Question about Insignia D300a PC Desktop
Computer will not shut down
my computer will not shut down, it seems to lock up when I hit the shut down
I performed an internal diagnostics and it locked up at 80% complete
  • 876 Answers
Update and run your virus control scan
Run a registry cleanup if you have a program for that
Go to toolbar>tools>internet options>general tab and delete all
cookies
Go to start>all programs>accessories>system tools >clean disc
If you have a separate spyware program ,scan for spyware
How many programs do you hae running in the background?Look at the lower right corner and the little icons there. Turn off anything unneccessary (leave your virus control and spyware control on)
After you have completed all this, get back to me if your computer still will not shutdown or restart.
Does it have an on and off switch? You may have to use it, but you may lose things, so do all of the above and get back to me?
Posted on Aug 18, 2008
SOURCE:
General International General Woodworking Machinery 80-300 M1 12 parts
That lock knob should be available through General. I see them having stock so should be easy!
Quote your machine modle and ser #
Feb 05, 2014 | General International General Woodworking...
HP Printer Reset
Resetting the printer can resolve several issues that may emerge. All the steps in the two sections below must be followed completely and in order for these resets to work. Performing a soft reset A soft reset, also known as an Electrical reset, can be used to restore the printer to a ready condition when a cartridge, paper, or other printing issues occur. This reset method should be used for the HP Photosmart 100, 130, 145, 230 and 245 printers. Perform a hard reset for all other HP Photosmart printer models.
  1. Disconnect any USB cables attached to the printer and remove any memory cards from drive bay.
  2. Restart the computer.
  3. Unlock the ink cartridge locking clips.
  4. Remove all ink cartridges.
  5. Lock down the ink cartridge locking clips.
  6. Close the main printer door
  7. Turn the printer off with the Power button and wait for the printer to shut down before proceeding to step 8.
  8. Unplug the printer AC adapter from the printer and the wall outlet or surge protector.
    NOTE: The adapter itself has an overload trip that may need resetting, but will not reset if power is flowing to it.
  9. Wait approximately fifteen to forty-five seconds to allow all current to dissipate from printer.
  10. Re-plug only the AC adapter into the wall outlet then into the printer, but do not plug in the USB cable.
  11. Wait for the appropriate missing ink cartridge error to verify that printer can recognize this error.
  12. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page.
  13. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections.
  14. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer.
  15. Test for printer functionality.
Performing a hard reset A hard, or mechanical, reset is performed when the printer is in a condition where its normal printing process is interrupted. Examples include a paper jam, carriage stall, or mechanical noise. To perform a mechanical hard reset, follow the steps below.
  3. Remove any paper from the paper tray.
  4. Unlock the ink cartridge locking clips.
  5. Remove all printer ink cartridges.
  6. Lock down the ink cartridge locking clips.
  7. Close the main printer door.
  8. Turn off the printer using the power button and wait for the printer to shut down before proceeding to step 9.
  9. Unplug the power from the back of the printer.
  10. Unplug the power adapter from the wall outlet.
  11. Remove the rear access door.
    NOTE: The clutch is located in the same place as pictured above in Figure 1, however, you must access it from the left, just above the paper output tray.
  13. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  14. Release the clutch and roll the wheels up two more rotations.
  15. Locate and then roll the internal rollers in an upward direction until a clicking sound is heard.
  16. Reinstall and lock the rear access door.
  17. Connect the power adapter to a wall outlet.
  18. Reconnect the power cable to the printer.
  19. Turn the printer on.
  20. Re-insert the paper into the input tray.
  21. Wait for the appropriate missing cartridge error to verify that the printer recognizes this error.
  22. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page.
  23. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections.
  24. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer.
  25. Test for printer functionality.
Goodluck,
And please don't forget to rate me as fixya..
Feb 02, 2008 | Office Equipment & Supplies
Holding down the Func key while powering up, Num lock and Scroll lock flash, caps lock on steady. No Post. Help
If your laptop won't run the diagnostics ( Holding down the Func key while powering up ) then you need to try and isolate the problem. Something is preventing the laptop from performing POST ( power-on self diagnostics ). Try removing the hard disk drive, memory modules, external USB devices.
Sep 06, 2011 | Dell Precision M6300 Notebook
All the lights are flashing. I have put in a new cartridge, unplugged and turned off the machine, I cleaned it with the air duster. It will not work
Try the following tricks:
Disconnect any USB cables attached to the printer and remove any memory cards from drive bay. Restart the computer. Unlock the ink cartridge locking clips. Remove all ink cartridges. Lock down the ink cartridge locking clips. Close the main printer door Turn the printer off with the Power button and wait for the printer to shut down. Unplug the printer AC adapter from the printer and the wall outlet or surge protector. Wait approximately fifteen to forty-five seconds to allow all current to dissipate from printer. Re-plug only the AC adapter into the wall outlet then into the printer, but do not plug in the USB cable. Wait for the appropriate missing ink cartridge error to verify that printer can recognize this error. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer. Good luck. Thanks for using FixYa.
Jun 01, 2010 | HP LaserJet 1012 Printer
The color is off when I print with my HP 3210 printer. It prints brighter and darker than the original photo. How do I reset it ?
erforming a soft resetA soft reset, also known as an Electrical reset, can be used to restore the printer to a ready condition when a cartridge, paper, or other printing issues occur. This reset method should be used for the HP Photosmart 100, 130, 145, 230 and 245 printers. Perform a hard reset for all other HP Photosmart printer models.
Performing a hard resetA hard, or mechanical, reset is performed when the printer is in a condition where its normal printing process is interrupted. Examples include a paper jam, carriage stall, or mechanical noise. To perform a mechanical hard reset, follow the steps below.
Mar 05, 2010 | HP Photosmart 3210 All-In-One InkJet...
Im having trouble with my transmission for a 1996 Chrysler Intrid
sounds like you have a speed limiter fitted, the locking up what do you mean by locking up if the ABS is locking up seek a garage
Jun 06, 2009 | 1997 Dodge Intrepid
NP9890 shut down
If it is an overheating problem try turning the laptop off, turning it over and placing a vacum on the fan grill on the bottom. Many laptops get a dirt buildup internally and this will sometimes suck out the dirt.
Jul 29, 2007 | Sager NP9890 Notebook
Insignia D300a PC Desktop Logo
65 people viewed this question
Top Insignia Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Joaquim Martins
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
