3. When the window pops up:
    • If any boxes are checked in the Scan Job Window / Queue, uncheck them, and recheck them.
    • If no boxes are checked in the Scan Job Window / Queue, check them.
  4. Close the Scan Job Window / Queue.
You should be able to scan again without any issues.
Dec 19, 2008 | Office Equipment & Supplies
HP 4350 ERROR MESSAGE: 49.2F90
he printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Drum Full of Waste Toner
Try clearning the NVRAM most cases the drum fill count is baised on a setting and not if its really full.
  1. Press Menu.
  2. Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  3. Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  4. Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  5. The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
  6. Turn off the printer, and then on again.
Nov 16, 2007 | Dell 3000cn Laser Printer
When scan job is sent a start failure error comes on the display
Don't worry about the clean roller message. It is just a reminder much like your scheduled maintenance light that appears in your car.
Start Failure can occur for a number of reasons. When you get a start failure message close your scanning software and reopen it. Sometimes your connection may degrade if left idle. If that doesn't work shut down the scanner and pc. Turn on the scanner and wait until it is fully initialized before turning on the PC. These steps have resolved that problem for me. Lacking a manual, I just try things. Good Luck
May 07, 2007 | Kodak Digital Science 2500D Path-Through...
Microtek ScanMaker i700 Flatbed Scanner Logo
87 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
