Toshiba Cinema seriers TV turns off automatically and won't turn back on unless you unplug it. Red light (on and off light) will flash (until unplugged).
  • kbrebs Aug 18, 2008
    Is this something that I can repair myself or only by a
    technician, do you have an idea on the estimate to fix this? TV picture still works great!
  • 2,920 Answers
Your power supply is getting weak
Posted on Aug 18, 2008
  • Ronnie Houston Aug 18, 2008
    200 to 300 maybe it depends on the cost to do the work and replacement of the board
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
TP61H95 Toshiba Cinema Series 61" The Image rolls
defintly the convergance.if the con is on a small board ,maybe 130 big board 250&up.if u know how to solder 35$ each STK and u need 2. and check each internal fuse with a ohm meter with tv power unplugged
Mar 12, 2009 | Toshiba TP61H95 61" Rear Projection...
36" 36a50 tv won't turn on
My 36A50 suddenly shuts off losing audio and video. The red light on the on/off switch continues flashing until the set is unplugged.
Jul 16, 2008 | Toshiba 36A50 36" TV
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 55" 55H70 model. Turns OFF, but won't turn ON until I unplug it from the wall first.
sounds like loose connections on the convergance amps ic's
Aug 22, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
TV is not powering up and red light keeps flashing
I had the same red blinking led problem on my Toshiba Theaterview tv. I resolved by:
- Unplugging the tv.
- Press several times (3 or 4 times) the tv Power button.
- Plug the tv back in and press the Power button once to turn the tv worked!!!
I've had the problem before and tried unplugging the tv for a couple of days and that had also worked, but I this recent solution seems to be faster.
Jul 29, 2006 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
