Question about Car Audio & Video
I installed my in dash my self but i dont know how to bypass the e brake screen?
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 19, 2008
No picture on my a Pyle PLDN74BTI
bypass parking brake w/no switch codes
Oct 06, 2012 | Pyle PLDN74BTI Car Video Player
How to bypass e brake with no remote
The remote has nothing to do with bypassing the e-brake. Not to mention the fact that it is illegal anyway.
May 07, 2011 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
How to adjust clutch pedal on 86 mustang lx
clutch is supposed to be self adjusting. Here are instructions for replacing the adjuster:
REMOVAL & INSTALLATION
See Figure 1
  1. Disconnect the battery cable from the negative terminal of the battery.
  2. Remove the steering wheel using a steering wheel puller, Tool T67L-3600-A or equivalent.
  3. Remove the lower dash panel section to the left of the steering column.
  4. Remove the shrouds from the steering column.
  5. Disconnect the brake lamp switch and the master cylinder pushrod from the brake pedal.
  6. Rotate the clutch quadrant forward and unhook the clutch cable from the quadrant. Allow the quadrant to slowly swing rearward.
  7. Remove the bolt holding the brake pedal support bracket lateral brace to the left side of the vehicle.
  8. Disconnect all electrical connectors from the steering column.
  9. Remove the 4 nuts that hold the steering column to the brake pedal support bracket and lower the steering column to the floor.
  10. Remove the 4 booster nuts that hold the brake pedal support bracket to the dash panel.
  11. Remove the bolt that holds the brake pedal support bracket to the underside of the instrument panel, and remove the brake pedal support bracket assembly from the vehicle.
  12. Remove the clutch pedal shaft nut and the clutch pedal, as outlined above.
  13. Slide the self-adjusting mechanism out of the brake pedal support bracket.
  14. Examine the self-adjusting mechanism shaft bushings on either side of the brake pedal support bracket, and replace if worn.
To install:
  1. Lubricate the self-adjusting mechanism shaft with motor oil and install the mechanism into the brake pedal support bracket.
  2. Position the quadrant towards the top of the vehicle. Align the flats on the shaft with the flats in the clutch pedal assembly, and install the retaining nuts. Tighten to 32-50 ft. lbs. (43-67 Nm).
  3. Position the brake pedal support bracket assembly beneath the instrument panel, aligning the four holes with the studs in the dash panel. Install the four nuts loosely.
  4. Install the bolt through the support bracket and into the instrument panel. Tighten to 13-25 ft. lbs. (18-34 Nm).
  5. Tighten the four booster nuts that hold the brake pedal support bracket to the dash panel to 13-25 ft. lbs. (18-34 Nm).
  6. Connect the brake lamp switch and the master cylinder pushrod to the brake pedal.
  7. Attach the clutch cable to the quadrant.
  8. Position the steering column onto the four studs in the support bracket and start the four nuts.
  9. Connect the steering column electrical connectors.
  10. Install the steering column shrouds.
  11. Install the brake pedal support lateral brace.
  12. Tighten the steering column attaching nuts to 20-37 ft. lbs. (27-50 Nm).
  13. Install the lower dash panel section.
  14. Install the steering wheel.
  15. Connect the battery cable to the negative terminal on the battery.
  16. Check the steering column for proper operation.
  17. Depress the clutch pedal several times to adjust the cable.
Sep 24, 2010 | Ford Mustang Cars & Trucks
How do i get my movies to show on my dvd/cd player in my car. say something about the brakes.
Depending on what DVD/navigation system you have, it may be wired to only play movies while the parking brake is engaged.
I have an after-market Pioneer AVIC-9DVD Nav system, and that's the "default" means of operation. My screen is in-dash. Some places can install a a bypass switch, but that ultimately introduces a safety risk.
In situations where the screens are mounted in the rear of the vehicle only, it should be okay. I'm guessing you have a factory-installed setup where the screen is in the front with the driver.
Jan 27, 2010 | Car Audio & Video
Bypass parking brake for VR3
Hi, I had the same prob with mine. Pretty easy fixed. There is an earth wire connected to the park brake switch, you have to disconnect it. If you are not savvy with car stereo installation, I would advise you take it to strathfield or another car stereo installer - it is a quick and easy job and they shouldnt charge you more than 20 bucks for it.... if that. Beware though, playing movies in your field of view is VERY distracting and dangerous..... and illegal.
Jan 16, 2009 | Jensen VM9510 Car DVD Player
Help need bypass code or instructions
There should be an extra wire on your wiring harness, labeled for the e-brake light. Find that one. On my Jensen, it's a peach colored wire. In your manual, take a look and see what it says is required for activating the DVD playback feature. If you simply have to pull the brake handle to make it work, then yes, just ground that wire and you're in business.
On my Jensen, there was a sequence that had to be done - the brake had to be applied, released, and reapplied for it to work. What I did initially was to ground the wire and put a switch inline on it. To simulate setting the ebrake, I'd close the switch (completing the ground), then flip it open to break the connection (same as releasing the brake), then flip it back again, and the DVD would play.
I found a little while ago that there is a hidden feature menu on the player that allows the e-brake sequence to be bypassed with a code, which I put in and now it's not an issue.
Take a look at your instruction manual and let me know if it just has to have the e-brake on, or if there's some sort of activation sequence like my Jensen has, and I can firm up the answer.
Dec 26, 2008 | JC Whitney - Pyle 7" Tft/lcd In-dash...
Brake bypass code
I just got this same unit on thursday of last week and put it in myself. All you have to do is ground the pink wire out and it will work without having to put a bypass code in. Hope this works for you as well.
Mar 31, 2008 | Phase Linear UDV9010 Car DVD Player
HOW DO i BYPASS PARKING SWITCH?
You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Mar 18, 2008 | Car Audio & Video
E- brake bypass
Thanks for everyone's help. The bcar screen actually is the backup camera screen which is activated by the orange wire and when I turned on the lights, it got activated. I disconnected the orange wire and everything is fine. When I get a backup camera I'll connect that wire to the backup lights so that it will come on whenever I put the car in reverse. You are right that their manual is not very clear at all. I called their tech support and they couldn't help me trouble shoot the problem either. The unit is functioning perfect now but my next beef is that you can't change the XO vison default screen when a cd is playing. It would have been nice if you can scroll some jpeg shots of anything else besides looking at the xovision logo. I guess I can't have it all for $340 so, I'll stop whinning.
Jan 26, 2008 | XO Vision XO-1400 Car DVD Player
Jensen VM9512 in-dash DVD player
with the remote:
press set up button
scroll to highlight language
enter 5,4,3,2,1,0
you will now be in a secret menu
turn on brake bypass
and exit
done
Dec 14, 2007 | Audiovox VM9512 Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
