Question about McCulloch MC1275 Steam Vacuum
Mc Culloch chain saw
My chain saw will start but does not idle for long and cuts out when I press the trigger. Any ideas?
Stuart K.
  • Stu29kitch Aug 21, 2008
    It is a gas chainsaw.
    Stuart
  • Gayle Ashbach
    Gayle Ashbach May 11, 2010
    Is it electric or gas?
  • 32 Answers
You will need a parts breakdown and exploded views to start with as well as a manual , All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
After that is done then you can see the fuel filter and line inside the tank you will need to replace, take your printed views and manual to the nearby lawn mower shop and they will help you get the parts you need even if the original ones are not available. blow out the carb with chemtool and install the parts, use NEW GAS, NEW OIL and from that day forward never leave fuel in a unit for more than 3 months. Good Luck...
Posted on Feb 19, 2009
  • 876 Answers
It could be a plugged or "gooey" carburetor or the fuel filter in the tank could be bad. At any rate, It is not getting enough fuel. Since most of Mcculloch parts are no longer available, you will most likely be looking for used parts. Here is a site that has some parts, whether for your exact saw or not, you'll need to look. If you can find a chainsaw service center (you'll probably have the mos tluck witha smaller business) you could find out exactly what you need and then look for the parts yourself. There may be other sites online for used or even new parts that someone still has on hands.
http://www.mfgsupply.com/ChainsawCarbMc.html
Good Luck to you and thank you for using Fix YA. Please rate my solution.
Posted on Aug 21, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 21, 2008
    Here is a site where you can download a manual for Mcculloch Chainsaws: When you get to this site a video will be loading, however such open the tab above it marked download and right click on the type you want (I prefer txt) now click on "save target as" to begin the download. Eventually it should as you where to save it and you can either save it to the Desktop or to a folder anywhere on your hard drive. (C). I just thought this might be good for you to have.
    http://www.scribd.com/doc/3097717/CHAINS...
Water dispenses without pulling trigger. How to stop it?
you should have a lever which controls this spray slid it all to one side then the other sometimes its just trial and error if this doesn't work then see if it has a cut of valve if so it may be broken
Apr 10, 2014 | Hoover F7225-900 SteamVac V2 Upright...
Trigger switch cuts off during use
make sure the filter is washed thoroughly. I have/had the same problem and washing the filter helps a lot - it cuts off if overheating....and avoid picking up really fine dust like after drilling picture hook holes...
Feb 02, 2013 | Dyson DC34 Bagless Cordless Hand Vac -...
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
Can you put an 18 in. bar and chain on a poulan 2055 14 in ?
Have you considered a rental? Home Depot rents Makitas (Dolmar) with a 20" bar reasonably. Be warned running a Dolmar/Makita will make you question the value of your Poulan LOL. HTH
Lou
Dec 07, 2009 | Vacuums
My eager ****** chain saw will not stay running ?
The 3 adjustment screws are Idle, high and low.
First figure out which screws are which adjustment. Tighten the screws then turn them 1 full turn.
Then start the saw and get it warmed up. Work on the high adjustment. This does take a little while. after you get the saw running at high speed work on the low speed.
Apr 25, 2009 | McCulloch MC1275 Steam Vacuum
Parts for Mcculloch MC 1275 steam cleaner
You can find your parts on amazon. take a look here Amazon com Mcculloch MC 1275 parts. I hope this was helpful. cheers
Nov 15, 2008 | McCulloch MC1275 Steam Vacuum
Chain saw starts runs, bur saw won't start next time it is needed, craftsman chain saw
Steam vacuum? no clue but on your chain saw make sure you check the choke. it would explain why it wouldn't start again.
Sep 27, 2008 | McCulloch MC1275 Steam Vacuum
Trigger not working correctly
You might need to de-scale the unit to free the stuck valve.
Keep the unit unplugged.
Fill the unit with a vingar and water (filtered or distilled is best).
Screw the cap back on and place the unit in a sink upside down to allow the vingar and water to reach the valve.
After a few minutes press down the trigger several time to work the solution into the valve.
Hope this helps.
Sep 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Mcculloch chainsaw 2416
Aug 03, 2008 | McCulloch MC1275 Steam Vacuum
McCulloch Chain Saw Manual
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
Jan 14, 2008 | McCulloch MC1275 Steam Vacuum
McCulloch MC1275 Steam Vacuum Logo
937 people viewed this question
Top McCulloch Vacuums Experts
JoeVacs
Are you a McCulloch Vacuum Expert? Answer questions, earn points and help others
