Question about Kodak EasyShare Z1275 Digital Camera
Kodak easyshare z1275 not working =(
I have a kodak easyshare z1275 digital camera that will not turn on with any of the recommended batteries. Another problem is that the zoom lens is completely stretched and as i can't turn the camra on it won't go back in.
  • 8 more comments
  • Anonymous Dec 23, 2008
    same problem
  • Anonymous Jan 09, 2009
    Mine wont turn on either no matter what batteries I use
  • Anonymous Jan 11, 2009
    my camera won't turn on either. It started were it would go on then right back off, but now won't work at all.
  • mikepeaslee Jan 13, 2009
    Mine will not turn on either, any help would be appreciated
  • Anonymous Feb 09, 2009
    • Have the same problems as mentioned with camera not turning on and lens is fully extended. Batteries are charged. Seems Kodak needs to do a recall!
  • Anonymous Feb 13, 2009
    same problem
  • billsidwell Feb 18, 2009
    I have the same problem and have tried different batteries but no luck. Has any one found the fix fo rhtis problem?
  • straycat28 Mar 01, 2009
    Mine is doing the samething... any solutions yet?
  • rebak14 Mar 16, 2009
    Mine is doing the same thing. It won't turn on at all and the zoom is extended. I was hoping for a reset option/button somewhere. This was an awfully expensive camera to only be used for 8 months!
  • joel2665 Mar 17, 2009
    Camera turned on, lens extended, and then the camera tuned off with the lens still extended. This happened with a freshly charged set of batteries. Tried other batteries, but the camera will not respond. Tested the same batteries in other cameras, and they work. When I press the On/Off button the green power light blinks once, and that's it. So, I have a very lightly used camera that just stopped working. I used a Kodak DX4900 for approximately six years with no problem, but this Z1275 barely lasted one year. Very disappointing.
Ghgfh
Posted on Sep 15, 2008
PROBLEM - Camera will not turn on at all regardless of battery used. Happened after about 8 months of use. Kodak instructed me to send the camera in of warranty repair. MCU was replaced. The unfortunate thing is that I have the same problem again, 7 months later and I am guessing it is not a warranty repair this time.
Posted on Feb 24, 2009
Can I use the same USB cable to charge the batteries as well as transferring photos to computer from Kodak EASYSHARE Z1275 12.0 MP Digital Camera providing that I am using rechargeable batteries inside the...
No. The Z1275 is not a battery charger. If you want to use rechargeable batteries then you must charge them outside the camera using a separate battery charger.
Aug 19, 2013 | Kodak EasyShare Z1275 Digital Camera
I have easyshare Z1275 and once I printed pictures on my printer, thezoom lense will not close down and I can't turn it on, even if the battery is removed, it won't shut down. Help. I love this camera,
Camera does not
turn on.
■ Install new batteries (see page 1).
■ Charge rechargeable batteries.
Camera does not
turn off.
■ Remove the battery, then reinsert or replace it. If the camera still does
not function, visit www.kodak.com/go/z1275support,
www.kodak.com/go/z1285support and select Interactive
Troubleshooting & Repairs.
Jun 15, 2010 | Kodak EasyShare Z1275 Digital Camera
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
My kodak z1275 wont turn on
first check wether those batteries are getting charged solution is to replace the batteries as you might nave not used the camers from quite long time
Jun 10, 2009 | Kodak EasyShare Z1275 Digital Camera
My Z1275 kodak camera's lens wont retrack. turn it on and then it goes right off.
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
May 04, 2009 | Kodak EasyShare Z1275 Digital Camera
EASYSHARE Z1275 Digital Camera
KODAK EASYSHARE Z1275 is a peice of ****
Jun 28, 2008 | Kodak EasyShare Z1275 Digital Camera
Kodak EasyShare Z1275 Digital Camera software
Though I'm not sure how to solve this problem, I don't recommend using the program for downloading pictures at all, it's unecessary and slower. Without it, you can treat your camera the same as any other USB drive - open the camera drive as you do any other folder, and drag/drop or copy/paste picture files off of it.
Nov 06, 2007 | Kodak EasyShare CX6330 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
491 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
