Question about Whirlpool LER4634J Electric Dryer
Clicking and clunking
I am having a problem with my dryer, as I turn it on, there is a clicking noise, now that has turned into a clucking in addition to the clicking. It is still drying just fine, but what is the problem and how can it be fixed.
  • Anonymous Sep 07, 2008
    cant get apart to see what it is
  • rmstone May 11, 2010
    having problem with dryer clunking from time to time.
    also a whirring noise.
  • 550 Answers
Most dryers suspend the drum on felt glides, nylon glides and rubber tired rollers, if these are worn or locked up, there are regular clunk noises.
Posted on Sep 22, 2008
Creak, cluck, or light clunk noise coming from front passenger end during acceleration from a stop or slow speed.
It is hard to tell, without checking it. Iti could be the universal joint or CV, whatever you have, show it to a mechanic.
Mar 15, 2013 | 2005 Acura TL
2001 Crown Victoria Won't Start Makes Clicking Noise
Sounds like the battery is too low to start the car. The clicking noise sounds like it could be the starter relay. There is enough voltage to cause it too cluck but not enough amperage to turn over the started. They need a lot of amps. If you can, try putting a charger on the battery overnight to see if that helps. Just because you have 12 volts in the battery does not mean you will have enough starting amperage. Hope this helps you...
Nov 03, 2012 | Cars & Trucks
"I hear and feel "Clucking noises when I drive me
If it is clucking then someone has hidden some chickens in your trunk, open it and let them out. If it is clunking then I would suspect rubber bushings on any of the several suspension components have reached the end of their life and metal is banging into metal as the suspension moves up and down.
You need to take it to an alignment shop and have them give you a list of what is worn out. Consider replacing those parts and getting it aligned. If the clunking is reserved only to times when you shift from D to R and back, then I would suspect U joints and CV joints in the axles. If it is reserved to times when you are turning, check the CV joints and wheel bearings. Everything on the car is 14 years old and each part will eventually fail from use and age.
Feb 03, 2011 | 1997 Ford Taurus
My stackable dryer (417.94702300) makes a clunking noise. We just got it (craigslist) and it happened the 1st time we turned it on. Sounds like we're trying to dry a shoe in there - it clunks in rhythm...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Kenmore Washing Machines
I need help with my 1994 pontaic grand am. I just bought the car and it has a terrible clunking noise in the front mostly when I turn the wheel. What could this be? Could it be tie rod, cv joints,shocks or...
Jack up the wheel and see if it has play up and down and left and right. Have someone watch inboard as you move it. A bad cluck will usually show itself.
Jan 12, 2011 | 1994 Volkswagen Jetta
Washer makes loud clunking noise &so does dryer when moving around, you can turn the basket by hand to make it clunk.
heatman101
ghgf
Sep 03, 2010 | Splendide 2100 Vented Washer-Dryer
When turning it makes loud noises and is harder to turn, but there seems to be enough fluid in container.
Does it make a clunking noise when turning? How about a continuous clicking noise when turning? That would be tie rod end if clunking, or cv shaft (ball bearings) if continual clicking when turning. Sometimes turning very sharply can put to much pressure on the power steering pump and strain on the belt when turning. Do check your steering linkage and make sure nothing is rubbing against the tire when turning.
May 29, 2010 | 2001 Chrysler Town & Country
Clunk noise with or without clothes in dryer when operating: possible drive wheel issue? Thanks
heatman101
hghdg
Dec 26, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer works... just makes a clunking noise when it is running
heatman101
uit
Aug 10, 2009 | Amana NGD7200TW Gas Dryer
1997 Dodge Grand Caravan heater blower makes clicking noise
take out the blower motor
if the bearing is ok
use a vacuum cleaner to suck out the debris in the piping
Apr 28, 2017 | 1997 Dodge Grand Caravan
Whirlpool LER4634J Electric Dryer Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
