Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader washer
Hello-
I have a smell inside my front loader. I checked to make sure there wasn't a soggy item inside the rubber door seal. Its a sour smell. Any suggestions on getting ride of it?
  • bjwg Aug 19, 2008
    I have the same problem. Where is it coming from and how do you solve (clean) it?
  • Official Brand Answer
  • 30 Answers
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Posted on Dec 09, 2012
My washer also smells. I cleaned behind the door seal with bleach but it still stinks. Also ran vinegar through the cycle. When looking closer, I can feel a slime on the outside of the drum but can figure out how to get to it. I am sure that is contributing to the smell. Has anyone else noticed this and if so, what can I do?
Posted on Aug 18, 2008
Smell of mildew in washer
They make products to eliminate this mildew, check at the store.
Aug 30, 2017 | Washing Machines
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello - I have a Bosch Classixx 1400 and it smells bad! What may be causing this? I have emptied the black tube with water in adn I have unscrewed the plug on the right and water came out of here but the...
Hi.
The smell will be coming from inside the drum as you summised.
It is probably caused by the drain in need of cleaning, or more likely a build up of dirt and scum on the door seal cased by doing too many low temperature washes.
Check the seal carefully and if it is stained black, then the only real solution is to replace the seal, and do more high temperature washes
Jan 16, 2011 | Bosch Washing Machines
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
The odor is terrible. Running the recommended
The filter is actually the drain pump trap. The following link explains how to access and clean the drain pump:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
You also may have to remove the drain hose that runs from the bottom of the wash tub to the inlet side of the drain pump to ensure it is free of debris as well. Small articles of clothing can commonly get lodged in this area and sour.
Make sure you also check the door bellow (gray rubber door seal) to ensure there is nothing caught in the rubber folds of the seal. Pull the rubber back and check the entire perimeter of the door. It is common for small items such as socks to get stuck in this area. If left for any significant period of time, they begin to sour and mildew. It is recommended that you check this area after each wash. I once found 17 socks stuck in the door seal that the owner did not know was there. They had been there for months. You can imagine what the odor was like at that point.
Last of all, leave the door open between washes to allow the wash tub to air out. Due to the water tight and air tight nature of these door seals, when closed no air can escape the tub and any residual water that remains in the drain lines will sour.
If you have any questions, please let me know. I hope this help you.
Nov 26, 2009 | Kenmore Elite 45986 Front Load Washer
Motor has load poping noise on front end load washer
If it is a front loader, reach just inside in the drum. Pull the rubber boot up and fell to see if something has gotten between the drum and the rubber boot, maybe a lighter.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Strong mildew odor in Duet washer
are you useing he detergent? if not this is your problem the washer cannot get ride of the soap so what it does is leave a layer of film in your washer and odor causeing bacteria forms in it. There is a product called AFFRESH you can buy it at SEARS it is made specifically for this. Do you leave the door open ragularly? The reason I am asking is because your washer is like your bathroom if you do not ventilate it properly it will grow mold and it needs to be cleaned. By leaving the door closed all the time it is very easy for the bacteria to grow.
So my advice is to leave the door open, make sure you are useing the correct soap (HE) high efficiancy soap, clean the washer with no clothes hot water and bleach and use the affresh or washer magic. Since you can smell the smell you are going to have to keep cleaning it abouit 2-3 times a month till it goes away. Then once a month. This is not a machanical problem or a whirlpool problem and is very commen in ALL front loader if you do not clean it regularly.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tub has a sour smell &does not seem to be rinsing soap out of clothes
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 29, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
307 people viewed this question
Dan Webster
Dan Webster
Sal De
