Question about Palm Treo 500 Centro
Palm Centrol - broken screen
Centro was in my "holster" when I sat down and scrunched it. Screen is cracked, touch screen does not work right, but display is not affected. Suggestions? Cost of required parts? Instructions for repair? Cost for someone else to do the repair?
Thanks,
Steve Spieth
  • Anonymous Sep 26, 2008
    palm centro
  • centro Oct 03, 2008
    I just want to get my contact lists from the centro with the broken display
  • 3 Answers
You just need a new digitizer.
Good luck finding one though. Unless you want to order one from Hong Kong on ebay for $8. But I would not recommend that.
Posted on Sep 07, 2008
White Palm Centro freezes randomly. Doesn't respond to input
http://forums.palm.com/t5/Support-Downloads/Palm-Centro-ROM-Update-for-Freezing-Issue/td-p/165101
Mar 28, 2010 | AT&T Palm Centro Cell Phone - White
Palm Centro Freezes on Power Up
try clearing up your web history, sms, or unwanted software....on the browser, click on blazer top left corner, click on history and clear all..tested if it doesnt work back up your phone and perform a master reset
Mar 23, 2010 | Palm Treo 500 Centro
Touch screen does not work. what can i do? i already did a hard reset by instruction of palm technicians. and now im really stuck
check to make sure you have the touch screen turned on. on my touch screen, i have the option of turning off the screen so bumping it does not cause it to do things i don't want done.......
Feb 03, 2010 | Sprint Palm Centro Smartphone
I can't log out of facebook from my palm centro!! how do log out??
1) Press the options key on the bottom right of your keypad (next to the alt key). A drop down menu will appear on the top of your screen.
2) Scroll over to the options tab.
3) Scroll down to the Settings tab
4) Logout button will appear
Oct 28, 2009 | Palm Treo 500 Centro
Phone sceen turns on. fully charged. touch screen works. Phone doesn't turn on. Phone off displays after I have touched the on/off switch.
With the phone screen showing, press the red button at the right-hand side and hold it for about two seconds. The Centro should display a "Welcome" screen, then after a few seconds the phone screen should reappear with the carrier name at the upper left instead of "Phone Off". Each time you press and hold the red button the phone switch on/off..
Oct 26, 2009 | Palm Treo 500 Centro
Hi. I have a palm Centro phone through Verizon with a cracked screen. How do I go about replacing the screen?
If your Centro is in warranty then you should probably take it to a Verizon store and let them repair or replace it.
If you want to try to fix it yourself, a Google search for "palm centro screen replacement" will show you several sources for the parts needed. There are also some special tools you may need to buy. This video shows the process and should help you decide if this is something you want to try:
Oct 12, 2009 | Palm Treo 500 Centro
Keys on my palm centro won't work!
Some phones have a keypad lock so you dont accidentally hit the buttons if its in your pocket or something. Maybe try to go to settings and see if there is anything like that.
Sep 13, 2009 | Sprint Palm Centro Smartphone
How do you do a master reset on palm centro cell phone?
Hard reset - remove battery, reinstall battery and hold down power button continuously as the "palm" screen loads and the black bar moves across the screen, release. The phone will then select a language and prompt for a reformat.
Aug 03, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Hi how do i put a backround on my phone
Hello edgar_25_06,
Putting a background on the palm centro phone could either mean adding a background picture or changing the background color. If changing the color is is desired then its simple:
•Select the the 'System' category in the drop down menu at the top of the main screen.
•Open the Prefs application.
•Select 'Color theme' (near the bottom of the Prefs options).
The Color theme option displays a list of many different screen color settings. Each one of the color themes can be selected and tested on the centro until you find the one you like. Adding a picture for a background is a different matter. I haven't found out how to do that yet.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Jul 18, 2009 | Palm Treo 500 Centro
New touchscreen does not work.
Pls first hard reset ur phone like this if it doesnt help then go to AT&T it is a possible Touch Panel Failure they will do it Free if u are aunder warranty i think u are
but pls try first RESET here
http://kb.palm.com/wps/portal/kb/na/centro/centro/att/solutions/article/887_en.html#hard
and also see this for New user info
http://kb.palm.com/wps/portal/kb/na/centro/centro/att/solutions/article/45008_en.html
May 08, 2009 | AT&T Palm Centro Cell Phone - White
Palm Treo 500 Centro Logo
199 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
