Question about Kenmore Elite HE4 Electric Dryer
Kenmore model 96284100 dryer
Wont start. where is the thermal fuse?
  • Wodenickel Apr 17, 2009
    The schematic does not say physically WHERE the items are located.
    I found TWO in the heating element circuit located on the side of the heating element cover. But I'm not sure where the third one is.
    ONE is identified as a thermal fuse (blows once and stays open forever) on the schematic. The other two are identified in words and by their symbol as thermostats, they'll open at temp & re-close after cooling.
    I replace the two on the side of the heating element cover once but the dryer is not working again. One of those two shows open, so I know that one is bad. But I want to check the third item & don't know where it is!
  • 121 Answers
The thermal fuse should be connected to and near the heating element. Check the paper electrical diagram, taped on the inside of the dryer.
Posted on Aug 22, 2008
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Jun 08, 2011 | Amana Dryers
Where is the fuse at for kenmore 96284100
There is no fuse in the dryer itself. The only fuse(or circuit breaker)will be locked in your hope power panel.
Mar 01, 2011 | Kenmore Dryers
Lights turn on but dryer wont start
The problem is likely a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if the problem is not addressed above but indicate the exact model number of the machine for further advice.
Jan 23, 2011 | Kenmore Dryers
Kenmore electric dryer Model #66512692 makes a clicking noise when push start. Cleaned out so there is no air blockage and still will not start.
Hello & Welcome to FixYa
When the Thermal fuse of the dryer goes bad it wont turn on or will make clicking noise as it is doing right now. You can check the thermal fuse for continuity, if it is open then the thermal fuse needs replacement however, if the fuse tests continuity then check the control board (if that is bad then it needs replacement). Please get back to me if you have any other questions.
Dec 27, 2010 | Kenmore Dryers
Kenmore elite oasis dryer model #110.6708
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore dryer model 64602 wont turn on???
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
May 25, 2009 | Kenmore 73952 Gas Dryer
Dryer does not heat
Check the thermal cut-off, the thermostat, and the heating element. Most times one of the tree is the culprit.
I have seen a bad timer cause the no heat problem a few times but 99% of the time it is one of the three I mentioned.
If you change the thermal cut-off make sure you get both the cut-off and the thermostat. A stuck T-stat will take out a cut-off in a big hurry.
Feb 12, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
729 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
