Question about Creative Labs ZEN V Plus MP3 Player
Freezing My Zen freezes up and stops when the battery display says it is fully charged. Most recently during a concert this last week-end. That was sure fun!
  • Anonymous Aug 25, 2008
    its keeps saying playback error so i deleted the song hat wouldnt play and it still wont play any songs it just freezes
That happens to mine, too. What you do is stick a pin through the little reset hole on the left side (under the switch you hold down to turn it on). That should reset the player. If that doesn't work wait until the battery runs out and then charge it.
Posted on Aug 19, 2008
My creative Zen, 8GB MP3 player will not switch on. The computer will not detect it, but detected other external drives. I know the Zen's battery was fully charged before it faulted, but it will not even...
I think it's dead, You might want to do a hard reset on it or wait for the battery to drain. I had a color version of this and it was forever freezing. If removing and then reconnecting the battery does not help then it might have worse issues. If all else fails I can take a shot at repairing it, my e-mail is Zenodilodon@gmail.com
Jun 28, 2010 | Creative Labs Zen Micro MP3 Player
MY Zen WONT TURN ON. It also wont charge.
Connect the player to a USB port on the back of a desktop PC.. Check the display for the charging icon . As the display times out after a few seconds, press any button on the player to reactivate the display. If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is blinking on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging. If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
You might try updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality.
http://support.creative.com
Jan 16, 2010 | Creative Labs Zen Micro MP3 Player
My fm radio stopped working on my creative zen vision, and the display is all messed up. It also freezes for about 20 minutes when I turn it on. After 20 minutes, it will play normal, but it freezes...
Support for Zen Vision M on this site:
One of the Knowledgebase Solutions for "freezing" gives this answer:
Solution ID: 64087
dot-clear.gifSolution ID # 64087 -->dot-clear.gifdot-clear.gif -->
Player is Freezing
Keywords / Key Phrases: freeze, freezes, freezing, hang, hanging, freezes at creative logo, at docked screen, rebuilding library screen, playing audio files, switching to other functions or menus while shutting down, freezes at recovery mode, freezing at music playing now screen
  1. Gently push the end of a thin object (such as a pin or straightened paperclip) into the Reset hole.
    The reset button for your player is located at the bottom of the player, to the left of the sync adapter port.
  2. Refer to the article below to access the recovery mode and perform a Clean Up.
    SID 64088: Accessing the Recovery/Rescue Mode of your Player
    Note:
    1. Clean Up scans a player\'s hard disk/memory card and removes any invalid links from the music library. It does not affect the working music files at all. It is recommended that you perform "Clean Up" first before formatting or reloading the player\'s firmware.
    2. It is advisable for you to clean up your player regularly if you are frequently transferring files from you computer to your player or vice versa.
Last updated: June 16th, 2009
Aug 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
My Zen freeze while i transfer music and video ; Docked Screen
i had this problem alot for first week or two when moving stuff about best bet is to reset the little bugger leave it to sort itself out with the newly transfered data then switch off and upoun power up reset again hope it helps :)
May 26, 2009 | Creative Labs Zen Digital Media Player
My zen freezes regularly and needs rebooting
It's from the firmware, I've had the same problem and I've gotten the white screen of death. Any suggestions? The power light turns blue but the screen is either black or white, it won't turn off unless I click the reset and then won't turn on until 10+ tries of doing the hold down power button, click reset while plugged in PC thing.
Apr 05, 2009 | Creative Labs ZEN Vision:M Digital Media...
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision M freezing during music upload.
Try to add your music a bit at a time instead of your whole library at once. That will freeze it. You can also try sync with Window's Media Player, which works a lot better than the Creative software.
Nov 29, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision: M Freezing During Music Upload
have you download the latest firmware from creative?
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?region=1
Battery
A fully charged battery should last up to 4 hours if it's being used A LOT! But I lost mine and it was in standby mode for pretty close to 3 days and when I found it I was still able to use for quite awhile before charging it again.. So yes, it sounds like it had a weak battery..
Oct 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Creative Labs ZEN V Plus MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
