Question about Pentax K1000 35mm SLR Camera
Purchase part screw-on film rewinder
  • jmsugg Aug 18, 2008
    Reside in Toronto, Ont.
    Scholar:
  • 185 Answers
If the threads are not stripped on the knob or shaft, just screw it on clock-wise.
If the threads are stripped on the shaft, it must be replaced, same with knob.
To replace the shaft (if the knob is off) just pull it down in the film compartment. now there is a spring to hold the shaft up or down if the new shaft has a beveled shoulder just turn the shaft while pushing it back up. If no beveled shoulder is on the shaft then with a long needle or pin hold the spring back while pushing the shaft back up. Don't bend the spring. just move it out of the way.
Posted on Dec 07, 2008
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
My Canon AE-1 rewind crank came off while rewinding the film. can it be fixed?
Yes. I am not sure that you can do it yourself. It depends how handy you are with fiddly mechanical things. Any camera shop ought to be able to put it right.
I believe that you have simply unscrewed the crank by winding it in the wrong direction. It will screw back on, but you will need to open the camera to get hold of the internal part that it screws on to (the bit that fits into the film canister). This will need to be pushed upwards in its socket to allow you to get the crank started on the threads on the top of the shaft, and you will need to put the end of a screwdriver or something through the slot to get leverage when you come to tightening the crank the last bit.
If you heven't rewound the film yet, then open the camera in complete dark and rewind the film into the canister by hand. I usually do this in a darkened room under a bed quilt.
Nov 03, 2010 | Canon EOS-AE-1 35mm SLR Camera
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
How do i rewind the film in my nikon n2020
Set the film advance mode selector to L.
While sliding film rewind lever, push film rewind button.
Fold out film rewind crank and rotate until film advance indicator stops moving.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
Feb 13, 2010 | Nikon N2020 35mm SLR Camera
The nob that rewinds the film fell off my camera, and i unfortunately could not find it. Is there anyway to get the film out of the camera before I get a replacement piece?
yes, after dark find the darkest room or closet you can find, make sure no light is coming in around the door. pull up on the rewind shaft to open the back door. remove the film and rewind it into the canister by hand. turning to the right.
Oct 21, 2009 | Pentax K1000 35mm SLR Camera
BATTERIES DEAD, FILM INSIDE, NOT MY CAMERA, HOW DO i REMOVE FILM
Not really, the battery is going to be needed to power the rewind motor.
To try and open the camera, remove the film and rewind it will all have to be done in complete darkness and under such conditions you're likely to break something.
$7.16 is all you need for that battery including shipping:-
http://www.ebatts.com/pentax_iq-zoom-60x_digital-camera_batteries_part_b-151.aspx?GCID=C10847x066-perm3&KEYWORD=Pentax%20IQ%20Zoom%2060X%20Battery
Jul 01, 2009 | Pentax IQZoom 140M 35mm Film Camera
FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
May 21, 2009 | Nikon N80 35mm SLR Camera
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Film Advancer loose
Hi., rotate the rewinder clockwise until the film will tightened , hold the film rotator , observe the rewinder knob moving , it means the film are engage will. then shoot for favorite angle.
Feb 18, 2008 | Pentax ME Super 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
61 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
