Machine works fine, but will not heat water, eliment fine thermostat fine
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Does the washer have a dial for water temperature.. some do and it may have been moved to cold...!
Just a thought. Probably random... :0)
sue
Posted on Aug 18, 2008
Inside fan is working but heat exchanger ices up and fan freezes and unit won't cool.
This means the heating eliments are not coming on. Usually in this case I change out the heating timer, eliments, and thermostat. All as a set.
Aug 29, 2015 | Haier HRT02WNC 1.7 cu ft Compact Counter...
Hi my wf220 won't do a full cycle the prewash flashes all the time if i put it onto wash it just sticks on wash all the time but will spin if i just set it to rinse n spin or just fast spin could you help...
My guess is heating element, if its broke it wont heat water and because the thermostat does not detect hot water the machine does not move onto next step. i suspect you will not be able to do a prewash.
Part cost ££20 to £30
My machine has same problem but im struggling to pull out the eliment.
Jan 15, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Dryer does not get hot, already changed the heating eliment
this might help
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 15, 2010 | Dryers
Coffee machine kenwood model es547 ligts come on but water will not heat up
Try unplugging it for several iuets in an attempt to re-set it..
If not - could be that the heating eliment failed.
Jul 11, 2009 | Coffee Makers & Espresso Machines
Will I get power to both elements at one time I test power at elements while unit is heating and can only get power to one element at a time.When one thermostat cycles off the other element will come on.I...
You are correct. That is the way most of the two eliment  water heaters work, one eliment at a time. Make sure that the two thermostarts are set at the same value. Have you tried just making the water hotter, so that the hot water will not be used at such a fast rate, when mixed with the cold? Also draining the sediment from the bottom of the tank with increase the water capacity,of course.
Mar 10, 2009 | Water Heaters
No water at all coming from the hot water (electric) tank? we drained tank in case there was an air leak already. If we wait awhile it will run again for a bit then stop --no reason to it. Help please with...
If it is at least a 30 gallon tank it has two thermostats  One behind each door. They are ajustable and you should  be able to cycle then on and off with a small screwdriver. Went finished,if they both worked set them on the same value. With a volt meter,if test lamp,see that you have rated  voltage coming into the tank.   Turn off the electricity, Disconnect the wires for the heater eliments (one behing and usually placed under the theromostates and  the with a battery type test light, if you have not an ohm meter .  Check across each one. Light should light dimly. Brightly means that the eliment is shorted . No light indicates that the eliment is open. No or bright either one replace the eliment. That is about all their is too it . Fairly simple design.
Mar 01, 2009 | Premier Watts Two-Chamber Tankless...
How do you know if it is the element that is bad or the therm-o-
Disconnect the electric for the unit. Disconnect the two wires from the two eliments. Place a battery type test light or Ohm meter is more conclusive if you have one, Light should light when placing the two test leads to the two eliment contacts(while they are disconnect for the water heater wiring) should be dim but glowing. If no light the the eliment is open. If an Ohm meter the Wattage is written on the heater the heater. E=IR P=IE. It should work out to about 1200 -1400 ohms if 220 volt heater. If the light is bright just as if you had put the two test leads together,then you can say that the eliment is likely shorted. Either no light or a Very bright light requires the eliment to be changed.   To check the thermostats, Raise the ajustment one one at a time, until it clicks. Listen for the heater to be heating. Turn that one back down and do the other one the same way. I hope I have been clear enough. About one gallon of water should be drained for the bottom of the tank once a year along with checking the preasure/tempature safety relief valve by  operating it ,using the leaver,for  a few moments as preventive maintenance.
Feb 11, 2009 | Element Chromalox SG1353-430326 Electric...
Heating elements will not heat
If you dryer is running but not heating then you may have one of the following problems.
Make sure you have 220-240 volts to the machine. If one leg of you breaker has kicked you will only be getting 110 volts this will cause the dryer to run and not heat. Simply kick the breaker off and back on to fix.
If you have enough voltage then you may have a bad thermostat, thermostats or heating element. I recommend you take your heating element off and look for broken lines.check continuity if possible. If the heater is good then go to the thermostats. Check continuity. Replace if you find a bad one. Good luck and I hope this helped. mca0824@aol.com
Apr 29, 2008 | Hotpoint NLL113EYWO Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
