Question about Motorola Cell Phones
Phone does not turn on. key pad lights up but no other functions or screen. batt is new and works on other phone.
    Brigadier General:
  • 7,752 Answers
Replace the flexcable in the phone
Posted on Aug 18, 2008
SOURCE:
Seems like the car is staying in "ACC" (accesory key position)
BFC that body function controller. BFC batt fuse controls .the body function controller .its part of the PCM.the BFC controls anti theft system. your interior lights -drl lights- radio -door locks.if your check engine light is on take it to dealership.because your BFC and PCM works together. your car could shut off. that unsafe.when you on a busy highway.you have electrical problem.not a home fix.
Jun 27, 2009 | 1999 Oldsmobile Alero
My display screen is black, but I can recieve calls and the key pad lights up
my display is nt working bt the other functions is used.plz help
Apr 25, 2009 | LG Shine KE970 Cellular Phone
Iphone has a problem
Hi Bob. If your touch screen is fully functional on other areas or pages, I would restore the firmware. Should take care of that prob. If it is not responding at all, then you would probably be looking at replacing your digitizer.
Jan 29, 2009 | Apple iPhone Smartphone
AVH -P5900DVD /CD-BTB200 Bluetooth Connection
are u power to a full time batt voltage or just to acc voltage. need to be connected to full time batt voltage!
Oct 03, 2008 | Casio G''zOne Type S Cellular Phone
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
RAZOR V3
HAS IT BEEN WET? IF SO OPEN BATTERY DOOR AND REMOVE BATTERY THEN POUR RUBING ALCOHOL NOTE MUCH THEN VACUME NOW PLACE IT UNDER POWERFUL FAN OVER NITE.TRUST ME IT WORK'S...
Feb 01, 2008 | Motorola Mobility RAZR V3
Phone will not turn on
hi you say the key pad lights up but does it light up after a couple of minutes like when you press a key if this is the case and the keypad is functional and lights up when you press keypad if this is the case then the chances are that the screen hasnt been fitted properly.
did you purchase phone from shop or somewhere else if its new cant you exchange it the chances are if you didnt buy from reputible deler then the chances are they sold you a phone that should have never gone on sale.
As i used to work in a major mobile phone producer the phones are all tested before being shipped out.
The chances are the screen needs removing and replacing this is difficult to do yourself as the screws need to be undone in certain order and the same back together if not you can warp the board and destroy the phone completely.
if you want to try this yourself use a good search engine and look for the instructions on how to take phone apart but you need to earth yourslef out before doing this as the static in your bady can blow the chips on the board it is best left to a pro if you are unsure hope this is some help let me nkow what you want to do
Jan 03, 2008 | Motorola Mobility RAZR V3
V3i Problems
you need to have the flex cable replaced
Dec 30, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Won't turn on after assembly
dear first check the the power volts are comming in ur on of key. if not comming check key pad strips. mostly it prob from key pad may be it is not good connected to board or damage during assembling. first unplug it and then re connect
Mar 23, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
21 people viewed this question
Top Motorola Cell Phones Experts
Ekse
Damen Wong
Damen Wong
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
