Question about Dryers
DRYER WON'T RUN
OUR DRYER MYSTERIOUSLY QUIT WORKING THIS MORNING. WE'VE TRIED ALL CYCLES, AND NOTHING WORKS. TIMER STILL TICKS WHEN START BUTTON IS PUSHED. IT WORKED FINE UP UNTIL THIS POINT. I'VE CHECKED THE RECEPTACLE AND THE BREAKER, ALL OF WHICH ARE FINE.
  • patpsc Mar 02, 2009
    My LG dryer model number is LG DLE2512W. It power up alright but when I press the start button, it sounds click-click (like a relay sound) then nothing happen. The timer is ticking down and all the lighting are operating as normal but the motor does not run. I have checked all diagnosis tests as instructed in the service manual and everything seems ok.
    Please help if you know the problem is.
    Thanks
  • 5 Answers
Just want to post the solution. After completely disassembled the dryer down to the motor, I did all component tests as instructed from the service manual and all passed. I narrow down to the motor and gave it a straight 110V external source and it did run ok. So, I checked the hardness terminal at the motor to see if it give the motor the power and it does not. I pulled out the terminal wire (brown) and plugged it back making sure that it has good contact and voila... the motor run as normal.
So the problem is: electrical wire contacts getting loose due to long time motor vibration.
Posted on Mar 09, 2009
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
PYE2300AYW quit mid-cycle. Can hear the timer ticking but nothing is happening.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Maytag PYE2300AY Electric Dryer
Washer quit during wash cycle. Tub still full of water. No agitation, no sound at all but the timer ticking. I've turned it off and tried to restart it. Nothing. I even unplugged it and plugged it...
Is there a switch for the lid? If so, stick a pencil in it, sometimes they wear out and the little pin on the door does not push them down enough to activate them.
Jul 04, 2011 | Maytag Washing Machines
Dryer has stopped running in all modes. Timer makes a ticking/pulsing sound in "timed heat". Makes no sound in other modes. Origianlly stopped working when it was very hot. Next few tries ran a...
heatman101
May 04, 2011 | Dryers
My dryer won't turn on (start button?) The timer works though. It quit working in the middle of a cycle and I'm pretty sure the heat was still working, it just stopped working.
Sound`s like a broken drum belt. When the belt break`s on most kenmore/whirlpool dryer`s it prevent`s the unit from starting via a ``kill switch`` located under or next to the belt tensioner/idler pulley.
Since you`ve indicated the timer appear`s to advance/work, it is not the thermal fuse/cut-out.
The other possible fault is in the start button, but that is not very common.
I`d look at the belt. That`s what I`d check first. Hope that help`s.
Good luck and thank`s for visiting fixya.
macmarkus :)
Dec 13, 2009 | Kenmore Dryers
I have a very old roper dryer (11 yrs), it quit mid cycle. It ticks when I set the timer but nothing happens. The on button quit along time ago but when you shut the door it would start. Today nothing...
You've got an open circuit somewhere in the loop betwixt the start button, the "safety" button actuated by the door, and the motor/heat coils. Trace out those circuits and you'll have that thing running in no time.
Feb 27, 2009 | Roper REK2950W Electric Dryer
Stops during cycle
Maybe. Will the unit restart in the same position or do you have to move it? If it will work in the same position and all you're doing is waiting for a bit of cooldown...it could be a defective high limit switch that is resetting. If it will restart only after you move the timer, then change out the timer. This is a bit of a mystery since timers generally don't have 'dead spots'...they are designed differently than that.
Dec 24, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
