Have a 51 inch vivitek dlp.picture cuts out.error code says lamp is bad.
  • 125 Answers
Most probably the lamp is bad anyways the ballast supply voltage to the lamp and could be also bad, if you hear a noise coming from the back go ahead and replace the lamp. if the lamp is good you just keep it sooner or later you will use
Jose
Posted on Aug 18, 2008
SOURCE:
New lamp, still no picture
You need to replace the ballast board the powers the lamp.
Jul 02, 2010 | Vivitek V37655 56" DLP TV
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
May 24, 2010 | Vivitek V37655 56" DLP TV
Looking for the enter code for vivitek tv model # rp51hd41-a a 51" micro display projection tv
your cable or satellite will do just fine. i have a vivitek rp51 and i was told that if i lost my remote i was SOT well i found out that the parent company of vivitek is DELTA and wouldn't you know it i programmed my direct tv remote using the brand delta wich was on the list and it worked... by the way vivitek is not on any list for remote control codes....
Jan 14, 2010 | Vivitek V37655 56" DLP TV
I need a replacement dlp lamp for a Vivitek model RP42HD51-A Can you help??? Cost & Availibility???
here is your tv lamp IQ number:3797048800 so with this is easy to find you a good price try this website http://www.discount-merchant.com i buy a lot from this site is good free shipping and good service i like it oh y will give you a link so you can do it yourself..
i think you know who to !
this is your part number! im not doing any thing lol.. so i can help you
hope it works good luck!
http://www.discount-merchant.com/Vivitek-3797048800-3797552Projection-DLP-TV-Lamp-p/vivitek-37970488-dlp-bulb-lamp.htm
http://www.youtube.com/watch?v=tJXxi5NVZjA
Nov 15, 2009 | Thomson 50DSZ644 50" DLP Rear Projection...
Vivitek 56 inch dlp projection is humming. why and how to fix
In my experience, the humming means your color wheel is going. The bearings inside the wheel are probably giving out.
My Vivitek started humming a couple of months ago and first I replaced the lamp.
Still hummed.
I read in other forums that humming is linked to color wheels and that seemed like where the noise was coming from.
I purchased a new wheel online and replaced it myself...
..no more humming, the picture is great and now I can listen to the movie again...not the tv!
Mar 17, 2009 | Vivitek V37655 56" DLP TV
Replace lamp on dlp tv
On the side of the TV press the menu and volume up buttons at the same time for three seconds. The 'reset lamp timer?' will appear on the screen. Press the OK button to accept. You're done!
Jan 05, 2009 | Televison & Video
Vivitek 51 DLP HD HDMI
You should have checked the troubleshooting section of your manual!! Okay, enough scolding. You need a new lamp. I do enjoy my Vivitek, but this is a definite downside of a DLP, especially if you watch a lot of TV. I am on my third lamp already, and they are NOT inexpensive. If you have your TV less than a year, your lamp may still be covered under warranty and may be replaced by Vivitek for free. If you have to buy your lamp, it can easily cost you over $200. This is the new lamp in a whole new assembly, which makes installing it EXTREMELY EASY and will just take a few moments. If you are a little more adventurous and want to save some money, you can buy the lamp alone. You then remove the lamp assembly from the television, open it up (there's several screws to remove), disconnect the old lamp, and reverse the process by making the proper connections with the new lamp and putting the new assembly back together and back into the television. It sounds more complicated than it is.. Biggest rule.-- don't touuch the surface of the lamp with your bare hands. You don't want your oils on the lamp. . And once you put everything back together and restart the TV, reset the timer for the lamp (the manual explains how). The lamp timer is very important for warning you of when to replace the lamp under ordinary conditions, when it does make it through its entire expected life. I don't know if it's appropriate to actually recommend specific vendors for the lamp, but I can if that's okay. email me midlomiss at yahoo dot com
Mar 13, 2008 | Vivitek V37835 46 in. LCD Television
Tv codes
THE TROUBLE CODE IS 32. YOU NEED A BULB.GET READY TO PAY BIG MONEY, I'M SORRY I BOUGHT A VIVITEK.
Jan 14, 2008 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Ekse
