Question about Brother PC-6000 Pacesetter
I am having trouble with my tension on my Brother Pacesetter PC-4000. The top tension is fine, however, the bottom tension is loose where it can be pulled out. Typically, I know that you adjust the top tension, however, this has not helped. I do not know how to correctly adjust the bobbin tension. There are two screws, but do not know which one to adjust without the fear of messing it up even more. Thankyou!
Go to this website page and it will help you. http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faqh/000000/000000/000044/faqh000044_001.html?reg=eu&c=gb&lang=en&prod=hf_inov700eeuk&Cat=52
Posted on Mar 12, 2010
How to adjust tension on Brother Pacesetter 8200
Is your thread new? sometimes if it's older thread it will break often, finally changed my thread and it worked fine.
Feb 13, 2015 | Brother Sewing Machines
Why does upper thread break?
Check your tension, especially the tension disks for loose thread. Then rethread the whole thing.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
PE-3000S Pacesetter won't pick up bottom thread
try changing the needle
also rethread the machine
clean under the needle plate & in the bobbin area for loose threads or lint
if these suggestions don't help the it's possible that the machine has jumped time & needs to be serviced
May 15, 2012 | Brother Sewing Machines
Tension is off. top thread is tighter than bobbin thread. And the machine is making a squeaking sound. have taken off the bobbin case and cleaned all around it.
usually a tension of 3 or 4 is good
rethread the machine, the thread is probably caught somewhere
also clean under needle plate where the feed dogs are for lint
Nov 19, 2010 | Brother PC-6000 Pacesetter
What tension setting should I use for6 layers of polar fleece on my brother PS 1800?
Depending on the thickness of fleece I would go back about 1-2 settings, being that your tension on bottom is already set correctly
Nov 30, 2009 | Brother PS-1250 Pacesetter
Zigzag stitch pulling tight, looks wrong
Try adusting the bobbin thread instead of the top. Always make sure to insert the bobbin so the thread is pulling in a clock wise direction. Both threads top and bobbin should have about the same resitance when pulled.
May 08, 2009 | Euro-Pro Shark 60 - 384
How do you thread a brother pacesetter 6000 for twin needle sewing
Two reels of thread on the top,make sure the threads go seperate sides in between the tension discs, thread both needles but remember not to put the stitch width more than 2.
May 02, 2009 | Brother PC-6000 Pacesetter
I'm having troubles with my brother sewing machine
Your tension is loose on top. Adjust your tension dial up a little at a time until you have a desirable stitch. Before adjusting the tension, you may want to look into the tension and see if there are any threads caught between the disc. If so remove them. Another common problem is that your machine is not threaded properly, make sure the pressure foot is in the up position when threading and if needed consult your manual for the proper threading diagram.
Jan 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Tension problems
It sounds like your bobbin tension is too loose. If your needle went into the spare between the looper and the flat tensioner, the plate might need replaced, or removed and unbent.
Jan 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
224 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
