DVDR615 will record but when I click browser button it shows disctray but resolutely refuses to show what's on the disc except on rare occasions when it will condescend to show the required information.Then it can only be persuaded to play the recorded material after a good de4al of effort.It also assures me it is "busy",what it's busy at I don't know since I haven't asked it to do anything.Any suggestions?
  • alexander549 Aug 20, 2008
    Phillips DVDR615 will sometimes record but then is very reluctant to display the recordings for playback,keeps assuring me it's "busy".What it's busy doing I don't know as I haven't even asked it to do anything.IT'S PRETTY MUCH OF A DEAD LOSS.Any suggestions?
    Problem Solver:
  • 53 Answers
Hello Alexander549:
The recommended recordable Dvd discs for that unit are
Dvd +R
SONY:
2.4X, 4X, 8X, and 16X
Tdk: 4X
DVD+RW
SONY: 2.4X
TDK: 2.4X
PHILIPS: 4X
DVDR+R (DL)
MAXELL: 2.4X
Also you can try to reset the unit. But doing this will erase all of the information on the unit I.e. clock and timer information.
Disconnect the DVD Recorder from the electrical outlet. Press and hold down the Standby on button (Power on button) on the front of the Recorder while reconnecting to the electrical outlet. Continue holding the Standby on button for 5 seconds after unit is plugged back in. Release Standby on button (Power on button) when you see "IS TV ON?" in the display window on the dvdr.
There is also a software update that you may want to try on the Philips web site and that site is www.p4c.philips.com enter in the model number then look for a sub menu labeled software and drivers there is step by step instruction for downloading the software there.
Posted on Aug 20, 2008
    Genius:
  • 2,035 Answers
Try a manual recording:
Manual record.
  1. Insert a recordable 'DVD+R(W)' disc.
  2. Select on the recorder the program/channel number or EXT/AV input to record from.
  3. From the disc menu select an empty title or a title you would like to record over.
  4. Press 'RECORD' or remote 'REC/OTR' button to start recording.
  5. Press 'STOP' to stop recording.
  • 1,879 Answers
If you're experiencing that issue with different type/brand of discs, then you're having problem with the lens. Try cleaning it using a CD Lens cleaner.
It's a common issue for all equipments that have optical drives (example: PS2 / PS3 / XBOX / DVD), the lens die and you need to have it replaced or purchase a new player whichever costs you less.
  • 6,487 Answers
Try first using another DISC to record with if possible try a different brand because sometimes it also has something to do with the compatibility of the recorder and the Disc..
Hope that helps............
Posted on Aug 18, 2008
  • Mark Gil
    Mark Gil Aug 20, 2008
    Yes, its almost a dead unit that needs a replacement,but if you can take it to a service center hopefully they can still fix it...
    Good luck........
    Sergeant:
    Champion:
  • 298 Answers
Buy a cleaner for the player. before running the cleaner unplug the component for about 20 seconds, plug it back in ,run the cleaner.
that should do the trick.
  • 876 Answers
What is the brand name of your DVD player? Thank You.
Dvr drive tray will not open
In the cover of the tray, look for a small hole the size of a pencil lead. Get a paper clip, straighten it out and push it into the hole. That should release the tray so you can get the disc out.
Jan 20, 2018 | Philips Dvdr615 Dvd Recorder
IHAVE A DVD PLAYER RECORDER DVD3460. I ENTER THE DETAILS IN THE TIMER AND IT RECORDS THE DETAILS AS VALID, 5 TIMES IN A ROW IT SHOWED FAILED.IT HAS ON OCCASIONS RECORDED CORRECTLY, BUT NOT OF LATE??...
Thank you for posting your concern details however i would be
needing few more details from your side if necessary and
allow me few mins to come up with the resolution.
May 14, 2008 | Televison & Video
Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Sep 26, 2008 | Philips DVDR615 DVD Player
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
No disc kicks disc out
I have the problem of it refusing the disc if the door opens before I have filled the whole disc and finalized it. As long as I don't open the door till the disc is full and finalized, it works.
Aug 30, 2008 | Samsung DVD-R130 DVD Recorder
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
