Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Fan Issue I'm calling it a fan issue just because the error code is 37, although I have a 12 dc converter and have troubleshooted both the exhaust and bulb fans. They both are working perfectly. I don't understand why it wont come on and says there is a stopped fan when they all seem to be functioning. Look forward to hearing back from you, Josh
  • joshlankford Aug 21, 2008
    I only find three and I completely took the entire TV apart. I took off the mirror, housing above the lower mirror and bulb, and the whole power supply. I re-wired all three fans and then found that there was a wire cluster that became disconnected from the power supply. I have no idea how something like this could happen but after re-connecting this and putting the TV back together she works like a dream. Now I can sell it!
    Thank you so much for your time.
  • Mitsubishi Master
  • 8,617 Answers
Theres 5 fans inside your Tv are you sure they are all working?
Posted on Aug 20, 2008
  • Sonny Berry
    Sonny Berry Aug 21, 2008
    your welcome, glad I could help
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
I bought a lamp for my Misubishi 1080p and its not coming on flashing yellow
If not same issue as before lamp replaced double check that it is in correctly and door is closed--this set should also have a self check:
This is for another model so codes may be different but see what code you get.
Nov 08, 2012 | Mitsubishi WD-Y657 65" HDTV
Starting light flashes green, and then red. Turn off and on several times.
Possible lamp but:
Nov 07, 2012 | Mitsubishi WD-65733 65" HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
Green light on tv trunes tv off. then green light gose off @ ON
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 17, 2012 | Televison & Video
Try to turn on. sounds like hamster on exerise wheel needing some grease then stops a few seconds and starts again. then stops completely.
Might be the color wheel used in most of the light engines--to my knowledge it is only available with a replacement engine.
You can try to see if set has the self check:
Jun 12, 2012 | Mitsubishi WD-65731 65" HDTV
Timer is lock replace bulb
This set has all kinds of problems--
try the self check:
Jun 01, 2012 | Televison & Video
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a mitsubishi wd62725 green flashing led non stop replaced all the bad caps, 2 big and 4 smaller on power 4 1000u on fmt and 4 1000u on the dm board still getting the non stop led if i boot up with...
You can press the "DEVICE" and "MENU" keys on the front of the TV (not the remote) and the TV should flash an error code. Here is a chart.
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
If the code is lets say 36 the LED will flash 3 times then pause then 6 flashes.
May 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
