Question about Mach Speed P4M800 (890552603480) Motherboard
Slow, Slow mobo
I installed my P4M800 Mobo combo, and it runs extremely slow, could this be a bad mobo or processer, everything works and runs, but really really slow, took about 4 hours to load XP, about 2 hrs to format drive, which makes me beleive bad hardware. Any ideas?
  • 781 Answers
Is your CPU set to its correct speed
Posted on Aug 25, 2008
SOURCE:
Why my CPU is so slow in any progress, My Desktop Sets are: Motherboard- GIGABYTE GA-B75M-D3H. RAM- DDR3 HyperX Blu 8GB. Graphic Card ASUS GT710-2GB. Please Help, what should I do to IMPROVE. PLEASE
NO OS stated, just mobo. (and GPU card) windows what?
all PCs are slower than better PCs,
no CPU stated,
what are you doing, when its slow?
are you playing games, tell what you do when it slow.
I have Asus z270 with i5-7700 and it screams, with M.2 fast. SM961.
no idea what you have there, or are attempting.
computers can do 1000000000000 things, name one please.
is the CPU overheating, 90c it halts just before that all CPU slow down to save themselves from damage.
the heat sink must match the wattage of your CPU,
the fan on top must run and blow, or the CPU will overeheat.
your mobo only can run 3rd generation intel CPUs, like i5-3xxx
2012 processor it is.
you didnt put a slow crippled Celeron in it did you?
Core i7-3770 (this CPU tops out here) full features. and speed.
tell more get more, what OS, and what runs slow , name something please, and tell what heatsink fan you used.
the top processor needs at least 77watt fan/HS or it will overheat.
Jun 29, 2018 | ASUS Computers & Internet
System is running extremely slow, when I tried to do a factory restore I get an error code 0xf00000005. I ran hardware diagnostics on the hard drive memory cpu and mobo, tests run extremely slow. I tried...
After using Darik's boot and nuke (DBAN) your hard drive will be wiped clean with little chance of recovery. This also depends on how many passes you used for the disk wipe. More passes = less chance of recovery.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process.
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
Installed Intel P4 630 CPU on ECS P4M800-M7 V3.1 mobo. Cannot do POST. The mobo runs fine with Intel Celeron 326 fine.
Hello Mafatbhai, What beeps are you getting at POST?
Here is a list of BIOS beep codes.
http://www.computerhope.com/beep.htm
Well the mobo should not have any problems with the new CPU. Please ensure though that you have removed the CMOS battery to reset it. I have included a link to ECS for your specific board. Download and install all of the available updates starting with the drivers and then the BIOS updates.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Jul 11, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Bios upgrade
You can use Winflash to upgrade the motherboard BIOS or during boot using text or character driven interface . These utilities can be downloaded free of cost from the mobo manufacturer website. BUT MIND YOU IF YOU DO NOT FEEL CONFIDENT ENOUGH OR NOT SURE OF THIS PLEASE DO NOT TRY THIS AS ANY ERROR IN THE PROCESS OF UPGRADING MOTHERBOARD BIOS WILL RENDER THE THE MOTHERBOARD USELESS. An 8x AGP PRO Card should work without hitches on tis mobo
Apr 03, 2008 | EliteGroup Intel Pentium 4 Processor...
Mer cury PVM7 mobo wont display on monitor
So I think you are saying it did work and then stopped, right?
If that's the case then I would try booting into the BIOS setup and reseting it first. If that does not work then I would reboot into the BIOS again and see if there is something there you need to enable for the AGP port to function.
If all this fails then you most likely have a bad motherboard. It's probably not worth the money to consider having it repaired, and I doubt you'd find anyone who's even interested trying.
Good luck.
Dec 28, 2007 | Mercury P4VM800M7 Motherboard
P4M800-M7 presumed memory problem
I have never had a problem with Mobo's supporting 2 GB of memory.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&DetailName=Specification&MenuID=44&LanID=0
As per the website your mobo supports 2 GB memory.
Dec 25, 2007 | EliteGroup P4M800-M7 Motherboard
No display on monitor
no, its working as you said. try to uninstall your video if you installed to expansion slot (agp) then use the on board. that is one of the most common problems of pc specially when you're moving this from one place to another. if it boots from your onboard vga clean your uninstalled video card then reinstall to your agp. i hope that this helps you
Dec 08, 2007 | EliteGroup ECS P4M800-M Socket...
Problem with my mobo
are you sure the wires are on the right pins.
No it wont hurt the bios, but power may of fried something,
But thats rare.
here is the pins. #1 is lower left.
1 HD_LED_P
2 FP PWR/SLP *MSG LED(+)
3 HD_LED_N Hard disk LED(-)
4 FP PWR/SLP *MSG LED(-)
5 RST_SW_N Reset Switch(-)
6 PWR_SW_P Power Switch(+)
7 RST_SW_P Reset Switch(+)
8 PWR_SW_N Power Switch(-)
9 RSVD Reserved
10 Key No pin
Here is the manual
Nov 07, 2007 | EliteGroup P4M800-M7 Motherboard
Slow running
1.reinstall or upgrade your graphics card driver 2.make sure your hardware acceleration is full (control panel: display properties) 3.make sure your DirectX Acceleraion enabled (run: dxdiag)
Sep 27, 2007 | Computers & Internet
Mach Speed P4M800 (890552603480) Motherboard Logo
257 people viewed this question
Top Mach Speed Computers & Internet Experts
Thomas F. Schneider
Marvin
Marvin
Chris
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
