Question about Mitsubishi WS-55805 55" Rear Projection Television
Where to purchase pico fuse in DFW area
I have a 42" Mitsubishi HDTV that needs a 125v 5a pico fuse. Having trouble locating a local store in the DFW area to get parts. Does anyone know a source to get these parts?
  • ts13 Aug 18, 2008
    Thank you, great source for parts.
  • 2,326 Answers
Click here to find the pico fuses.
Posted on Aug 18, 2008
Mitsubishi convergence issue
First is consider what the issue is: nothing moves convergence wise or only one color etc.
Also follow if needed the voltages from the pico fuses involved---one will be a negative voltage and the other a positive one--follow them from the diodes for each voltage to the chips---"Got Voltages?"
Jun 11, 2012 | Mitsubishi WT-42313 42" Rear Projection...
Please tell me where the fuse box is and the mother board
one fuse is located directly where the power board goes--set has as many as 6 other fuses inside in different areas--they are pico fuses which means not glass or fuse like in appearance.
Set dead with or without power light?
Apr 09, 2012 | Samsung HCN4226W 42" Rear Projection...
Pioneer sd-643hd5 fuse issue
The fuses may not be your problem--I have fixed several of these---The large power board is on the right side as you look from the back?
Lots of these sets develop bad solder connections on that board--several sites on the internet offer to have you remove and send them the board to resolder--this set used lead free solder and after some years has problems--a few I have opened had clearly broken solder joints--I usually in this case remove the board(mark all the many plugs and make a diagram) and solder almost all of it by hand----usually fixes this kind of trouble.
I do this here for free so if this information was helpful give me a vote here....I am here to help people.
If you have any questions or need advice reply to this posting here.
SD TECH
Sep 12, 2009 | Pioneer SD-643HD5 64" Rear Projection...
GREEN LIGHT COMES ON THAN SHUTS OFF WS-65313
Issues where water has been splashed onto the board can cause so many weard issues, it is easyer to replace the board then try to replace the individual parts. You need to do allot of troublshooting that will requrie schematic and a good knowlage of that board. try to get your board from pts, http://www.moduslinkptstvboards.com/
Sep 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Thermal fuse
It is mounted to the case that holds the lamp.. Its specs read something like L3 250V, 5A, 115C. You can replace it provided you can locate it
Jul 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Toshiba 42H81 Fuse Type
Speed rating is micro = any chemical micro fuse will work,5 amp, of course.Not necessary to use Mfr. part........T.
May 27, 2008 | Toshiba 42H81 42" Rear Projection...
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Jan 05, 2008 | Toshiba 50H81 50" Rear Projection...
Blown fuse
What was the orginal problem?
Nov 25, 2007 | Mitsubishi WS-55907 55" Rear Projection...
2 fuses blow on power up
Its the power pack on the system board. It has a short in it and causes the fuses to blow.....if your farmilar with replacing it you can order the part though the manufacturer.
Nov 15, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
124 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
