Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Loud ratchet sound - coffee tamping problem perhaps -
The sound abated for a couple of days - sadly yesterday it strted again and ended with a series of electrical pops - sparks and smoke - what can I do with this machine ?
  • 515 Answers
I think you have a leakage in your machine, it can also be your printed circuit card there is a short circuit.
Try to take off the top and look inside the machine.
/Mirran
Posted on Aug 18, 2008
SOURCE:
I can't brew coffee, when machine is turned on it makes a loud noise like endless spinning. sounds like it is coming from the brew/tamping area
foreign element perhaps the grinder is bad though. First try using a small vacuum that will allow adequate control of vacumming up the bean container. remove all the beans etc. the bean container must be emptied. then look at what the vacuum removed, any foreign objects? if you see 1 or more it's likely fixed. otherwise remove any inside cover/guides in the bean container you should now look directly at the grinder wheels with flashlight, as there may instead be a foreign substance or a defect preventing the grinder from processing the beans. if a defect then it may require factory service. gl
May 28, 2015 | Jura Capresso Impressa Z5 Espresso/Coffee...
Hi there. problem with my La pavoni PL-16. No coffee comes out. The vapour its ok, it comes out but from the place the coffee should comes out, it doesnt. With or without the the filter holder. Whats...
Hi if there is Vapor coming from the grouphead when the lever is down then I would guess there is a problem with the seals around the piston and possibly elsewhere. Here is a link to a goos site that looks at repairing La Pavoni lever machines. Good luck.
DIY
dr pavoni
May 29, 2014 | La Pavoni Lusso PL-16 Espresso Machine
Lesson
Hi I have one of these and I know it is frustrating at first. There is quite a lot out there on the net about \'pulling a great shot\' some of it conflicting some of it intensely obsessive.
So here is one I found useful
http://coffeegeek.com/proreviews/detailed/pavoniprofessional/operation
I will also try to tell you what I believe will help you get going.
Number one buy decent coffee.
Like all espresso makers it the combination of grind and tamp that will lead to a good shot, this is especially true with the La Pavoni.
You must grid your own beans for this machine, or at a push if you buy from a roasting house get them to do a selection of different (fine espresso) grinds for you, mark the packs and try them all and select the best. Here in the UK coffee sold pre-ground is just to course for this machine.
So if you are grinding your own you need to experiment and every time you buy new beans you will notice you have to do it again to calibrate the grind.
A grind will be to course or the tamp to light if the coffee flows to easily and takes less than about12-15 seconds with a relativity moderate pressure on the handle again this is something you need to get a feel for. you really don\'t want to be straining to pull the shot as this means the grind is to fine or the tamp is to hard, so it is possible to have a good grind coupled with a wrong tamp.
I tend to use just two finger to pull down on the handle this way I can feel more easily how the flow is going I also have a look at the coffee coming out of the spout when you have it just right the flow kind of bends at the top rather than going straight. Also it can be quite easy to damage the machine but pulling too hard on the handle.
If you find that you are pulling down for to long and nothing or next to nothing is coming out then the grind is to fine or the tamp is to hard or both. I think in general I would try adjusting your tamp first before changing the grind.
I suggest experimentation and stick with it, it really is worth it when you start to pull great coffee shots.
Also look out for overheating the brew-head this can lead to a bad taste it can get to hot after pulling 4 or 5 shots try wrapping a damp cloth round it for a while to bring the temp back down.
So I am sorry if I have rambled on a bit but there are no hard and fast rules here.
All the best
Pierssy
May 05, 2014 | La Pavoni Coffee Makers & Espresso...
We have a sunbeam cafe series coffee machine that is 2 years old but suddenly under extracts on the pour and cannot reach the extraction pressure we are used to. We grind our own beans as well.
Generally, this is not a problem with the machine but with how you're loading the coffee! Sounds typical of one of these problems:-
Not enough coffee in the basket
Coffee should be filled and tamped to about 3mm below the rim.
Coffee grind not fine enough (too coarse)
Do you grind your own coffee or buy ready-ground? If buying ready-ground, make sure it is for espresso (fine) and not for filter or plunger.
If you have your own grinder, (like the Sunbeam Conical Grinder), then make sure the coffee hopper on top is securely connected to the grinder. I'd been using mine for years on the the finest grind (1) not realising the hopper wan't on right. Only discovered it when I took it apart to clean. Now my grinder is on 9-10 to grind for espresso.
Coffee not tampered down hard enough
You do need to provide a reasonable degree of pressure to tamp the coffee down just right.
Group head not turned tight enough
Push the group handle as far to the right as it will go, then ease it back just a fraction to have the right pressure.
Dec 15, 2012 | Sunbeam Cafe EM6910
After successfully using the machine I tried to make a second coffee. Water continually poured into the tray and the machine sounded very loud (as if it was starting up). I then tried to shut down the...
The coffee grind is too fine, or you are tamping too hard, First remove the portafilter and press the brew button if water flows move on if not remove the shower and clean. Now that we have a nice flow of water without the portafilter. Now we will add coffee to the portafilter, and level it out, do not tamp and try to run a coffee, if that works then the Tamp is the problem, if you tamp and still have the problem then the grind is too fine.
Jan 02, 2011 | Breville BES820 Espresso Machine
Pump makes strange staccato sound at 1 second intervals. A little coffee dribbles out. Then it just shuts itself off. Seems to be a pressure problem?
Check the grind on the coffee or the packing pressure used to tamp. If it flows great without coffee in the portafilter, then the problem is the grind or tamp. The grind might be too fine that the pump has to use so much pressure that the relief valve open and most of the water goes into the drain tray.
Jun 28, 2009 | Krups XP 4000 Espresso Machine
New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
May 10, 2009 | Cuisinart EM-200 Espresso Machine
Silvia
there are two class of expresso coffée: one produce crema and the other none. A 9 sec shot, means you are putting ground coffee that are way too coarse. The Silvia requires coffee grounf extremely fine, near powder texture.
Hope this help
Dec 28, 2007 | Rancilio SILVIAespresso&cappuccino machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
97 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
