Question about VIA P4MA Motherboard
Controller FireWire VIA VT6306 Fire II IEEE1394 Host Controller
Hi and thank you for your responce
Your 1st recommendation appears to have amended my first fault, well the question mark has disappeared at the moment anyhow.
I do not understand what I need to do to clear my firewire fault and was wondering if you could break down your recommendation further, I clicked on the link as requested and only broucher and picture images appeared? Do I need to purchase a new chip and have it installed or is there a download to solve the problem?
I'm not much of a wiz kid with computer faults and only I'm only used to pressing Windows Explorer so please bear with me?
Your help is appriciated thanks
Best Regards
Andy
  • 1 more comment
  • Anonymous Sep 18, 2008
    need driver for XP x64 by subj
  • jehurey Oct 03, 2008
    i also need the driver for VIA VT6306...
  • matt_g187 Jan 24, 2009
    Hello, I have the same problem, has anyone got drivers for VIA VT6306 ?
    matt_g187 @ hotmail.com
  • 2,794 Answers
The first set of drivers contains the PCI drivers, USB drivers, AGP slot, as well as few others. That set will initialize the PCI controller to work. Your Firewire card won't work until that gets installed.
Once that is complete, you need to install the firewire drivers. That is what the second like is all about. Once that is installed, restart your computer and it should be working again. If the drivers aren't working from the second link, you may need to purchase a new Firewire card for your computer.
Usually when you install the 4 in 1 drivers, the computer will look at the existing hardware plugged into the the computer and try to install drivers off of that using plug and play. If it doesn't find them, it will look for the CD that came with your computer or hardware device.
Posted on Aug 18, 2008
Hello, no recognize media expansion bay
I found a list of the needed drivers most of them have drverguide.com registration is free:
VGA
Intel 82865G Integrated Device
AUDIO
Intel 82801EB ER AC97 Audio Controller (ICH5
ICH5R) Device
NETWORK
Realtek RTL 8139 8139C
MODEM
Conexant Rockwell HSF 56k HSFi
FIREWIRE
VIA Fire II OHCI Controller VT6306
DEVICE RECEIVER
Logitech LX 700
MULTIMEDIA ENCODER
Conexant Rockwell CX23418 Single Chip MPEG 2
USB
Genesys Logic USB Hub DUB H4 USB Hub
and
Intel 82801EB ER USB2 EHCI Controller ICH5
ICH5R
WI-FI
Belkin Ralink RT2573 F5D7050 Wireless V3000
Jul 03, 2014 | Acer Aspire RC500 PC Desktop
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I need drivers for this card, OS XP
You can get drivers from www.driversguide.com
Sep 02, 2010 | MSI VIA VT6306 2-Port IEEE 1394 FireWire...
I WANT TO DOWNLOAD MY VIDEOS TO A pc BUT CAN NOT , MY SONY CAMCORDER IS MODEL.DCR TRV 120, WHAT I NEED TO DO TO SUCCESS, I TRIED WITH A CABLE FROM AUDIOVIDEO ID-2 TO USB BUT CAN NOT GET IT.
your camcorder doesn't support usb streaming for PC connection.for you to download your videos you will need what we call an ilink (firewire or ieee1394)connection.the ilink jack is located at the bottom of where all jacks are located.also known as dv in/out jack with an i symbol. its a plug-and-play connection but you would need a pc that has ieee1394 card (check if you have one by going to device mng).if you do have an ieee1394 bus host controller that means you have a working port in your PC.all then need would be the correct cable for both your devices.if not,an alternative would be to use a pcmcia to ilink card that you can use if your computer has pcmcia card slot. if your able to connect and successfully establish connection you can use win moviemaker for your video capturing application.this has been too long an answer but hope it helps.thanks :)
Mar 18, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
OHCI complaint ieee1394 host controller not recognising DV camcorder. ieee1394 device displays in device manager.problem in Dellk Vostroa840 laptop.
go to support.dell.com and click on drivers and downloads and enter in your service tag and update drivers like bios and mobile chipset.
Nov 27, 2009 | Dell Vostro A860 Notebook
DV download from IEEE1394 to USB port
Exact. Firewire is a protocol. Usb is a different one. Both has nothing in common. Also if you dont have firewire it usually also means you have older computer that may have trouble to handle firewire big video files anyway. Video editing requires dual core cpu and firewire cards, and 30 gig per hour of storage...
Aug 27, 2009 | Panasonic Proline AG-DVC7 Mini DV Digital...
Attila0051
I Saw the you posting and problem is solved , sorry for the delay....
Jun 25, 2008 | JVC Everio GZ-HD7 Camcorder
VIA P4MA Motherboard Logo
9,042 people viewed this question
Top VIA Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
