Question about Aprilaire 700 Humidifier
Model 760 Humidifier - need wireing diagram please....
I need a wireing diagram for a april aire model 760 - please....
I logged on to the April Aire website and found the wire diagram i needed.
they have really good information on all their units. thanks.sc.
Posted on Aug 19, 2008
Does anyone know where i can find a wiring diagram for a model 600 aprilaire humidifier.
I hope this helps.
http://www.aprilairepartners.com/products/category/humidifiers
Scroll down towards bottom of page. I looked under the heading "CURRENT RESIDENTIAL MANUALS", and clicked on "Humidifier Model 600 Series Safety and Installation Instructions Template with Model 60".
Dec 19, 2010 | Aprilaire 600 Humidifier
How do you set and or reset the "filter replacement"schedule on the April air #700 model?
The owner's manual reads "After the Water Panel is replaced, turn the Control knob to the “Test/Reset” position until the green “Humidifier ON” light flashes, to reset the Water Panel change timer."
Hope you find this to be very helpful.
Let me know if you have any questions. :-)
Mar 20, 2010 | Aprilaire 700 Humidifier
Solenoid on Aprilaire whole house humidifier
the solenoid allows water to flow to jet that then runs down the pad the solenoid is control by the stat
Feb 23, 2010 | Aprilaire 700 Humidifier
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
When calling for heat and humidity I have 24v at the brown wires going to my Aprilaire, but the solenoid doesn't pick. Is it the control card or solenoid? Both are mounted on the Aprilaire unit. I have a...
If you have 24 volts to the solenoid, then it's not the control card. It's either the solenoid or there's an orifice in the water line at the solenoid that sometimes stops up. To check the solenoid you need to disconnect the power to the system and disconnect the solenoid wires (the two brown wires) and ohm the solenoid. If you get a low ohm reading around 50 ohms or then the solenoid is good and you need to check the orifice. If the ohm meter doesn't move when you ohm across both leads then it's the solenoid and it needs replaced.
Nov 24, 2009 | Humidifiers
Water runs when furnace is off, but stops when furnace is on.
the 760 humidifier does not need a transformer wired externally. the 760 has its' own 24v transformer inside the fan compartment. this transformer will provide the power to enrgize the water solenoid as needed. it sounds like to me the additional trasnformer is hot all the time. when the furnace comes on, the unit gets power and the internal transformer is cancelling the power from the external transformer. this would explain why it quits running when the heat is on. since the external transformer is hot all time, when the heat shuts off, the solenoid is getting energized by the external transformer. to make this run correctly, you need to get rid of the external transformer. leave the humidifier high voltage wires hooked up so they are only hot when the furnace runs. if you have a humidistat that has a r and c terminal, you will need to wire these directly to the r and c on the furnace control board and move the switch inside the humidistat to "power". make sure it is not on "bypass". then wire your 2 brown wires from the humidifier to each of the "h" terminals on the humidistat. if you have a humidistat that only has 2 terminals, wire one brown wire to each of the terminals. this should allow it to run properly.
Jan 28, 2009 | Aprilaire 700 Humidifier
Aprilaire 760 humidifier. no power to humidastat
the 760 send power out the humidistat is just a switch if you touch the two brown wire coming outof the 760 the humidifier should come on if it doesnt and you had appiled power to those wire you probably shorted the 760 control board
Jan 15, 2009 | Aprilaire Humidifiers
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
Aprilair model 760 does not go on
If you replaced the solenoid yourself make sure that is a 24VAC some solenoid are 120VAC and they look the same. to see if your humidifier is working you can short the 2 control wires coming from the humidifier I think the wires are brown or oa range. if you put then together the hum. should come on if is pluged in, if not then check your outlet see if you have 120AC plug in a lamp to check the outlet, if not your hum.may have a bad power supply you can get one at www.AppliancePartsPros.com/Parts
Dec 14, 2008 | Aprilaire 550 Humidifier
Aprilaire 700 Humidifier Logo
752 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
