Question about Kodak EasyShare DX7440 Digital Camera
Bad USB Port in Camera
I was having problems transferring pictures from my DX7440 and could feel a little "glitch" with my cable/USB port in the camera, so thinking my cable was bad I ordered a new one from Kodak. After trying the new cable, I have realized it is the USB port inside the camera.
I contacted Kodak support and was told that I could send it in for repair or mail it back to Kodak and receive a coupon for 15% off a new camera purchased through Kodak.
I called repair and was told it would cost almost $140.00 to repair the USB port and I can probably buy a new camera for that. Is there any way I can repair/replace the USB port myself? TIA
  • 3 Answers
I think you CAN--there's a lovely site with specific instructions,,,, Do It Yourself Camera Repair --- for fabulous step by step instructions WITH pictures & simple explanations that a novice can follow!!!
In short, all you need to do is find another USB port (even from a broken camera or other device) to replace yours. It seems that you'll need to solder it in -? - that's the step I'm trying to research right now--I'd like to just glue mine back in because I don't know how to solder--- but the tricky part is getting the camera apart, not touching the flash capacitator nor any of it's power-holding chips, and not damaging any of the other components.
(ACF0EB8F)
Posted on Sep 15, 2008
My cam can not be recognized by my laptop... its the first time this happens... i can not transfer my pics to my laptop
Try camera in another USB port of laptop and also check it with another USB cable, if still problem not solved then plug camera in any other computer to make sure that it is problem of camera.
If camera still wont work in other computer then its USB port got defective, please use memory card reader to transfer pictures in computer, take out memory card from camera, put it in memory card reader and plug it in USB port of computer.
Thanks.
Feb 28, 2011 | Sony Cybershot DSCW310 Digital Camera
I am trying to transfer pictures from my Cannon EOS Rebel T1i to my Mac book and I can't get it to work
When you connect the camera to the Mac, you must have the camera powered ON. THe Mac will automatically recognize the camera and will open iTunes to download the pictures. IF this does not happen, you may have a bad cable or a bad USB port on the Macbook. Try a different cable, or try a different port. Good Luck.
Feb 27, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Why can't import my pictures into the computer?
Have you downloaded the Kodak Easyshare software? It will be easier to transfer picture from the camera to the computer also easyshare software has feature to enchance picture download not to mention that you can send picture thru email using the esayshare software. To download the software visit www.kodak.com/go/easysharesw.
Transferring pictures/videos with the USB cable
Turn off the camera.
2 Plug the labeled end of the USB cable into the USB port on your computer.
3 Plug the other end of the USB cable into the USB port on the camera.
4 Turn on the camera.
Note: EasyShare software opens on your computer. The software prompts you through the transfer process.
If still having issue importing picture from the camera to the computer call Kodak support line at 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z730 Digital Camera
Usb cable has never worked to transfer pictures to computer
It could be a bad USB cable or a bad port. You can test the port by plugging in a different device. If the port tests good and the camera is connected and turned on, you most likely have a bad cable.
Jan 13, 2009 | Kodak EasyShare Z710 Digital Camera
With that amount of non-accidental damage, a replacement is the best option financially
Mar 05, 2017 | HP E427 Digital Camera
Transfer the photos
This can occur due to 2 reasons..
1) Bad USB port: Try connecting to a different USB port and see if it works. If it does then its probably a problem with the USB cable.
2)Bad USB cable: You can resolve this by Changing the cable or by getting a USB card reader. Specify the details of your Memory card and i will help you find a card readr that suits your card..
Jun 16, 2008 | HP Photosmart R717 Digital Camera
Can't transfer pictures to my computer
I work as a Olympus DTS Agent. It sounds like your cable is bad or your Port on your camera is bad. One tip that I can recommend other then calling us at tech Support 1-888-553-4448 is be sure you are always plugging camera in through a usb port on the back of the computer.
Mar 25, 2008 | Olympus SP-350 Digital Camera
Video to pc problem
usb port on this camera used for picture transfers, but to transfer videos, use FireWire DV cable, can be bought on ebay for a buck or so
Aug 18, 2007 | Canon ZR85 Mini DV Digital Camcorder
Olympus fe-130
Make sure your cable is OK. 1: Make sure you don't have any damaged pins on the plug on your camera and on your USB port on the computer Try using a different cable to be sure that is not the problem. If you can t ry a different camera on the same cable and make it work, your camera is at fault. Try it on a different USB port, and possibly also on a different computer to make sure the port on your computer is not at fault. Check both cable ends and the ports on the camera and computer are not dirty
May 18, 2007 | Olympus FE-130 Digital Camera
No usb port found
If you can't find such on your machine, then it's either disabled, the BIOS is out of date, the OS doesn't support your USB (Examples abound!) or other. I cut my time loss by adding an USB PCI card.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Kodak EasyShare DX7440 Digital Camera Logo
339 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
