Question about Apple Mac OS X 10.4
OS X 10.4.10 Stuck Loop
Hi, I installed Avid Free on my OS X 10.4.10 the results of this were catastrophic, my mac got into a loop, it would get to the icons on desktop and then go back to black.
What to do? Is there a problem with the avid or the 10.4.10 operating system?
Thank you.
    Scholar:
  • 38 Answers
H MerryAnn
I run Avid on my mac and have not experienced what you describe. Avid uses a lot of memory. The first thing I'd look at is do you have enough memory to run the OS and Avid. If that is OK check your screen res' (the system normally warns you if that is incorrect) If you have the install software try uninstalling and re-install to see if that helps.
It does not sound like a OS problem.
Regards
Paul
Posted on Sep 03, 2008
SOURCE:
Computer won't start. Message keeps saying " attempting to restore Windows" but seems to be in a loop. What can I do
I hope this will help
Method 1. Reset your Windows 10 PC
Navigate Start > Settings > Update and Security > Recovery > Reset this PC.
Then Hit on the Get Started button just below the option to fix Windows 10 'Restoring your previous version of windows' stuck issue. During the process, select Keep my files option will allows you to keep all your personal data safe.
Method 2. Perform a System Restore or Startup Repair
1. Download Windows 10 media creation tool and create a Windows 10 installation media.
2. Boot or start your computer from the Windows 10 installation media.
2. In the Install Windows page, tap 'Repair your computer' to start the Windows Recovery Environment.
3. In the Windows Recovery Environment, on the Choose an option screen, click 'Troubleshoot'.
4. Click 'Advanced Options' and then click on 'System Restore' or 'Startup Repair'.
Then follow the on-screen instructions to fix Windows 10 'Restoring your previous version of windows' stuck or loop and restore the computer to an earlier state successfully.
Method 3. Clean install Windows 10 with ISO image
If none of the above methods is helpful, you can try to reinstall Windows 10 with ISO image file. Just download Windows 10 media creation tool. Try it to download Windows 10 ISO image file and burned it to bootable DVD or USB flash drive. And then clean install Windows 10 on your PC. It has helped most users to fix Windows 10 stuck at 'Restoring your previous version of windows' loop.
Method 4. Restore Windows 10 using previous backup image
The above methods are all the possible free solutions from Windows 10 settings to fix Windows 10 stuck at 'Restoring your previous version of windows' loop. Actually, at most times, they might not help due to certain reasons. So we strongly recommend you to backup Windows 10 system with EaseUS Windows backup software. It can help you easily and quickly restore your system from the backup image without losing anything when a disaster happens unexpectedly.
Feb 08, 2018 | Computers & Internet
How do I fix a rooted LG Optimus Fuel stuck on LG splash screen loop
Hi there.
Usually a Splash Screen loop indicates that the Phone's Software / OS is corrupt and therefore will not boot.
I recommend having the device reverted back to Stock. It is likely that the Root firmware was not compatible or the Flash process was done incorrectly.
Jan 13, 2016 | LG Cell Phones
How do I fix a next book tablet that's stuck in a repair loop?
You didn't say what is the OS but when you encounter this situation it is hard disk. I suggest rescuing data first. If you know about computers you can take the disk out, mount it in another computer, rescue data. Buy another disk and install OS and data after that. If you don't know how to do this take it to a shop.
Oct 10, 2015 | Computers & Internet
Boot loop
try pressing the power button and holding it for 10 seconds. Then wait a while. Turn it back on, you may press F12 or other key when the Samsung Logo appears (before Windows Logo) to see the boot options. Choose the one to check for any errors or anything else - Run diagnostics. Then also you may scan your hard drive for any failures.
Jun 04, 2013 | Samsung NF210-A02 Netbook
What is routing loop?
A routing loop is a condition in which a packet is continuously transmitted within a series of routers without ever reaching its intended destination network. A routing loop can occur when two or more routers have routing information that incorrectly indicates that a valid path to an unreachable destination exists.
The loop may be a result of:
Incorrectly configured static routes
Incorrectly configured route redistribution (redistribution is a process of handing the routing information from one routing protocol to another routing protocol and is discussed in CCNP-level courses)
Inconsistent routing tables not being updated due to slow convergence in a changing network
Incorrectly configured or installed discard routes
Jun 07, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
Says my system is not suported
These are the system requirements for the M-Audio Fast Track USB input. Be sure that you meet these requirements, or else upgrade your system to meet them.
MINIMUM SYSTEM REQUIREMENTS-FAST TRACK HARDWARE Windows
  • OS: Windows Vista 32/64 or Windows XP (SP3) Home or Professional
  • CPU: Pentium 4 2.0GHz, 1 GB RAM, 1 native USB port
Mac
  • OS: OS X 10.4.11
  • CPU: G4 (native), 1 GB RAM, 1 native USB port
MINIMUM SYSTEM REQUIREMENTS-PRO TOOLS M-POWERED ESSENTIAL HARDWARE Windows
  • CPU: 1.8GHz multi-core (Intel or AMD), 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mac
  • OS: OS X 10.5.5 or greater
  • CPU: 1.8GHz Intel multi-core, 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mar 11, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
Wanted to install a MacOS X... can it work???
Mac OS X won't run on your pc... you can however run windows on a mac now... the latest generations of macs will allow you to run both systems... pretty cool .. sorry it won't work the other way...
May 28, 2009 | HP Compaq 6720s Notebook
10.4 tiger stuck on install
Hi, Sorry to hear you are having problems,
YES, Yes there is a way to get out of that loop.
  1. Shut down your Mac by holding down the power on button for 5 seconds or so..
  2. Power on your Mac and VERY QUICKLY press down on the mouse button and hold it down until your CD ejects.
  3. Now, insert your Disk 1 and reboot the Mac on this installer disk and don't forget to choose option 2 disks only...
  4. Voila!
Mar 30, 2009 | Apple Mac OS X 10.4
How to install driver of HANTEL USB Modem on vista operating system
I have a Garuda phone (CDMA-2000 1X Wireless Local loop Phone HTP-801). I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. Please help me and told me about how i can install it on vista os
Apr 15, 2008 | Computers & Internet
Open Questions:
See all Apple Mac OS X 10.4 Questions
Apple Mac OS X 10.4 Logo
109 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
