Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Can not connect to the internet in trying to setup the router.
In setting up the router through the setup wizard and I been asked to enter the username and password to my ISP (Time Warner) for internet connection. After enter my username and password I get the error message that it can not login into the ISP.
Per my ISP tech support, they do not require a username and password to access the internet. he mention I needed a router username and password.
Any advise would be appreciated.
  • 60 Answers
Yes time warner is a cable connection and they dont require a username and pasword. You can set up the router manually by accessing its set up page. By default the router's IP is 192.168.2.1. Make sure to set the wan connection type to dynamic, change the wan mac address or clone your pc's mac. Then save the settings. Check your internet connection.
Posted on Aug 24, 2008
SOURCE:
Connected to d-link network which is unsecured. how to secure?
You need to setup a password for the wireless connection,
1. Connect D-link Router to your computer
Your computer should be connected to the LAN port of using an Ethernet cable.Power on the router after connecting the router to your computer.
2. Log on to D-link Wireless Router
To logon to wireless router type the default IP address of the router on the address bar. The default IP address of the D-Link router is 192.168.0.1
Before log on to the router it will ask you the user name and password. For a default D-link router
User Name : admin
Password :admin(Flip the router over to know the default username and password)
3. Click on Setup Wizard
To configure the router in an easy way click on the button Setup Wizard.
4. Click on Launch Internet Connection Setup Wizard
To configure the internet connection in this D-link router, click on the button Launch Internet Connection Setup Wizard.
holygrass_21.jpg Now the wizard will show you what steps it is going to complete while running the wizard. Click Next to continue.
holygrass_22.jpg 5. Create new Password For your router
holygrass_23.jpg Setup wizard will prompt you to create a new password for your WBR-2310 Wireless Router. After entering the password click on next.
6. Select your Time Zone
Now the setup wizard will prompt you to select your time zone.
holygrass_24.jpgPost .
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | D-Link Computers & Internet
Tip
How to setup the D-Link Dir-615 Wireless Router on the Internet 1. You will need...
1. You will need to connect your Cable or DSL modem to the Internet port on your router.
2. Connect your computer to any of the 4 LAN ports
3. Next you will want to insert the "Quick Router Setup Wizard CD" in to your CD-ROM drive. This will take you through the automated steps of setting up your router to work with your modem. Note if you have a DSL modem that uses a PPPoE connection software program you will want to uninstall it from the computer before you continue. Also you will need make sure you know the user name and password because you will need to enter it as a part of the setup for the router.
4. When the setup wizard opens you will want to click on "Install Router" in the upper left hand corner.
5. Click on the option for "Setup Wizard" to use the setup wizard.
6. Click "Launch Internet Connection Setup Wizard" to start to setup your LAN settings
7. Click "Next" to continue.
8. At this point you will be asked to create a new password. After you entered a new password click "Next".
Note it is important to setup a password at this point especially if you plan to setup a wireless network so no one will be able to gain access to your router settings.
9. Click on the drop down menu to select your time zone and click "Next"
10. You will need to select the type on Internet connection you have and click "Next"
11. Here are the different step you need to go through depending on the option you selected above.
DHCP
- If you selected DHCP then you might need to enter the MAC address of the computer that was last connected directly to your modem. If this is the computer you are currently connected to then just click on the "Clone Your PC's MAC Address and then click "Next"
Note you may need to enter a host name if this is required of your ISP.
PPPoE
- This is where you will need to enter your PPPoE user name and password.
Note as a reminder if you have not uninstalled the PPPoE software from your computer because it is not needed any more.
PPTP
- This is where you will need to enter your PPTP user name and password.
L2TP
- This is where you will need to enter your L2TP user name and password.
Static
- You will need to enter the network settings provided by your ISP
After entering the required information click "Next"
12. Click on "Connect" to save your settings. At this point your router should be rebooting. After it is done rebooting then click "Continue". Next you will need to wait 1 to 2 minutes while the router connects to the Internet.
Now you should be connected to the Internet. If you are not connected you may need to review you settings. Also you may try unplugging the power from your modem and the router. Then next plug the modem back in and let it run for about 30 second and then plug the router back in. If you still have trouble you may want to contact your ISP to make sure you have your settings right.
on Apr 26, 2010 | D-Link DIR-615 Wireless Router
When i try to connect it will not get connection to internet. If i by pass the router it will connect
Hi rarebed, Your router needs to be set up D-link has an automatic setup wizard just connect you router to the computer and type 192.168.1 in the internet's address bar. hit enter and enter again on the next page (you don't need a password) then pick automatic setup and follow the wizard. http://www.fixya.com/support/r4219065-set_up_wireless_router_use_wireless For General manual instructions
Sep 27, 2010 | D-Link AirPlus DI-524 Wireless Router
How do i set it up manually?
Connect an Ethernet cable to one of the Lan ports,
and to the network-card in a computer (running Windows XP or Vista or 7).
Via Internet Explorer, access the web-interface "inside" the router,
and run the "Network Setup Wizard", and run the "Wireless Setup Wizard".
That's all -- there is nothing dependent on "Windows 7".
Nov 23, 2009 | NetGear WGR614 Wireless Router
Help me to resolve a problem with my Router
To access the configuration page of the Dlink router, use a wired computer or directly connect your laptop to the router using an ethernet cable. Then open any internet browser and in the address bar type: 192.168.0.1.
Select Admin from the drop-down arrow and then enter your password. Leave the password blank by default. If it doesn't work, then you will need to reset the router.
At the back of the router there is a reset button, hold it down for 30 seconds.
Then try again to access the router. Reconfigure the router's internet connection, depending on your ISP. Under Setup>Internet page, click the Internet connection Setup Wizard button to automatically configure the router.
Then for the wireless settings, go to Setup>Wireless Settings page, then click on the Wireless Network Setup Wizard to configure the wireless settings.
Nov 11, 2009 | Computers & Internet
Ran the setup wizard for the d link di 514 but still cant connect to internet
Do you have Internet connection before you installed the Dlink router? Do you have cable or DSL? If you have DSL make sure you have the username and password from your Internet service provider because you need to enter those information when you run the set up wizard. You need to connect your computer to the LAN port of the router. Turn off computer and router, turn on router first then turn on the computer. Run the set up wizard again.
http://technicalsupport.blog.friendster.com
Sep 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
Router configuration
you need to open the configuration page of the ADSL router and enter the configuration settings manually.
into your browser type http://192.168.0.1 >> username: admin >> password: admin
then in the setup page...enter the correct setting provided by your ISP...like encapsulation...multiplexing..VPI / VCI etc...call them if you have to...then enter your username and password for your internet account (you need to contact your ISP also for this.)
if ever you still cant enter into routers setup page...you can reset it to factory default...at the back of the router...there is a small hole..(usually in red border).....
turn on router >> then push a stick into the hole (small stick enough for the hole) for about 5 secs...then try again http://192.168.0.1 >> username: admin >> passoword: admin
if you need further info...please post back. good luck
Feb 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
WEP encryption ana Wireless connectivity
  1. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online,
  2. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
  3. Click OK. This logs you into the router
  4. Click Setup Wizard on the top left corner, Select Yes for the Setup Wizard to detect the type of internet connection and click Next.
  5. The Setup Wizard will detect the type of Internet connection. DSL connections which require a login to connect to the internet will be detected as PPPoE. Click Next
  6. Configure your router with the username and password provided by your ISP and click Apply.
  7. The router will now save these settings. When complete, you can verify whether you are connected to the internet from the Router Status > Maintenance menu.
  8. Verify you have a valid IP address (not-blank / 0.0.0.0) on the Internet Port assigned by your ISP
  9. check if you are able to go online wired..
  10. to setup wireless
  11. Click Wireless Settings under Setup menu.
  12. Under Security Options, Select WEP (Wired Equivalent Privacy)
  13. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  14. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
  15. then check in your w/ls laptop, you would find your w/ls n/w name , try connect to it, enter your key , you would get connected
for more clarification, log into http://kbserver.netgear.com.
Dec 02, 2007 | NetGear RangeMax WPN824 Router
Sympatico
  1. Start your network in this order:
    1. Turn the modem power off.
    2. Turn the router power off.
    3. Turn the modem power back on. Wait two minutes until the lights are stable.
    4. Turn the router power back on. Wait one minute until the lights are stable.
    5. Turn the computer power back on.
  2. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online, for example to http://kbserver.netgear.com.
  3. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
  4. Click OK. This logs you into the router
  5. Click Setup Wizard on the top left corner, Select Yes for the Setup Wizard to detect the type of internet connection and click Next.
  6. The Setup Wizard will detect the type of Internet connection. DSL connections which require a login to connect to the internet will be detected as PPPoE. Click Next
  7. Configure your router with the username and password provided by your ISP and click Apply.
  8. The router will now save these settings. When complete, you can verify whether you are connected to the internet from the Router Status > Maintenance menu.
  9. Verify you have a valid IP address (not-blank / 0.0.0.0) on the Internet Port assigned by your ISP
  10. check if you are able to go online wired..
  11. to setup wireless
  12. Click Wireless Settings under Setup menu.
  13. Under Security Options, Select WEP (Wired Equivalent Privacy)
  14. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  15. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
  16. then check in your w/ls laptop, you would find your w/ls n/w name , try connect to it, enter your key , you would get connected
Nov 16, 2007 | NetGear RangeMax WPN824 Router
Internet connection
Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
189 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
