Question about HP PSC 1315 All-In-One InkJet Printer
Printer will not print, I just change the cartridges and it still will not print
The printer will not print it kicks out a black sheet of paper, what could be the problem
  • kinny88 Aug 24, 2008
    I hv installed new ink cartridges and it will not print, except it will kick out BLANK sheet of paper............pls help
    Genius:
  • 3,422 Answers
HI,
Please unplug all the cords of your printer for 30min and then plug it back in and then try printing.
Posted on Aug 18, 2008
Prints total black sheet of paper
If there are no indicator lights, it's probably a defective cartridge.
Apr 23, 2016 | HP LaserJet 1020 Printer
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
I am getting several black lines in scanned and copied documents of my DCP 7020 Thanks
Check the print document to see if the ink rub of easily,if so this mean the fuser cartridge need to be change.Turn off the printer and wait until it is cool before changing the fuser cartridge because the fuser get very hot when ever the printer is in use.
Open the fuser cartridge door. On most printers this door will be either on the left-hand side of the printer or in the back. Consult your owner's manual for the exact location. Flip down the clips that hold the cartridge in place, then grasp the handle and pull it out of the printer.
Push the new fuser cartridge in until it snaps into place, then flip the clips up to lock it in place. Close the fuser cover door.
Open the toner cartridge door and remove the toner cartridge. On most laser printers the toner cartridge is located either in the front of the printer or on the right-hand side.
Vacuum underneath the toner cartridge to remove all paper dust and toner residue. This debris has a tendency to build up and cause streaks and stains on the paper.
Wipe the interior of the printer with a soft cloth to remove any remaining debris that could cause problems with print quality. Continue cleaning the printer until all debris is removed.
Purchase a set of laser printer cleaning sheets, and load one or two in the paper tray. Print to those sheets of paper to clean the paper path. These sheets are slightly sticky, and they are designed to remove dirt and debris from the paper path.
You should also clean the print drum and the corona wires.
Aug 30, 2010 | Brother DCP-7020 All-In-One Laser Printer
Leaves streaks vertically on paper changed cartridge still there. 2600n printer
when you open the front of the print you will see the streaks on the black transfer sheet.
Close the front door half way or until all the cartridge doors open.
You will see the same streaks on the problem cartridge(s) as on the transfer sheet.
Change that particular cartridge, let the printer recalibrate, and presto streaks are gone.
Feb 13, 2010 | HP Color LaserJet 2600n Printer
The paper only comes out through the left side of the paper path. I didn't find anything jammed on the rigth side when I pushed an envelope through it.This started when I changed the paper in the printer....
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1 Load plain paper.
2 On the printer control panel, press .
3 Press the left or right arrow button until Maintenance is highlighted, and then press OK.
4 Press the left or right arrow button until Print Test Page is highlighted, and then press OK.
5 Press OK again. A test page prints.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 02, 2009 | Lexmark X4650 InkJet Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printer not printing correct colors or black
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Jul 21, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black cartridge not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Jan 15, 2008 | Lexmark X75 All-In-One InkJet Printer
Balck ink not working
Mar 16, 2007 | Canon S 330 InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
18 people viewed this question
Ben Johnson
