Question about Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator
Kenmore fridge ice maker
I think the tube that delivers water to ice maker is frozen. This has happened before and the repairman fixed it in a jiffy. I just can't remember what he did.
  • kyle_rogers Sep 12, 2008
    I have a Kenmore Side by Side.he water is nolonger dispensing at thecup water dispenser and now the water to the ice make is limited. What do I?
I used a hair dryer for about 5 minutes. It took a while to verify because a tray of ice had to fill and freeze before I knew my problem was fixed. No repairman!!!
Posted on Aug 20, 2008
Water is frozen in fill cup inside the ice maker
Put your frozen food in a cold place.Unplug the fridge, leave the freezer door open for 12 hours. Dont mess with hair dryers
Jan 30, 2013 | GE GSS25LGM Side by Side Refrigerator
Ice maker will not fill with water
Water might be frozen in the tube that fills the ice tray. Check the tube and if it's frozen shut, use a hair dryer to heat it until the ice piece melts out. Your icemaker should work after the fridge has been closed for 24 hours to cool back down.
Mar 23, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My 2003 kenmore elite french door fridge made noise for several days, then died. Repairman said it was compressor...expensive repair, so I bought new fridge. Old fridge came back to life 48 hours after...
I bet the bearings in your compressor are bad. The compressor will run and heat up but after getting hot it won't always restart. Most of the time it happens with Tecumseh compressors.
Sep 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Mod: 10651262103, icemaker leaking, not making ice
We need to know if the ice maker overflowed or if there is a crack. Sometimes the water gets frozen in the fill tube and diverts the water everywhere other that ice maker. Rare but sometimes something causes the water control valve to stick open on rear of refrigerator. Your ice maker has a thermostat inside it and starts a cycle when the thermostat says the water has frozen. That starts a cycle of about six thing to happen.The defrost element below ice maker warms the bottom just enough to loosen the ice. Micro switches feel and sense the position and as it nears ending the final step the ice maker tells the water control valve to open for a few seconds. An adjustment in that control may stop over flow. But if cracked in a major section it will need to be replaced. Let me know if this helps you. Sea Breeze
Jun 20, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
LG Fridge-Tube where water dispenses in ice tray is frozen solid
I think that the solenoid valve that supplies water to the ice maker is leaking ,it is located in the back of the refrigerator where you see a copper pipe or plasticpipe thatfeeds water to the refrigerator. Shut the water off and the power and take it out and replace it .
Apr 10, 2009 | LG Refrigerators
Water fill tube and fill cup for ice maker freezing up
If you would like to know how I did it, let me offer you my Premium Assistance Plan.
Nov 24, 2008 | Kenmore Refrigerators
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
