Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Running continuously I have a FFU20FC6AW2 freezer that I have noticed is running continuously. Explains my $400 electric bill. Any ideas? Thanks, Ed
  • Anonymous Aug 21, 2008
    freezer keeps runing
  • Anonymous Oct 22, 2008
    same
  • 750 Answers
Hello bxrjer,
Welcome,
You said, you have a FFU20FC6AW2 freezer that I have noticed is running continuously. Explains my $400 electric bill.
How old is the freezer?
The thermostat may be faulty.
But check out this list first.
If the black tubes running back and forth that carry the freon is under the freezer and behind the plastic grill down near the floor you may want to remove the grill cover and gently run a refrigerator brush across the coils. Ive seen them never cleaned and full of lint and dust 2 inches thick.
This is not good for the freezer or any refrigerator too!
They need to be clean so air can run across them or they over heat and get hot.
Room or outside weather is hot. It is normal for the freezer to work harder under these
conditions.
Reasons why Freezer may run too much or too long.
1.Freezer had recently been disconnected for a period of time. Freezer requires 4 hours to cool
down completely.
2.Large amounts of warm or hot food have been stored recently. Warm food will cause the
freezer to run more until the desired temperature is reached.
3.Door is kept open too long or too frequently. Warm air enters the freezer every time the door
is opened. Open the door less often.
4.Freezer door may be slightly open. (Freezer is not level. It rocks on the floor when it is moved slightly. This condition can force the cabinet out of square and misaligned the door.Freezer needs to be leveled if this occurs.
Floor is uneven or weak. Freezer rocks on the floor when it is moved slightly. Level the floor by using metal or wood shims under the freezer or brace floor supporting the freezer.
5.Temperature control is set too cold. Turn the control knob to a warmer setting. Allow several
hours for the temperature to stabilize.
6.Freezer gasket is dirty, worn, cracked, or poorly fitted. Clean or change gasket. Leaks in the
door seal will cause freezer to run longer in order to maintain desired temperature.
Let me know what you find
Huuum
Please remember to leave a rating before you leave.
Posted on Oct 05, 2008
SOURCE:
Freezer seems to run all the time.
Good Morning Linda, this is Z. I appreciate your post!
I understand your Frigidaire freezer seems to continuously running. Unlike older freezer that turned off and on frequently, newer models save energy from having to start up and shut off repeatedly. For example, diesel-powered trucks conserve fuel and energy and therefore have less engine wear and tear by keeping the motor running; much like newer energy efficient refrigerators/freezer. If the compressor is running on a more constant basis; it is maintaining the temperature within your freezer, rather than having to cut off and start again to adjust the temperature.
I hope this information explains why your freezer runs more often. However, should you feel that a service technician is needed; you may visit the manufacturer website to find a provider in your area that will look at your freezer.
Best regards!
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
Freezer is making rumbleing noise!
You have an abnormal compressor on running. Unfortunately , it is hard to repair this compressor. People usually replace the compressor rather than get it repaired. Prolonged this situation will increase your electricity bill.
Sep 02, 2010 | Maytag Freezers
What temp should freezer be set on in a hot garage?
commercial refrigerators are required to be set to 23 % a home unti shold not be less than 27% and thats for food being frozen to last 6 months.
Jun 28, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Continuously running freezer
Hi, The picture I get shows the temp control in the uppr left hand corner. It should be set to half of whatever is on the dial.
I had about eight different possiblities on model #. Could I get the whole # and look this up again?
May 31, 2009 | Frigidaire 19.53 cu. ft. Commercial...
Freezer runs continually
Hello jyount130960
Welcome
This is a bad thermostat that if not repaired will cause the compressor to burn out prematurely.
You should service it right away!
Thank you,
for using Fix ya.
Please remember to leave a solved rating before you sign out!
Dec 22, 2008 | Freezers
Broke down after 3 years!! Any ideas on what wrong and how to fix it?
Hi Bill,
You will not like this repair at all. It is cheap and easy but usually really gross. So hold your nose and read on.
This time of year we have little visitors in our garages that like to find a warm place to cuddle up. They will crawl into the back of your freezer and find your warm compressor and start looking for places to build a house. While walking around they will eventually walk directly into the condensor fan and and usually they will not die, they will just be stuck in the fan blades. The heat that begins to build up will slowly cook the little critter and you will get a foul smell for a couple of days. Then you will notice the freezer has stopped cooling well. To repair simply remove the rat from the condensor fan and you got it fixed. In some cases the fan can burn out from the jam so you may need to replace it. I always hate to do this job, it is easy but who likes to handle a cooked rat??? Grossss.. Please dont forget to rate me and try to have a nice day.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezer always on
If the display reads -20 even though the freezer is set for 00, shut the unit off. If you can still hear the freezer compressor running, the board has a stuck relay for the freezer compressor. You will need a new board.
Jan 20, 2008 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
603 people viewed this question
Top Frigidaire Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
