Question about NAD T743 Receiver
OVER HEAT My NAD T743 gives a message on the console "over heat". While this is happening the receiver stops functioning. I even can't stop the receiver. Could you give me advice.
  • Richard Gilpin May 11, 2010
    I'm getting the same problem on startup. And using the reset procedure of "Video 6" and "Source Up" also brings up the "Over Heat" notice. What now?
To reset the the T743 hold down the video 6 and the source up buttons for 3 seconds. then power up from the back button
Posted on Sep 13, 2008
The amplifier has occasionally shut itself off due to overheating for the last 3 years (I've had it since 2005). But now it continuously shuts itself off and simly won' start up anymore. Does it need a...
They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
A heat sink is just a finned heat-conducting device for radiating heat to the air which should be flowing freely through the unit's ventilation holes. It can't break in normal use. But it CAN get clogged with dust reducing its effectiveness.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T743-Receivers-manual/id/8043bh636/t/2/
Page 6
"Choose a location that is well ventilated (with at least several inches to both sides and behind), and that will provide a clear line of sight, within 25 feet/8 meters, between the receiver's front panel and your primary listening/viewing position-this will ensure reliable infrared remote control communications. The T 743 generates a modest amount of heat, but nothing that should trouble adjacent components. It is perfectly possible to stack the T 743 atop other components, but the reverse usually should be avoided. Nonetheless, it is generally preferable that the T 743 stand alone. It is especially important that sufficient ventilation be provided; if you are contemplating locating the T 743 within a cabinet or other furniture, consult your NAD audio/video specialist for advice on providing adequate airflow."
If you're lucky, you haven't finally toasted it. If you have, a hands on tech will need to sniff sround (literally) to find the dead component(s).
Mar 06, 2011 | NAD T743 Receiver
My NAD T743 will not switch on. I haven't used for a couple of months and it was working just fine before. Now I tried switching it on using both the power button on the amp itself and the remote, to no...
Hi, have you checked the power button in the back to see if it got pressed by accident? It's a round button located right under the speaker inputs in the back.
Apr 11, 2010 | NAD T743 Receiver
My xbox freezes and flashes red
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
Stop the heat and you will be fine.
Feb 27, 2010 | Microsoft Xbox 360 Console
Xbox 360 freez on two of my new games one same level jasper no lights lose controler function remove disk pic still on screen
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
Once you stop the heat getting to the chips you should be fine.
Feb 09, 2010 | Microsoft Xbox 360 Console
NAD T743: The digital channels stop working after a short time.
Hmm, sounds similar to my problem. Analog input and FM seems to work but all coax/opto input are dead ( for me there isn't a buzz).
Have you, fredrik648, solved your problem?
Anyone with ideas what to do?
Thanks
///Johan Westerlund.
May 11, 2009 | NAD T743 Receiver
Nad 743 shuts off at -14db vol. Why?
mine got fixed by replacing the front panel PCB with control processor. Only 350€...
Feb 28, 2009 | NAD T743 Receiver
My xbox 360 stopped loading
Heat needs to be removed from your xbox for it to function properly. If you are starting to see random lockups and odd artifacts in graphics it may be time to clean out your console. Keep in mind that in game lockups can also be caused by DVD issues but if can stick your xbox in a cold place and notice that this gives you stable play time then clean it of all dust. I am talking about taking it apart and giving it a good cleaning. If this does not help try a aftermarket fan.
DVD Drive failure most common problem, this ranges from dirty disk error (DDE) message to inoperable drive door, skipping in movies, slow load time or no load or the call customer service errors 10, 11, and 12. To replace the drive it will have to be reflashed.
Feb 16, 2009 | Microsoft Xbox 360 Console
Using NAD t743 with Panasonic DMP-BD55
The reciever you have has 5.1 inputs at the backof it.The only way to get Dolby True HD and DTS HD is to run the 7.1 analog out from the bd55 to the nad. You'll have to leave the 2 rear surround open on the bd55 leaving the remaining 6 connected to the nad. The digital coax and the optical will not transmit the hd data, only the analog out will. Run a hdmi right to your HD tv for picture bypassing your amp. this will workfine and you'll have the audio you want. You,ll have to change the input settings for dvd in your amp to 5.1 to recieve the audio.
Dec 14, 2008 | NAD T743 Receiver
Turns itself off
NAD Technical Bulletin T743-H2005-06 describes the problem "Unit may shut down, shortly after turn on".  Reason: There is a diode on the standby board that maybe operating intermittently.  Solution: Locate and identify D756 on the standby board.  Change only if the diode is a 1N4148.  Change from a 1N4148 to a 1N4004 or equivalent.
It is located near a transformer and some fuses.
Aug 07, 2008 | NAD T743 Receiver
Does not respond to remote control
I have had the T743 for about three years now. The first unit which I got from the local shop was doing exactily like your described after couple of minutes use. Well, I took is back and got a new one covered by the warranty.
Unfortunately I never got any explanation to this problem from my local shop or anywhere else, so I guess the only way is to contact your local shop.
Dec 27, 2007 | NAD T743 Receiver
NAD T743 Receiver Logo
1,470 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
