Question about HP Photosmart 3210 Printer
Error 0xc18a0207 Hey My printer is having a 0xc18a0207 error. It wont print, scan, fax etc. Can you please help! I tried some online solutions already such as removing the ink and whatnot but none of it has worked. Please help! Thanks!
Turn the printer off while pressing the following key (it perform a cold reset )
cancle+ok+color+black for 3210
then swich it on
do it twice the your printer is alive .
Posted on Aug 25, 2008
I received the same error- 0xc18a0207, and it stated that my black ink was expired, so I might try to buy a new one.
Posted on Aug 31, 2008
  • Angela Sbrizzi
    Angela Sbrizzi Dec 13, 2011
    I`m having the same trouble I have purchased all 6 cartridges but alas it will scan but it tells me ink cartridge has failed unable to copy, receive faxes,or print refer to printer documentation
then swich it on
SOURCE:
Photosmart 8250 0xc18a0207 carlitosfop
This is a general printer error which occurs when ..........
a> cartridge/s are changed
b> defect in integrated printhead
HP Single-Function and Multi-Function Printers - An '0x ...' Error Message Displays on the Front Panel When Printing (c00489814) Issuegtabtop.gif The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .'
c01733891.gifImportant: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) (in English) to solve this error:
  • Cartridges 564, 364, 178, 862, or 920
    Figure 1: Example 564, 364, 178, 862, or 920 cartridges
    c02264161.gifIllustration: 564, 364, 178, 862, or 920 cartridges
Solution one: Reset the productgtabtop.gif
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
      NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
    Figure 2: Example USB connection (your product might not look exactly the same as this example)
    c01651067.gifDescription of disconnecting the USB cable.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the productgtabtop.gif
gtabtop.gif If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jul 16, 2010 | HP Photosmart C7180 All-In-One InkJet...
Hey deskjet f2400 printer wont print, says it is "offline" when i put it online it says "there is an error with the print system" ... driving me nuts
I have the same problem. Used 3 times and now it just won't print it says that it is "offine"... I don't even know how to put it online!! Please help
Nov 23, 2009 | HP DeskJet 3930 InkJet Printer
Canon Pixma MP150 offline - won't print from computer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-25
Aug 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP PRINTER 2840 WONT SCAN TO WINDOWS FAX AND SCAN PROGRAM
well........ first of all it depends on the Operating System on you computer, then starting from there the advice that i can give you it is to fully uninstall the software and then install the software back using the version that is on hp.com
after that when you have the full sw installed you have to set up the scan button on the printer from the twain scan window but that will be a piece of cake. just make sure ot get the software properly installled.
Mar 06, 2009 | HP LaserJet 2840 Printer
HP PRI
completely uninstall all software realated to this printer. disconnect your pc from the web. disable your anti virus and firewall then run your fresh install. if you are getting the diver/software from the web save it to your desktop and follow the first dsirections this should solve your problem
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
[email protected]
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
Lexmark 4200 printer/fax/scanner
hey buddy its nothing to do with your printer or monitor
but this problem occurs because of your operating system
first try this out
remove all printers from your start > settings > printers & fax
then reinstall your printer ( if you have usb printer remove cable while installing printer and plugin only when it asks )
then try to pring again
if its not printing then no solution buddy
you just have to re install your operating system
only this can help you
Mar 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Ready Memory Received
Dear guys, your toner cartridge is low and as a preventive measure, the unit stores the faxes in order to give priority to copying and printing. If you are using remanufactured cartridges, the unit might not be displaying the low toner warning.
Jan 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
HP Photosmart 3210 Printer Logo
2,263 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
